Question about LG Washing Machines
Front load washer LG wm2140cw has te error. changed the thermistor, but there is a wire broken off from the wire it plugs into. what is the replacement wire and where can I get omne?
    Genius:
  • LG Master
  • 1,585 Answers
Fix it with connector strip
Posted on Apr 16, 2015
4 Suggested Answers
  • 380 Answers
SOURCE: washer is showing "TE" error even after replacing the thermistor
Try pressing spin speed and soild level at the same time. Is the temperature about 10 degrees C over the the selected temperature? If no, then try replacing the main board.
Also make sure the thermister isn't loose. That could cause your problem.
If the main board doesn't fix it, then you have to replace the heater assembly.
Im actually looking the the service manual your unit as we speak.
Posted on May 27, 2009
  • 5 Answers
SOURCE: LG Tromm washer WM2688HWM tE error code. Very easy
LG Tromm Washing machine te error. The manual says to call for service. Not much help there. The reason for the error is the thermistor circuit (resistive element that becomes less resistive as it increases in temperature). The thermistor acts as a heat sensor. In many cases, the error occurs because the wireing harness is too tight at the bottom of the drum and one of the wires in this circuit becomes disconnected with all of the movement of the drum (unbalanced load, normal cylcing etc).
1. Unplug the washing machine from the wall. The thermistor circuit is at line voltage (110 in the U.S.) and it will bite! So do this first before proceeding.
2. Move the washer out so you can get access to the back of it.
3. Remove the stainless panel (the one that is not painted, it is large (aprox. 16x18 inches). It is held in place by 4 phillips screws.
4. Locate the thermistor connection block near the bottom of the machine, at the center of the wash drum. It is the small white connector that has two wires running to it. One wire is dark blue, the other is light blue. Insure that neither wire has pulled out of the connector. If either of them have, repair the connector and provide enough extra wire ( aprox. 2") to provide cable relief.
5. If the cable connector and wires are ok, there are other solutions here that recommend either cleaning or replacing the thermistor.
Good luck to you.
Posted on Aug 04, 2009
  • 119 Answers
SOURCE: How much does a broken thermistor typically cost?
THAT THING RARELY GO BAD. CHECK THE CONNECTIONS ON IT FIRST. UNPLUG AND PLUG CONNECTOR IN FEW TIMES. WHILE YOU DOWN THERE, PULL IT OUT COMPLETELY AND SEE IF IT COVERED WITH SOAP SCUM, GUNK, ETC. THAT WILL GIVE YOU FALSE READINGS AND GIVE YOU AN ERROR CODE FOR THE THERMISTOR
Posted on Aug 04, 2010
Front load washer LG wm2140cw with error code up side down FE. Any ideas what this means? Will start to run then error code shows up and it stops.
A tE error code on the display of the washer indicates a heating error, usually caused by a faulty thermistor.
  1. Unplug the washer from the power outlet for 10 seconds.
  2. Plug the washer back in and press the POWER button and then the SPIN SPEED button until No Spin is selected. Press the START/PAUSE button.
  3. Once the washer has drained, restart the wash cycle.
  4. If the tE error code appears again, close the water taps and unplug the washer. The washer will require repair service.
Apr 06, 2015 | LG Washing Machines
Lg front load washer with a tE error code and switched the thermistor that was located when I took the top off the washer and it ran two loads fine but code is back...I noticed online they keep saying the...
As many suggest, the tE error means there is a thermistor error. On my machine, simply unplugging the machine, tipping the machine backwards (careful! ... I put a few blocks under the front legs so I could work under the machine)...and the thermistor was under the drum, with a 2-wire lead going to it. It was easy to unplug, tighten the plug (squeezing the connector), plugging it back in. The machine has now worked fine ever since this simple procedure with no failures.
Oct 27, 2013 | LG WM2688HWM TROMM SteamWasher
I have te error
The thermistor temperature sensor in the machine is faulty and needs to be replaced.
TE = "Thermister Error"
The thermister sensor is connected to the main control board and relays the temperature of the water to it.
Sep 14, 2013 | LG WM2140CW Washer
Error code te for lg tromm front load washer wm2496hsm
The TE error code is a Thermistor error. Replace the thermistor and you should be good to go.
Feb 29, 2012 | LG WM-2032H Front Load Washer
Error code te
"te" error code is caused by a faulty thermistor; likey cause is:
a. Loose wiring at the control panel (directly behind the cycle selector knob)
b. Broken wire at the thermistor (located at the bottom/front of the tub)
To access the wire plug connectors at the control pannel, remove the top cover of the washer. Stand in front of the washer and look for the plug connectors behind the control panel. Pull apart the plugs and re-install.
Test the washer. If the "te" error still occurs it will be neccesary to remove the front panel as well (two sets of special plier-type tools are needed).
Inspect the thermistor closely, with good lighting. If there's a break in the wire it will be at or near the black sheathing / heat shrink material.
Hope this helps and just keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa.
Nov 01, 2011 | Samsung WF337AA Front Load Washer
I have a Maytag Neptune MAH8700AWW with error code tE, lower case t and upper case E. What causes it. I finally got it in diagnostic mode and it says U133 but wont go any further.
Just like a reference guide, this service manual could helpful: MAH9700AW
Hope this helps.
Oct 07, 2011 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune mah8700aww has an error tE, lower case t and upper case E.
Hope this helps.
Getting a "te" error code -- a heating issue?
I had the tE or te error (an L with a line through it) error on my LG front loader and my local appliance store sold me the thermistor for $7. I layed the unit on its side and accessed the thermistor through the bottom. It plugs into the bottom of the tank. Blue and white wires. No screws and 1 tie-wrap. (Leave the rubber grommet in - just pull the thermistor rod out.) Works like a champ!
Jan 05, 2011 | LG WM2487H Front Load Washer
Te code is showing up. how do i fix this
Sorry to read about your problem, I hope this helps you out.
The te code means a defective thermistor. but thermistors rarely fail in LG washers.
The most likey cause of the "te" error is:
1) Loose wiring at the control panel (directly behind the CYCLE SELECTOR KNOB)
2) Broken wire at the THERMISTOR (located at the bottom /front of the tub)
Test the washer. If the "te" error still occurs--it will be neccesary to remove the FRONT PANEL as well (two sets of special plier-type tools are needed).
Inspect the THERMISTOR closely--with good lighting. If there's a break in the wire it will be at or near the black sheathing / heat shrink material.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 02, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG WM2688H Front Load Washer
I do not have a solution, but have the same exact problem and would like to know if you ever found out where the thermistor is and if you were able to fix it.
Thank you,
Treegirl
Sep 12, 2007 | LG WM2688H Front Load Washer
Washing Machines Logo
160 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
