Question about Health & Beauty
How to wire battery pack - Health & Beauty
  • 1,263 Answers
Hi , what scooter is this for ?
for 24 volt systems( a larger number of mobility scooters ) ... remember lithium powered scooters can be different including the the charge voltage of 29 volt...
okay you wire run the batteries in serial configuration...
Posted on Jul 11, 2015
How do I wire two tandem batteries for an electric scooter
Tandem batteries... is a fairly loose term to be dealing with on batteries... SIMPLY BECAUSE THEY ARE EXPLOSIVE.
TANDEM voltage
(assuming you were trying to achieve 24 volts with 2
12 volt batteries would NORMALLY be called serial...
Where as to increase AMPACITY ... called "parallel."
Rather than risk severe burn, blindness (end of life
experimenting with EXPLOSIVES...
You need to go back to your source for better information ...
or
Provide better information here... Pretty please
Jan 12, 2017 | Electric Health & Beauty
I have inherited a Rascal Fold and Go 370 and have ordered two new replacement batteries to go in the battery case......however, my husband does not remember how the batteries are wired back in the ca
the batteries are wired in series, meaning two 6volt packs are wired nose to tail so they can deliver a full charge, OR they are wired so that both are in parallel, and each pack contains 1 Ampere-Hour of energy at 12 VOLTS and you use 2 packs to get 2 Ampere-Hours of "CHARGE". What your significant other has to get before he connects the wires back up , is a VOLTage METER to verify the polarity of the wires coming from the adaptor. It USUALLY is RED for positive, BLACK for negative........ but not always....... measure to be sure, then double check.
IF it is two 6 volt cells that are connected in Series, then the red of the first pack goes to the RED WIRE of the adaptor, then the BLACK WIRE of the first cell goes to the RED WIRE of the second cell and the BLACK WIRE of the second goes to the BLACK WIRE of the adaptor.
*Your mileage may vary, not intended to give professional advice, all actions are at your risk, Federal Deposit Insurance will only cover cash deposits at Federal Registered Banks. Colours may fade over time. Always call a friend when you need the answer.
Nov 24, 2014 | UPG 12V 18AH Rascal 110, 120, 370 Fold &...
I got my battery pack off my Gogo Traveller Elite scooter. But the batteries are encased in plastic and I don't see a way to get them out. Help?
Turn the battery pack up side down and you will see holes around the outside of the case. With a long (12") Philips screw driver, remove 8-10 screws. carefully turn the pack back on it feet and the lid will come off. Be careful with the wires inside the battery pack and make a note of where they go.
May 15, 2014 | Pride Mobility Products Go-Go Elite...
How to replace a battery in a waring pro wine opener
Replacing requires some soldering skills.
1. Remove two screws in bottom end and pull off the bottom sheath.
2. Remove six rubber plugs that camouflage six screws.
3. Remove the six screws. The opener will come apart in halves and the motor assembly may drop free but will still be connected so be a little careful. Take note of the orientation of the larger spring near the bottom and the positions of fittings that mate with the shell.
4. Unsolder two leads connected to the old battery pack and remove it.
5. Now you have options for replacing the battery pack. The pack consists of four Nickel Metal Hydride batteries connected in series.
a. Buy replacements (I didn't do this so I don't know if a pack is available that is already assembled). You might have to buy four same-size batteries and assemble the pack yourself. You can determine size by cutting the shrink wrap away from the battery pack to expose the actual batteries.
b. Buy standard AA (or AAA) cells, rechargeable (Nickel Metal Hydride) cells that are readily available everywhere.
6. (Unnecessary if you found a pre-assembled pack). Assemble a battery pack by soldering battery terminal to battery terminal such that all four batteries are in series. You can arrange adjacent batteries with a plus terminal and a minus terminal next to each other. You can make the four batteries into a pack by winding them with electrical tape.
7. (Unnecessary if you chose step 5A). Using a sharp knife or a Dremel tool, whittle away most of three ribs that are formed into the plastic shell. There are two ribs to do in one of the shell halves and one(+) rib in the other shell half. The (+) rib is near the connector block mounted under the operating switch and you can decide how much of it to whittle away also. The objective is to get the new battery pack to fit in the shell halves when they are re-assembled.
8. Solder the plus(red) wire and the minus(black) wire to the new battery pack -- those are the two wires removed in step 4.
9. Add padding if you desire to keep the battery pack from rattling around inside the shells.
10. Reassemble the shells and the bottom sheath.
11. Enjoy your wine.
Nov 20, 2013 | Waring Pro WO50 Cordless Wine Opener
Craftsman battery 300210
A negative temperature co-efficient (NTC) thermistor. A thermistor monitors the temperature of the battery pack during charging.
Oct 09, 2013 | Ace Hardware Power Glide Cordless Hedge...
Need to change the batteries in a Stanley bar flex light. lost instructions. how do you change the batteries.
I know this thread is old, but I just had to change the battery pack in mine. I could not locate a 4 pin battery pack so here's what I did:
You'll need: 3 NiMH 1.2v AA solder tab batteries, Razor blade, #1 Phillips driver, Kapton tap (standard electrical tape will do), soldering gun/iron, spare 18awg wire
1. Use a razor blade to remove the black sticker from the bottom of the flashlight base, it covers the magnets
2. remove the three outer phillips screws (the inner ones hold the magnets in and can stay installed)
3. Pull off the bottom plate
4. Pull out the battery pack and disconnect it from the flashlight at the 4-pin queeze connector
5. Remove the outer wrap and end protectors from the old pack keeping the end protectors in tact
6. Assemble the 3 new batteries in the same configuration as the old pack using Kapton tape, connecting + to - at the same two spots (use the old pack as a reference)
7. Carefully desolder the 2 wire leads from the old battery pack
8. connect up the 2 power wires to the same two spots as the old pack and insert the temperature probe between two of the batteries as in the old pack
9. Put the end caps on the new pack and wrap the entire thing in Kapton tape to simulate the plastic wrapper you removed
10. Install pack in to base, secure bottom plate and re-adhere black sticker(if needed you can use non-foam double-sided tape or spray adhesive)
The old pack was rated at 1300mAh and I used three 2000mAh each for a total of 6000mAh so theoretically the light should run for about 6 times as long between charges.
Aug 28, 2010 | Garden
I have a pride go go elite traveller 4 and need some new batteries, but what batteries and connection am i looking for?
Rachel you need 2 12/12AH batteries that are located in the battery pack under the seat. Simply pull the battery pack from the scooter and with a standard phillips screwdriver remove the many screws attaching the battery pack together (simply turn the pack over to get to the screws) There will be two wire on each battery and also a heat sensor attached to the side of one battery remove the wires from each battery and carefully reove the heat sensor. You can bring one of the batterys to your local battery warehouse type store or a provider and purchase 2 new ones reinstall like you removed attaching red wire to red terminals and black to black terminals and reattach the heat sensor to the side of one battery (you can use packaging tape to reattach). replace all the screws to put the case back together and reinstall in your scooter. Charge the batteries with you charger until the charge light is green then happy riding HOPE THIS HELPS
Aug 20, 2010 | Pride Mobility Products Go-Go Elite...
Dont know how to take master cylinder off to replace coil pack
You shouldn't have to remove it....here are the steps from the tech manual:
Removal & Installation
  1. Disconnect the negative battery cable.
  2. Label and disconnect the spark plug wires from each of the coil pack towers.
Ignition coil removal—2.4L engine
Ignition coil removal—3.3L and 3.8L engines
  1. Disengage the electrical connector from the ignition coil pack.
  2. Remove the coil pack mounting fasteners.
  3. Remove the coil pack from the vehicle. If equipped, remove the coil pack from the mounting bracket.
To install:
  1. Place the coil pack into position on top of the engine valve cover, or mounting bracket, if equipped.
  2. Install and tighten the coil pack mounting fasteners to 9 ft. lbs. (12 Nm).
  3. Plug in the electrical connector to the ignition coil pack.
  4. Connect each spark plug wire to each corresponding coil pack tower. The coil pack towers are numbered with the correct cylinder identification. Be sure that the spark plug wires snap firmly onto each coil tower.
  5. Connect the negative battery cable.
Jan 18, 2010 | 2001 Chrysler Voyager
My battery pack on my fold n go has a short and
hi, ok now you need to check your wiring within the battery pack ,
If there are two batteries, you need to make sure that negative wire of one battery connects to the positive of the other battery,
now use the postiive and negative battery connections to connect to the scooter , that will give you your 24volts,
battery 1 connects battery 2
== 24Volts
use the + of battery 1 & - of battery 2 to connect to the scooter.
Regards
GeWiz.
Oct 29, 2009 | ElectroVoice EV Rider FTCA020 Caddy Fold N...
Need an internal wiring diagram for the 14.8 volt battery pack.
check this link for more info about batteries and voltage
in your case you need to connect 4 pcs 3,7V batteries in serie. (wire between -battery+ -battery+ -battery+ -battery +
if you have 8 cells you connect like this
if this was any helpful please rate my solution.
May 29, 2009 | HP Pavilion ze5185 Notebook
Health & Beauty Logo
82 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
