No Signal S3 Video
No screen except for the aformentioned-not sure how to remedy
  • Anonymous Apr 19, 2015
    The input source should be Bell cable. In the white part of the screen it says:No signal Video3 Input. It does not work on anything nor any inputs given or offered!
    Top Expert:
  • Televison & ... Master
  • 43,020 Answers
Does it work on other inputs ?
Posted on Apr 19, 2015
How to turn it on
Samsung Galaxy S3: How to turn it on:
On the right side near the top you will find the power button.. press this down with your right hand finger for a couple of seconds until you see something happening on the screen.. then let go. The phone will power on:
>> While power on the phone make sure you don't do this:
Cradle the phone in your hand, be careful not to press the volume key.. doing so while holding down the power key will affect what the phone does..
Also make sure that your hand or fingers don't rest on one of the bottom (capacitive) buttons (these are buttons activated by touch) near the home button.. it can also affect what your phone does while holding down the power button
I will demonstrate turning on the Samsung Galaxy S2 which is similar to the S3 in the video below:
personalized video tutorial 16.9 MB:
Jan 24, 2016 | Samsung Galaxy S3
I got my unlock code from the carrier but my galaxy s3 still wont unlock. What can I do?
https://www.youtube.com/watch?v=hmQwEipEdFA
watch this video. you already have your unlock code so ignore the process until he explains how to put in the unlock code. Make sure you do it right because i think you only get 4 attempts at it.
Sep 20, 2014 | Samsung Galaxy S III S3 16GB AT&T
I have a Polaroid FLM-373B 37 " tv and I get a blue screen with "No Signal" in the top corner. Cant seem to get it to find a cable signal, dvd signal or anything. I have successfully...
That situation clearly indicates that no signal is coming to the set in its present setting. Have you checked to make sure that the tv's input is set on the right input setting. Mine always defaults to "Antenna" which drives me nuts cause I get that big blue screen with "no signal". It seems to do that at the slightest provocation, too. After 5 years, I still have to think twice before checking it. If that is not it, make sure that the cables are plugged in. If that doesn't fix it try another type of input such as HDMI or S video, composite, etc - one that you are not using. Don't forget to switch the input to it. Good luck!
Nov 06, 2010 | Polaroid FLM-3732 Television
My pc boots but no video is displayed so my only guess it the onboard video on the motherboard is faulty. can i buy another video card and remedy the problem?
You can indeed install another video card, but this may not be your trouble. Are you absolutely sure your computer is running normally except for the video? That is, do you hear all the other sounds that usually go along with normal startup (hard drive activity, Windows startup sounds through the speakers, etc.)? It's very unusual for a motherboard to fail so that everything works except for video out to the monitor. You might be facing a computer with some other issues, like memory or a deeper motherboard problem, causing it not to start.
If you do decide to install a new video card, be sure you get one that's compatible with the motherboard (proper type connector) and power supply (not a super whiz-bang card that may need more power than your current supply can provide).
Mar 27, 2010 | Computers & Internet
Signal interruptions on digital TV set
Weak signal is a weak signal, so not sure what if anything you can do. Buy a satellite subscription???
May 18, 2017 | Televison & Video
Screen goes blank except for a verticle streak
I had the same problem (blank screen, vertical line). After speaking with Garmin, I was told to make sure I was using the latest software version, and to turn off the WAAS function. Disable it for now, because the WAAS signal, coming from the satellite, has changed, and Garmin has not yet published a remedy to correct this problem. A fix should be out in a software update, sometime in the future, hopefully. I also did the software update, to the latest version 4.0. The unit performs perfectly now, however, the accuracy is not quite as good, due to the lack of WAAS. Good Luck!!
Nov 03, 2008 | Garmin GPSMAP 76S GPS Receiver
TV problem
  • it is 100% sure the problem is in red video output ckt only.
if you familiar with electronics please check the following.or call tech.
  • crt base for loose.
  • connector to crt base loose.
  • supply to red video output transistor ckt.& red video output transsistor.
  • components related to red video ckt.
  • red video signal coming to red video output frem processor.
  • hope this will help.
  • good luck.
Oct 17, 2007 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
