Bdp-s1500 won't change wired to wireless so I can't connect to internet
    Sergeant:
  • 290 Answers
You need to configure wireless. There is no switching involved since both can be always on. To not be wired you simply pull out the Ethernet jack.
Posted on Apr 16, 2015
2 Suggested Answers
  • 21 Answers
SOURCE: Wireless and internet
1. Make sure that wireless settings are properly synchronized.
>> ssid/security key.
2. Check your computers wireless connection status
> Make sure that it is set to "obtain ip address automatically)
3. If still not working if computer is set to obtain ip automatically, try assigning static ip on wireless pc
> You need to know your router's ip address and dns
4. Disable firewall on wireless pc.
Posted on Jan 26, 2008
Do I need WiFi to connect my blue ray to my tv?
No an HDMI cable should do the trick. You would only need WiFi if it was in a different room completely and thus a cable would be impracticable.
Dec 23, 2016 | Televison & Video
I don'tsee what i just purchased. 2 ganes I alredy have won"t run now. on occasioun it tells me i have no connection-not possible Please help me
it is possible,just because you are connected wirelessly,doesn't mean that you are connected to the internet,you ARE ONLY CONNECTED TO YOUR MODEM,unplug your modem from the internet and power for 30 seconds then plug in the internet wire then power and let it reboot,then see how the connection is.if you have more things connected to the modem,either wirelessly(like laptop) or wired(like xbox or tv),they will use your bandwidth which will cause connection errors on a tablet
May 28, 2015 | Tablets & eReaders
I have wireless Internet! I have a laptop, I tried to connect to it~ It will connect to the router, but won't connect to the Internet! Help!
How many wired and wireless computers do you have ion the network.
Do you have any wired computer ?
Connect your laptop to the router with the Ethernet cable and try to access Internet. See if the wired connection is working or not.
If the wired connection is working then I think you will need to check the wireless settings of the router and the laptop.
Try following websites
Router setup
How to connect to the wireless network
May 15, 2012 | Computers & Internet
Wirelss router won't allow other devices to connect to it - eg kindle, iphone, but internet works fine on computer (which it's plugged into)...
Before you start :
The Following Steps Should be done on the computer that is connected to the router (Plugged with a cable)
Step 1 : Make sure you have internet access
Step 2 : Open Router Setup by typing http://192.168.2.1 in the address bar of Internet Explorer
Step 3 : Once you are at the router setup .. on the left side underneath Wireless you can find Wi-Fi Protected Setup
Click it
Step 4 : If it is asking for a password .. leave the password field blank and click submit
Step 5 : Disable Wi Fi Protected Setup and click apply changes
Step 6 : Now on the left under wireless click Security
Step 7 : If it is asking for a password .. leave the password field blank and click submit
Step 8 : Change the Security mode to WPA-PSK (you can also choose WPA-2 but sometimes it doesnt work )
Step 9 : Type a password (8 Characters , It is Case Sensitive)
Step 10: Click apply Changes
Step 11: On the left , Under Wireless Click Channel and SSiD
Step 12: Change the SSiD to a Different name , Change the Wireless Channel to 11
Step 13:Click Apply Changes
Turn On the Wireless Switch on the Computer (If you are using a Laptop to Connect between router)
Now try to Connect to this new network on both your wireless Computers and Ipad
Let Me Know if it Works
Aug 24, 2011 | Belkin (F5D5231-4) Router
When setting up bluray, the set up states that wireless found, but can't make an internet connection when trying to hook up with netflix
I'm sorry to inform you that if you're referring to the BDP-S300, it does not have network capability. You can plaback Blu-ray discs. That's it.. If not please get back with the exact model # so that I might be able to assist you better.
Feb 05, 2011 | Sony BDP-S300 Blu-Ray Disc Player
HOW DO I CONNECT MY BLU RAY PLAYERS BDP S360 & BDP S1E TO A COMPUTER AND INTERNET ??? WHAT TYPE OF CABLES SHOULD I USE FOR CONNECTING THESE TYPE OF PLAYERS TO A COMPUTER ??? THANKS !!!
With the BDP S360 there is a port titled 'LAN'. With this port you need an ethernet (RJ45) cable which you can plug into your router or computer. If you plug it into your computer, you will need to bridge the connections to send the internet connection through the LAN cable. There's a good tutorial on how to do this here: http://helpdeskgeek.com/windows-7/bridge-network-connections-in-windows-7/ OR for XP: http://www.home-network-help.com/network-bridge.html
As for your BDP S1E player, you are unable to connect it to the internet.
Good Luck! -AC
Jan 05, 2011 | Televison & Video
CHANGE FROM WIRELESS TO WIRED INTERNET CONNECTION
It is possible .. just get youself an ethernet cable .. connect one end to your router and the other end to the back of the pc ( ethernet port ) .. and u will be connected via the wire.. You can disable the wireless connection from the router for that you can either call your Internet service provider or the netgear support team.
All The Best!!!
Please come back to vote, it would be a great appreciation for me and boost my determination to help so that I can keep on helping.
Zooless
May 24, 2010 | Computers & Internet
Sony code for chungchop rm-88E
I need 3 digit code for sony bluray bdp s1500 by using universal remote chunghop RM-88E.
Mar 15, 2009 | Sony 8-Device Universal Learning Remote
Computers & Internet Logo
231 people viewed this question
David Payne
David Payne
