Question about Ovens
Oven door will not close properly - Ovens
  • Ovens Master
  • 3,463 Answers
Generally speaking, if the oven door closes most of the way, but remains partially open, then it is necessary to replace the oven door hinges if it ios a drop down door.
Posted on Apr 17, 2015
The oven door doesn't close tight
Hello, Anna -
The problem of your oven door not closing tightly could be caused by one of several problems:
* A problem with the door hinges
* Broken oven door springs
* A problem with the gasket inside the edge of the oven door
This article from the San Francisco Examiner newspaper describes the problems and how to fix them:
http://homeguides.sfgate.com/fix-oven-door-not-close-properly-28760.html
Best wishes.
Feb 07, 2018 | Ovens
Door of oven is closing properly
Excellent! Glad to hear it. It's so inconvenient when they do not, especially on Wednesdays.
May 22, 2015 | Ovens
Oven door does not close properly
When you say "oven door does not close properly", do you mean that it closes but not tightly against the rubber seal on the oven cavity?
Or is it some other closing problem?
If it is the former, then it is a sign of the door hinge springs wearing out. The solution to this is to replace both hinges on the offending door.
Sep 01, 2011 | Neff B1421 Electric Single Oven
Both oven doors do not close properly. lights stay on & can't heat properly with doors not closing tight. is there an adjustment for these doors?
We have similar Jen Air double oven and with the same problem but only on the lower oven. The doors are interchangeable and the top door fits fine but the lower door will not close completely at the top. It does turn out the light but has never cooked properly. I checked with several appliance repair shops and the hinges are not adjustable, but since one door closes and our other doesn't it is not a hinge problem, just a defective design.
We let this go too long and are out of warranty so I doubt Jennair is going to do anything. I hope someone post a solution but it is clearly not problem with the henges but with the receptacle they go into.
Jan 04, 2011 | Jenn-Air WW27430P Stainless Steel Electric...
OVEN DOOR IS NOT CLOSE PROPERLY.
which subway are you , if the door doesnt close properly you may need new hinges
Jul 14, 2010 | TurboChef C3 Single Oven
Oven door not closing properly
If it is a drop down door with hinges on the bootom of the oven door, then it is likely to be weak door hinge springs, the usual solution is to replace both hinges.
If it is a swing open door, then the problem is related to a worn or broken door catch, or worn striker pin.
Apr 13, 2010 | Ovens
Oven door does not fully close
The usual reason for oven doors not closing properly, is weak door hinges,if it does not close all the way, and the door seal is o/k, then I suggest you replace both door hinges. Please rate my solution. Thamks.
Jun 06, 2009 | Amana AOCS3040 Electric Single Oven
Oven doors will not close properly
Most of these I have seen have to have the hinges and recievers replaced to get the doors to close properly and keep the light off.
Apr 17, 2008 | Ovens
Electrolux EOC6690X Pyrolytic Door won't close properly
if the door lock engagement rod is sticking out then with the door open hold the switch down with your finger then hit start then cancel lock rod should go back letting door close if engagement hook is not sticking out may have to replace switch some are bad about breaking but have been impooved
Dec 28, 2007 | Electrolux EOC6690X Pyrolytic Electric...
Ovens Logo
139 people viewed this question
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
