I have a nec nw-691, when you put it on spin cycle it brings error message --lid open??? plz help
Shows error code LE. tried a reset but didnt work. all other cycles work perfect but not the spin cycle. i have just recently moved house and it worked perfect b4 i moved
    Sergeant:
  • 290 Answers
Yuo might try making sure it is still level but I'd just try using a lower spin speed. How have to use "gentle spin" when I wash towels or my washing machine has errors and stops. If still too damp just use a gentle spin only cycle once more to finish the job.
Posted on Apr 16, 2015
LE error (checked stator and replaced HAll sensor already)
If the control board does not receive the input it will not operate does the door lock? However:
The attachment shows how to diagnose and repair a failed hall sensor, the usual cause of
an LE error code.
DO NOT replace the stator until the hall sensor has been tested. 98% of LE error codes are
caused by failed hall sensors.
[DD motor SVC check process ]
Pre Check
1) Gentle wash cycles, such as Perm Press, Delicates, Hand Wash, and Wool/Silk should only be used for
smaller loads. Because these cycles are more gentle in tumbling and spinning, putting too much in the
drum can register an issue with the motor. Remove items, reset unit and test with a Rinse/Spin cycle.
2) Don't replace the PCB when the hall sensor is replaced.
Check the hall sensor as shown in the new process.
O have a file I can send but can not upload here if you want it, contact me melissamaemartin@yahoo.com please put hall sensor in subject line. Thanks
Mar 28, 2014 | LG WM-2277HW Front Load Washer
Washing machine not spinning, stops & the letters LE flash, washing machine is a NEC NW-892 Millenium
It sounds like your lid switch is not working correctly, look to see if there is supposed to be a finger that protrudes from the bottom of the lid and enters a hole in the top of the washer, this is a safety switch to ensure the lid is closed, it is possible the actuator finger is broken or missing, If this is the case, I have heard of people manually actuating the switch to finish the load, I am not suggesting that because there is a safety issue, but it has been done. Your washer might not have an exposed actuator,it could be hidden under the washer top, but the LE error code indicates the lid is open.
Nov 10, 2012 | Washing Machines
I have a top load machine which shows LE error code despite lid is closed properly. This continues for half an hour then machine starts working again but the error resumes after every two minutes. Plz help
'LE' stands for Lock/Lid Error. There is likely to be a problem with either the lid solenoid/lock or the 'lid closed' sensor. Both require a service engineer's attention I suggest ;-0(
Good luck,
John C
Mar 22, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
I am Looking for the meaning to eror code LE on my washing machine it is an nec model No NW 452
According to what's written in the manual...
'LE' will light up if the machine is unbalanced or the lid is open. This can be corrected by following operation: WATER SUPPLYfi RINSEfi DRAIN. However if the unbalanced condition is unchanged despite repeating the above operation, the lamp 'UE' will light up, and the buzzer will sound to indicate a problem.
Jan 13, 2011 | Washing Machines
Nec nw-452 washing maching gives le message after filling with water? any help?
The lid switch is faulty and needs to be replaced or bypassed.
Sep 28, 2010 | Washing Machines
NEC nw-452 coming up with LE fault.
LE means the lid is up. If it's down try lifting it up
Sep 09, 2010 | Washing Machines
My NEC Fuzzy Logic 6.5kg Washer keeps coming up with LE in the timer box. It also makes a high pitched noise with it. I suspect it is some sort of error message? The washing machine is not dispensing...
I had the same problem, When calling a repair shop I told the mechanic it was coming up LE on the display. He told me it was a lid error. Which made perfectly clear sence. I checked the lip of the lid and there it was, a piece broken off where it hits the saftey switch. (my switch was on the left). So check the strike plate on your lid. You may have to screw a piece of alaminium angle to replace it. Or replace the lid.
Jul 02, 2008 | Washing Machines
Daewoo washing machine dwf-75ts
Found the manual for a similar model. LE error code indicates a "Lid Open" error. Most likely the little switch that is tripped when you open the lid has failed due to corrosion or some other reason. If you can find an equivalent switch then replacing it should do the trick. Otherwise, you can simply short the connection so the machine thinks that the lid is always closed. WARNING: This effectively overrides the open lid detection system and poses the risk of having the unit run a spin cycle even with the lid open! find a replacement switch if you can. good luck! just shorted mine out temporarily and it works -- until i can find the right switch.
May 23, 2008 | Washing Machines
Won't spin, error LE appears on display
If the washer seems to complete all of its cycles, but doesn't spin: 1) Be sure the load of clothes is not lop-sided. If the tub becomes unbalanced, it may spin erratically or not at all. Open the lid after 2 minute gap and reposition the clothes. This automatically resets an off-balance shut-off switch. Close the lid and re-try. 2) Check the lid switch and the tab on the lid that strikes it. If the plastic tab is broken, the washer may halt during the spin cycle. If the switch doesn't click when you press and release it, it's probably broken. If you're experienced at home repair, you can remove the switch, test it, and replace it if needed; otherwise, call an appliance repair service person. 3) The belt may be loose, worn, or broken. If you're fairly handy, tighten or replace the belt, otherwise call an appliance repairperson. Pl post back results
May 06, 2007 | LG WM-1832C Front Load Washer
Washing Machines Logo
77 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
