Question about Maytag Washing Machines
Maytag MEDE200XW1 s2000, front loading. Power on I get a "PF" code on the display. When turned on I hear a click but the machine does.not turn on. Thermal fuse? How do I locate it and access it.
    Sergeant:
  • 290 Answers
It should have come with a manual which would include that level of detail. I have a lower drawer of my filing cabinet just for manuals and the other upper one for the usual bills, warranties, etc.
Posted on Apr 16, 2015
SOURCE: PF display on my maytag neptune
The poster who advised me to unplug the unit for about 5-10 minutes was likely right and I probably could have done that and been able to restart the cycle last night but I waited until this morning and just selected "rinse" and pushed start. The door locked, then unlocked and the cycle stopped... BUT... then it started draining & finished correctly.
Chrf's assistance was definitely helpful- wish I'd been up at 0330 to try it because waiting all night for it to 'rest' on its own certainly messed up the clothing situation for my boys this morning!!
great website- thanks for being here!
Posted on Mar 05, 2008
  • 3 Answers
SOURCE: Maytag front loading washing machine
This worked for me for the E3 error code: Turn the machine off and then on. Enter the Service Mode by pressing the Chime and Exrta Rinse keys for 3 sec. Display the Diagnostic Codes by pressing the Rinse and Spin key. Clear the codes by pressing the Delay and Chime keys for 3 sec. Turn the machine off, unplug and plug in the power cord. This dumps the memory. Evidently, if it gets full, it causes problems with the programming and messes up the cycles.
Posted on Jun 20, 2008
  • 1122 Answers
SOURCE: washer machine maytag neptune front load
take the back panel off,see if the belt has broke if not,check your motor control board for burn spots ,front bottom right inside washer,if not that then your motor has gotten weak and will not turn the drum,let me knoe what you find-mike
Posted on Jul 12, 2008
  • 50 Answers
SOURCE: how to fix the LO error code on Maytag Neptune front load washer
Not really bad news. The unit requires a door lock assembly.
Posted on Feb 23, 2009
SOURCE: Maytag front loader washer--door won't open but lock light off
Open the soap dispenser. Look down in front of the fabric softener dish.
You should see a yellowy-green plastic cord (like weed-whacker line). Pull it.
The door should open.
If you don't see the cord, remove the four screws that hold the dispenser lid in place to find it. Just don't lose it when you put the cover back on.
Posted on Apr 16, 2009
Wm3431 pf code
The PF error code indicates a power failure. This might occur while machine is working due to an external disturbance like a storm or power outage in the area. If the PF error code is displayed, turn off the power to the washer, unplug it for 10 seconds, and restart the wash cycle. If the error code continues to present after these steps have been taken, then the washer may require service.
Apr 26, 2012 | LG WM3431 Front Load Washer / Dryer
How do you fix the maytag neptune pf code for the dryer??
Here is a tips that I wrote that will help to explain why you get the PF Error Code
PF Error Codefor Appliances
heatman101
Apr 13, 2011 | Maytag Neptune MAH5500B Front Load Washer
My maytage neptune washer is flashing PF what does that mean?
Hi
Error code PF means power failure. This happens when there is a power surge or the washer is unplugged manually. To reset this error you'll need to turn off the washer and unplug it for 10 minutes. Restart the washer and check, If the error still appears then pressing the Spin Speed key will begin the Board Output Test. This test turns ‘ON’ a specified output after a key press. Pressing the Spin Speed key again cancels the test. Please post back for further assistance if required.
Daniel
Aug 27, 2010 | Maytag Neptune MAH5500B Front Load Washer
Code pf
This error means Power Fail PF, this indicates that the Power Went off during the cycle, or while it was ON. Simply turn on & off again, this should clear the fault code.
Apr 04, 2010 | Maytag MAH8700A Front Load Washer
I get a PF error. That goes away and shows 52 in the display. The buttons light up, but pressing any buttons does nothing but to make 3 beeps.
PF is Power Fail, means the Power was cut off. PF Power failure Power to the machine has been lost during the last cycle. This may occur on start up of a new machine due to factory testing.
Mar 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
PF CODE COMES UP WHAT IS LIKELY PROBLE
Found the below at http://lgknowledgebase.com
hope this helps,
best of luck, have fun,
thanks,
chuck
Feb 25, 2010 | LG WM1814CW Front Load Washer
Just moved, dryer won't tumble with a load. Error code PF
Did it get tipped in the move? I don't know about the specific model of Maytag, but on my old Kenmore the belt that ran the drum also had a wheel and kind of like a pulley that it had to seated on in order for the belt to stay centered on the drum and turn properly.I don't know how you get the shell off the front to get at the drum, the Kenmore had screws that you had to take out and lift the control panel off and then back to get at the inside. Sorry
Jun 18, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Error code PF
PF means Power Failure!
Unplug both units for 10 minutes, then plug them back in and try operating them. You may need an electrician to investigate why you are losing power to both units
Jun 04, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Error code PF
THIS is a "Power Failure " Clease the code (press Cancel button) and see if it starts up
Jan 23, 2008 | Maytag MAH8700A Front Load Washer
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
