Question about InFocus X3 DLP Projector
How do I open the case?? - InFocus X3 DLP Projector
How to open case?
under the decals on ether side are four screws remove these and
separate the sides under these you will find white wedges that hold the case halfs together pull out these wedges and open the case. repair unit and Reverse the prosess to reassemble the unit. If you know how to work on electronics you may need to replace the electrolitic capacitors while the case is open. Kill 2 birds with one stone.
Oct 27, 2012 | Namco Arcade Classics Plug and Play TV...
I cannot open the case
You open the case by laying it on its side, pressing two buttons, and folding it open like a book.We found it awkward to simultaneously press two large release buttons and lift the case open, and we encountered some uncomfortable resistance in swinging it all the way open.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Jun 11, 2010 | Dell Dimension 8200 PC Desktop
How do I open the case of a 1968 automatic, ambassador Bulova watch? It appears that there is no way to open the back.
Pull out the crown. Now try to pull out it more, just don't do too hard. If the stem does not come out, there is the way you can open the watch - if it does not, then you have a monoblock case and it can be opened by the special pump only. In case if you can not pull the stem out, take an eyeglass and examine case back all the way around the case. You have to see the tiny groove. This is the place where to insert the openers blade and pry it .
Rate me, plz.
Jan 25, 2010 | Watches
Can;t open back of watchto find date it was made do i need special tool or some thing else can be used
You definitely need special Rolex case back opener. Without it your watch will be locked forever. Rolex cases are so tight, that even when special opener is used, you will need quite strong arms to open it. Rolex case openers sometimes sells on ebay, but they are never cheap.
Jan 07, 2010 | Rolex Daytona 116520 Wrist Watch
Need to open the case of a Mactor OneTouch III to
well i dont think we will be able to open the case of the hard drive commonly because a hard drive is the safe casing of the very expensive metal disc which is used to store the data on to it and it is done by using magnetic energy so normaly a hard drive cannot be dismantled by the user but may be the drive manufacturer can do this only in the extreme needs.
Good Luck.
Jan 07, 2010 | Computers & Internet
Cannot open clasp prestige replica rolex
1)Unscrew the crown until it pops out, the same way you would unscrew the crown to change the time on the watch.
2)Place the watch case opener in the notches around the outside of the back of the watch case. You have to use a watch case opener made for Rolex watches to open the watch. Once the case opener is in place, twist it and the back will pop open.
3)Use a mini screwdriver to loosen a tiny screw on the inside of the watch located near the stem. You do not need to unscrew fully--only loosen it.
4)Pull the crown straight out. The crown and stem should come out easily.
To open the back of the watch
1)Purchase a Rolex watch back opener set, if you do not already have one. This set is able to open and close any size of Rolex case.
2)Match the size of your Rolex case with the same size of grooved metal die from the tool set.
3)Put the metal die on the grooves on the back of the watch case.
4)Turn the die to remove the case.
5)Remove the rubber gasket.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Dec 31, 2009 | Bulova Watch
Can not open case to install 2.5
The wheel probably is an OFF/ON switch.
Take a closer look for small screws. If you see none, then what you probably have is a "press-fit" case -- like the lid on a bottle of ketchup -- that takes some pressure to force the case to open.
If you just recently bought the case, take it back to the store that sold it to you, and get them to demonstrate how to open the case.
Dec 29, 2009 | Computers & Internet
How to open it to clean it
small form factor desktop cases. With these you just push the buttons at the back on each side of the case and it lifts up there's a button on each side of the case towards the back.. press in and pull open the case, it's easier to open one side at a time.
(it's a hinged case design, lifts at the back and hinges at the front.)
hope this helps
Nov 06, 2009 | Dell GX280 Tower PC Desktop
Can't figure out how to open the case
There may be lock system rather than a screw. Please see the lock and it will be opened by pressing a lock node(s) or aplying the force in a paticular direction. Do not try to open force fully. Refer manual of scanner if there are instruction to open the case.
Aug 23, 2007 | HP ScanJet 3300Cse Flatbed Scanner
InFocus X3 DLP Projector Logo
48 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
