Question about Melissa And Doug Trunki Terrance (Blue)
Where can I get replacement latches? - Melissa And Doug Trunki Terrance (Blue)
  • toriless Apr 16, 2015
    Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    for what?
My Bosch Dishwasher door sticks shut at the end of the cycle. I can open and close it with ease during the cycle, but once it finishes I have to pull really hard to open it.
see all this steps and fix it. God bless you
Door or Lid Latch Assembly
If the door won't latch, the latch assembly might be defective. Inspect the latch assembly to see if it is cracked or worn out. The latch assembly is normally replaced all as one part.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Door Hinge
If the door won't latch, one or more of the door hinges might be bent or broken. If the door hinges are not working properly the door won't close squarely and then the door won't latch.
Door Catch
If the door won't latch, the door catch might be out of alignment or broken. If it appears to be OK, reposition it as needed. If appears broken it should be replaced.
Door Lock
If the door won't latch, the door lock assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door lock is broken, replace it.
Door Latch
If the door won't latch, the door latch assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door latch is broken, replace it.
Door Strike
If the door won't latch, the door strike might be defective. These are normally made of plastic or metal and cannot be repaired. If the door won't latch and the door strike is broken, replace it.
Apr 05, 2013 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Door wont shut
Door Hinge
Door Catch
Door Lock
Door Latch
Door Strike
Apr 05, 2013 | Miele Dishwashers
Hood latch won't latch when closing
Raise hood,have some one go pull hood latch and you look at latch and see if it releases,if it doesn't then cable may need replacing,I would'nt completely shut hood cause you may not get back open,also check hood latches bolts and latch for something bent or broken.
Sep 21, 2012 | Chevrolet Silverado 1500 Cars & Trucks
95 dodge caravan drivers door won't latch
often normal door latches will wear out causing the door latch to not activate the "full latch". The full latch ends up moving further up and into the latch. the solution is to replace the latch or have it rebuilt.
Aug 03, 2012 | 1995 Dodge Grand Caravan
I need information on how to replace (or service) the door latch mechanism on my merc. I have realigned the door (and realigned the striker rod) and it will still not close. The latching system does not...
Removal
  1. Disconnect battery ground cable (14301).
  1. Remove front door trim panel (23942) and watershield from front door (20124).
  1. Mark the location of the bolt retaining front door glass run front retainer (21572). Remove the bolt.
  1. Check all rod connections against the appropriate illustration. Correct any disconnected or loose connections and check operation before replacing parts.
  1. Remove power door lock actuator (218A42).
  1. Disconnect the rods from the front door latch (21812). The front door latch remote control link (21940) and the latch-to-lock cylinder rod cannot be removed at this time because of the rod's end configuration. Remove wiring from clip on front door latch shield.
  1. Remove front door latch control cylinder rod (22134) from the door lock cylinder (21985).
  1. Remove front door latch remote control and link (21818).
  1. Remove the front door latch retaining screws. Disconnect the door open warning lamp switch (14018) if so equipped. Remove the front door latch from the front door.
  1. NOTE: Do not damage anti-theft shield.
    Remove anti-theft shield from the front door latch.
  1. Remove front door latch remote control link, front door latch control cylinder rods and door open warning lamp switches from front door latch where applicable.
Installation
  1. Follow removal procedure in reverse order.
  1. Tighten front door latch retaining screws 4-8 Nm (36-70 lb-in).
Item Description 1 Front Door Latch Control Cylinder Rod 2 Front Door Latch Remote Control Link 3 Bushing 4 Door Latch Shield 5 Power Door Lock Actuator 6 Front Door Latch Control Cylinder Rod 7 Front Door Latch 8 Latch (1 Req'd) 9 Screws (2 Req'd)
Feb 13, 2011 | 1997 Mercury Cougar XR7
Thought door was frozen shut on 96 grand am se so pulled it open and now it won't close latch not engaged and door lines up but won't stay latched shut....
The latch may already be latched like it is closed. You can take a screw driver and put it.. where the latch engages Slightly pry outward agianst the latch while pulling on the door handle. That should release the latch. If you continue to have the problem than the latch will have to be replaced because there is a plastic piece that may be worn out.You will have to remove the door panel to replace the latch. They sell a book on that car that will explain how to remove the door handle(at O'rielly).
Dec 09, 2010 | 2000 Pontiac Grand Am GT
Boiled over then ceramic touch buttons all beeped. I believe default E-11. No manual what do I do and wht did a boil over leak is this not a sealed unit.
HI. This E-11 Code is an indication of a failed Door latch mechanism. I would advise to inspect the latch assembly for loose wire connections at the latch, and main control board. If the wires are attached correctly, and the contacts are ok, simply replace the Door latch assembly. Once the door latch is replaced, the code will shutdown, and the unit will operate properly.
NOTE_ It would be wise to try a hard reset, before purchasing the replacement door latch. Kindly, unplug, or shutdown the appropriate circuit breaker for 5 minutes. Once the 5 minutes have passed, simply re-introduce power to the unit, and observe the actions. If the error code illuminates again, replace the door latch assembly.
Nov 14, 2009 | Electrolux Kitchen Ranges
2001 Ford Escape Rear Hatch won't unlock
The liftgate consists of the following components:
  • liftgate door lock actuator
  • liftgate lock cylinder (if equipped)
  • liftgate window glass
  • liftgate window latch/ajar switch
  • liftgate window glass release handle
  • liftgate latch remote control which consists of the following component:
    • liftgate release handle
  • liftgate latch, which consist of the following component:
    • liftgate latch door ajar switch
Liftgate Latch Actuator Removal and Installation
  1. Remove the liftgate latch remote control. For additional information, refer to Liftgate Latch Remote Control in this section.
SECTION 501-14: Handles, Locks, Latches and Entry Systems 2001 Escape Workshop Manual
REMOVAL AND INSTALLATION Liftgate Latch Removal and Installation
  1. Remove the liftgate trim panel.
  1. Disconnect the liftgate ajar switch electrical connector.
  1. Disconnect the liftgate latch actuating rod.
    1. Open the clip.
    1. Disconnect the actuating rod.
  1. Remove and discard the liftgate latch bolts.
  1. Remove the liftgate latch.
  1. NOTE: Make sure the liftgate latch release rod is not preloading the latch. It should be clipped in a relaxed state with no slack.
    NOTE: Position the liftgate latch release rod by pushing outboard to remove the slack.
  1. Remove the screws and the liftgate latch actuator
May 29, 2009 | 2001 Ford Escape
Front loader washing machine the door latch is broken, it will not shut to perform cycle. Can you help?
Does it never latch and run, or does it occasionally work? Have you tried pushing on the door? Does the latch make any sort of noise? Have you recently had the boot replaced because of mold? Sorry for all the questions in reply to your question, but if the latch is physically broken then it needs to be replaced. If the question is "how do I replace a broken Bosch latch?", that's a different question.
May 06, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Broken latch
Replacement latch can be found at amazon, click here Amazon com mailbox latch and chose needed one. Wish you best of luck. John
May 03, 2009 | Solar Group Black Aluminum Mailbox Post,...
Melissa And Doug  Trunki Terrance (Blue) Logo
85 people viewed this question
Top Melissa And Doug Toys Experts
Jennifer Rock
Jennifer Rock
Linda Gentile
Level 1 Expert
Tom Chichester
Are you a Melissa And Doug Toy Expert? Answer questions, earn points and help others
