Question about PfaFF Sewing Machines
My pfaff 1222E has a broken / cracked cam on the underside of machine. How do I replace this?
Pfaff 12223 Cam on Bottom of machine
  • PfaFF Master
  • 1,860 Answers
You'd have to check with a Pfaff dealer about getting the cam for the machine
Posted on Jun 16, 2015
  • 632 Answers
SOURCE: lost instruction manual
ebay
Posted on Jul 17, 2009
  • 632 Answers
SOURCE: PFAFF 1222E Sewing Machine (~1977). Mechanically Locked-up
You might be in "Stopmatic" mode. Check if your pressure lifter bar is in the upper most position, if it is the machine is disengage and you are set to wind your bobbin. Lower it to the 3 o-clock position this will engage the machine and the needle will operate.
Posted on Aug 10, 2009
Sewtech1
  • 69 Answers
SOURCE: My Pfaff 7550 sewing machine will ball-up thread on underside
Make sure your tension is set on 5 and you don't have dirt stuck in your tension unit.
Posted on Jan 20, 2010
  • 632 Answers
SOURCE: I need a service manual for Pfaff model 1222e
You can download it from PFAFF service manuals in PDF formats. It may not mention an E or an SE after the model #1222 because the difference is just the motor rating and different feet it came with, the rest are all the same.
Posted on Feb 06, 2010
  • 1788 Answers
SOURCE: loose stitching on underside of
It is in your top threading, believe it or not. Sounds odd but it is. Try this, insert a new needle (flat side facing the rear of machine), totally rethread according to your manual or go to www.sewusa.com for a free threading diagram, make sure that your presser foot is up, now when you are totally threaded, with the presser foot still up, pull on the top thread, it should feed smoothly, put the presser foot down and pull the thread again, it should barely move. This should seat the thread in the tension discs. If that doesn't do it, I am afraid that you may need a repair shop. Good luck.
Posted on Jan 28, 2011
Pfaff 1222 part
Search for:
Pfaff 1222 parts
(may find it on eBay or some online sewing machine vendors)
Foot Control Pedal 90 222040 08 For Pfaff 1212 1221 1222E Sewing Machines...
Aug 01, 2017 | PfaFF Sewing Machines
Where are the oil holes in a pfaff 1222e sewing machine
There are no oil holes in a 1222e. I apply a light oil to the inside of the bobbin case and where you clip the bobbin in the machine. I also take off the top and drop a light oil on the moving shaft. I was told no other lubrication was needed by the owner.
Jan 26, 2011 | PfaFF Sewing Machines
I need a needle threader for my Pfaff 1222E the hook is broken so am looking for replacement
Contact Ron at ron@a1sewingmachine.com. He should be able to help you.
Sep 12, 2010 | PfaFF Sewing Machines
Pfaff 1222E machine not working right
Skipped stitches means a bent or dull needle or improper needle for the fabric being sewn. Try a new needle of the correct type for the material being sewn. If this doesnt correct it, then it will be a timing or needle to hook problem and should go to a qualifed dealer for repair.
May 06, 2010 | Sewing Machines
Feb 01, 2010 | PfaFF Sewing Machines
Can you get me a Pfaff 1222E motor please? Th
You will need a Pfaff dealer or go direct to the manufacturer or even go on ebay and try and purchase a similar model which may be cheaper thanh a new motor and you can then swap motor over.
Jan 31, 2010 | PfaFF Sewing Machines
Sewing Machines Logo
97 people viewed this question
Top PfaFF Sewing Machines Experts
SewTechWayne
SewTechWayne
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
