Question about Garden
Mower shut off while mowing and now has no crank or fire
  • Kprime
    Kprime Apr 16, 2015
    Hi Dawn Taylor, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Need Make/Model/Year/Engine Model/Transmission Model/Deck Size, and hours on meter will help determine wear patterns and issues of age vs new. If you haven’t already done so, add a short description of the events preceding the beginning of the problem.
    Sergeant:
  • Garden Expert
  • 187 Answers
Specific to your situation, since you were mowing when it quit and it no longer cranks, it does not sound like a fuel problem. Neither does it fit with an engine problem like valves, compression, or flywheel key. We can't rule out complications with these areas just yet, but, these are not the areas we want to start with. I will post details for checking the starting system.
If this all checks out, but does not resolve the problem then repost your question with updated details and I will go on to the next phase of diagnostics.
Your specific situation would cause me to check the
Fuse,
PTO switch,
Key Switch
Brake Switch.
Your machine does not have an oil level or oil pressure cutoff.
When I turn the key nothing happens.
There are several elements that go into cranking (turning over) the engine.
Battery
Fuse
Key Switch (and wiring)
Starter Solenoid and wires
Starter motor
To begin with check the fuse. It's a 20amp car style fuse located under the hood near the battery.
If the fuse does not fix the problem let's move on to the battery. The quickest way to make your initial check of the entire starting system and particularly the battery is to get a jump. Yep, get some jumper cables and jump the mower off your car. Turn the key and try to start it in the normal fashion. If it starts cool! It is likely a bad battery.
Charge the battery for a few hours, on a charger. Then perform a voltage measurement of the battery. Switch a volt meter to DC Volts and clip it to the battery. It should read between 12-13 volts. If not the battery is suspect. If it is 12-13 volts see if it will crank, but continue to watch the volts. If they drop below 10ish volts, the battery may have a bad cell.
Now let's check the starting system while bypassing all the safety switches and wiring. How? You can perform this test simply by jumping the starter solenoid. Hold a wrench or fat screwdriver across the two large posts of the starter solenoid. This bypasses the key switch and all safety devices and directly drives the starter. Your starter will crank if the battery and starter are good, the wires and connections are good, and the engine is not locked up. Don't crank it for more that a couple seconds. You just want to verify the battery and the starter are both in good shape. (The engine will crank but not start during this test if the key is off, or if the safety switches or wiring are damaged, or if the safety switches are in the no start/run positions.)
If the starter cranks try one more test. Run a small jumper wire from the positive post of the battery to the little terminal on the solenoid. You may have to take the small wire off the terminal, on the starter solenoid, in order to do this. When you apply this current from the battery to the terminal it should make the solenoid activate and the starter crank. This test bypasses the key switch and shows you the starter system is working. You could do this test first; if it works you do not need to do the basic jump test.
If these tests cause the engine to crank, but it will not crank with the key, then you know you have a problem somewhere in your starter wiring, safety switch system, fuse, or in your Key Switch. Of course you did check the battery terminals for good connection, right?
Most modern riding mowers have the following safety switches:
Seat switch
PTO switch
Reverse switch (RIS)and Reverse Relay(RIO)
Brake/Clutch switch
If you need detailed instruction for testing your wiring and safety system, I will need your complete machine info.
Make
Model
Year
Engine Model
Transmission Model
Deck Size.
On a John Deere (100 series) the starting current flows through the following items in this order:
Battery to Fuse then to the Key Switch.
With key switch in the start position,the current flows from the Key Switch to PTO.
With PTO off, current flows from the PTO to Brake/Clutch
With Brake/Clutch Pedal all the way down, the current flows to the starter solenoid.
If the Starter Solenoid is in good shape, the solenoid connects the battery to the Starter and the engine cranks.
Cranking does not mean running; it just means the engine turns over. Running is dependent on many other systems.
Those components are all part of the cranking/starting system. They can prevent the Starter Motor from cranking when you turn the Key Switch. You can trace the voltage with a multi-meter. Connect the black lead to ground and look for 12 volts on each successive step. If the voltage disappears at one particular step, there is your suspect.
Electrical elements that are NOT part of the starting system:
The RIO is the Reverse Implement Option. It is a switch that latches and stays latched under certain conditions. It is activated by the RIS. The RIS is the Reverse Implement Switch. It activates the RIO. These two separate components work to allow the blades to cut while you are backing up (without killing the engine). They have nothing to do with the starting system.
The Seat and the RIO (the reverse latch not the button) switches are tied into the engine kill system. They provide a ground path for grounding the Coil. This same system controls the fuel shut off valve beneath the carburetor. The Seat and RIO can keep the engine from running but they will not prevent the Starter Motor from cranking. Therefore, if you turn the key and nothing happens, the problem has nothing to do with the Seat and Reverse switches.
Note: With the Key in the RUN position, power flows from the Key Switch to the Hour Meter, then to the RIO latch relay (not the RIS button), then to the fuel shut off solenoid. If you do not hear the Fuel Shut off Solenoid clicking on and off when you turn the Key Switch from off to run, there may be a problem in this circuit; including a possible problem in the Hour Meter. Of course none of this affects the cranking circuit. Your engine will still crank, it just won't run.Mower shut off while mowing and now has no crank o - 0c82e2b5-5ccf-4328-9160-a0f7468cc1e1.jpg
Posted on Apr 16, 2015
  • toriless Apr 17, 2015
    If it were thr Solonoid starter or battery it would not even start. A starter does nothing after the engines is running, if the solanoid was bad it simply not run at all, and a battery would fail duringstart which drains it and not in the middle of operation while it is rechagring from the excesss electricity egnerated, A bad fuse could easily be involved andthwey shoud definately start there and bad switches and loose wire definately could cause it to happen. However, if it now refuses to start at all I either the battery could be old and no longger holding charge or the starter is often bad. Just like a car listen for the clicking noise when you turn the key. If you hear that th solanoid is good. You do not need to to any cimplicated test if you hear that clicking noise. Similarly, if it click but doe not "turn over it is probabyl a bad starterr motor, if it turn but does not stay running only then is it a fuel or switch issuefuel issue. Personally, I'd suspect the solenoid but some vrhicles require you replace whole starter to replace it. I have not checked if that is true in your cae but you can so do IF you determine it is bad. P.S. - Any cheap volt meter is good enough to check the battery, also if the voltage drop a huge amount while starting thta indicates a problem as well as just while the key is on and it is below 12V.
  • Behind_Blue_Eyes
    Behind_Blue_Eyes Apr 28, 2015
    Dude, leave the books at home. You just blew this poor guy away...
    Sergeant:
  • 290 Answers
You did check for gas first? I assume it is gas driven since it is a rider mower. Also, check the oil level. Mowers and generators often have an auto shut-off if the oil level is too low and will refuse to turn over even when otherwise properly gassed and throttled.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
Died... why ?
well lets see here... nope. didn't mention brand of mower OR the engine
a battery wont make it die but will keep it from cranking.
a safety switch will make it die
a pto switch can make it die
a pto switch engaged will also make it not crank
no model/brand info can't help much more
Posted on Apr 28, 2015
My craftsman ys4500 21hp riding lawn mower cranks but won't fire and I have tried everything
Have you pulled a plug and checked for fire? There is a huge difference between crank and no fire or crank and no start. If you have spark, make sure air filter is clean. Next step make sure you have fuel to the carb. After that the carb would be the next step. Have it cleaned and rebuilt.
Jul 18, 2016 | Craftsman Garden
Mower shuts off when brake lever is released down to mow
sounds like a bad switch. unhook and check them (seat brake and deck)
May 29, 2016 | Garden
My mower backfires when I turn it off after mowing.Why?
it sounds like the electric fuel shut off on the bowl of the carburetor is not working properly.
May 17, 2016 | Garden
I do I disengage the clutch
Sounds like the bolt to your clutch/brake pedal may have fallen out so that it no longer engages the safety switch that is required for the motor to crank over.
Aug 05, 2012 | Garden
John deere 717a shut-off while mowing
Mine took a Poo this evening. It's a 717A Z turn and it's run just fine for 4 years but tonight it kinda Popped (like something broke) while under a slight load and then shut off. Oil level was slightly low and curious if I blew the engine. It still cranks just fine but won't fire off? Acts like it's not getting fuel but the filters are all clear and fuel flows. It's my Church's mower and the Blue hairs are gonna kill me if I blew the engine.............I'm toast!
Jul 30, 2012 | John Deere Garden
My 1976 sears 18 hsp riding mower quit running now it just cranks but won't fire it has a onan engine
check for spark then spray a little carb cleaner or starting fluid in the carb if it fires its a fuel problem filter pump carb
Apr 10, 2012 | Craftsman Garden
17.5 hp in a riding lawn mower.mowed grass, shut-off now when cranking only back-fires
Could use a little more info.
But sounds like it could be many items, so lets start from the beginning.
Age of unit.
Do a compresson test to check to see if a valve is stuck open, if not Sounds like a broken sheer key or a bad magneto.
Aug 10, 2010 | Sport & Outdoor - Others
Was mowing with riding mower was running fine started missing and black smoke coming out of exhaust stopped mower immediatetly oil in carb now and when try cranking it just cranks and cranks not firing
Pull plug and check compression. When cranking see if bottom pulley turns from engine. If compression is below 90 psi it won't start and you have an internal problem. Stopped mower immediately sounds like motor blew. Also check side of motor for cracked block, Good luck.
Mar 21, 2010 | Briggs & Stratton Garden
CH25 Kohler on a Kees mower. Back fires under light loads
you must have the throttle at full at all times when under load driving and mowing, back fire is do to much fuel. if your running throttle at full than look at the carburetor and then the wiring (short)
Oct 12, 2009 | Garden
Garden Logo
283 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
