Question about Microsoft Windows Vista Home Premium with Service Pack 1: Windows
Windows vista boot system
Quick easy boot up to start screen
    Top Expert:
  • Microsoft Master
  • 10,875 Answers
Yup
Posted on Apr 16, 2015
Automatic restart my laptop.Windows vista
If you are able to boot the computer in safe mode, you can disable the Automatic Restart from the Control Panel.
Open Control Panel.
Click on the System and Maintenance link.
If you're viewing the Classic View of Control Panel, you won't see this link.
Click on the System link.
In the task pane on the left, click the Advanced system settings link.
Locate the Start up and Recovery area and click on the Settings button.
In the Start up and Recovery window, locate and uncheck the check box next to Automatically restart.
Click OK in the Start up and Recovery window.
Click OK in the System Properties window.
You can now close the System window.
From now on, when a problem causes a BSOD or another major error that halts the system, the PC will not automatically reboot. Rebooting manually will be necessary.
If you're unable to fully start Windows Vista due to a Blue Screen of Death error, you won't be able to disable the automatic restart on system failure option as described in the steps above.
Try the steps below:
Just before the Windows Vista splash screen shown above appears, or just before your PC automatically restarts, press the F8 key to enter Advanced Boot Options.
You should now see the Advanced Boot Options screen.
Using the arrow keys on your keyboard, highlight Disable automatic restart on system failure and press the Enter key.
After disabling the automatic restart on system failure option, Windows Vista might continue to load. Whether or not it does depends on what kind of Blue Screen of Death or other problem Windows Vista is experiencing.
Since you disabled the automatic restart on system failure, Windows Vista will no longer force a restart when it encounters a Blue Screen of Death.
Now that you have the STOP Code associated with the Blue Screen of Death, you can troubleshoot the problem:
The following is the list of BSOD error codes with troubleshooting, you can find the troubleshooting steps using the error codes in the MS website also..
http://pcsupport.about.com/od/findbyerrormessage/tp/stop_error_list.htm
Hope this helped you. Please do rate me.
Thanks!!!!
Dec 21, 2010 | Computers & Internet
Tip
Slow boot of the computer
if your computer is booting very slow and your operating system is XP / VISTA / WIN 7 dont get frustated//
here is the quick solution
1) xp computer---click start/ run/ type msconfig/ ok/
system configuration window will open//
goto startup / hit the tab disable all at the bottom// apply//
go to services and at the bottom put the check on the box which says " hide all microsoft services" then click ok or close to close the system configuration window and restart the computer and it will boot very fast .
when the computer boots up you will get the window of system configuration and at the bottom put the check on the box which says "do not show this msg again".
note** vista and win 7 user will have to follow the same steps.. just type the command " msconfig" in the start seargh which appears at the bottom when you click the start button.
on Jun 10, 2010 | Computers & Internet
Tip
Install Windows 7 or Windows Vista on a Pc Without DVD Media
For user who doesn’t want to waste a DVD disc to burn the ISO to physical media, and does not have WinPE (Windows PE) startup disc, here’s a workaround method to install Windows Vista and Windows 7 into physical computer’s hard disk drive or partition (volume) directly with ISO without writing or burning to disc. The without-disc installation method is useful especially during beta and RC period of new operating system in the making, where the new build and new versionis launching and publishing every now and then. This tutorial guide assumes that the new Windows 7 or Windows Vista will be installed and replaced the original existing operating system currently installed. The instructions can be modified slightly (mainly on hard disk partition used) to fit into need of readers who want to have a dual-boot, multi-boot, or simply just to upgrade install to new OS.
1. Install a virtual CD/DVD drive on existing Windows operating system.
2. Mount the Windows Vista or Windows 7 installation DVD ISO image using the virtual drive.
3. Copy all files inside the virtual CD/DVD drive mounted with the ISO into any folder on any partition or hard disk drive not going to be used to install the Windows OS. For example, copy into E:\Windows7.
4. Copy the bootmgr and boot folders nested inside the copied folder (i.e. \Windows7) to root directory of system boot drive, typically C:\.
Note: For Windows Vista, users may need to use this step: Copy the bootmgr folder from E:\Windows7 to C:\ root directory, copy E:\Windows7\boot\boot.sdi file to same folder in C:\boot folder, and then copy bootsect.exe from the E:\Windows7\boot\ folder to C:\ drive.
Note: boot folder in system boot drive is hidden system folder.
5. Create a new folder named sources under the C:\ root folder.
6. Copy the boot.win file inside \Windows7\sources folder to the source folder created in the system boot drive, normally C:\.
7. Open a command prompt as administrator.
8. Run the following command (change the C to your drive path letter if applicable):
C:\boot\bootsect.exe /nt60 C:
For Windows Vista users who copied bootsect.exe to C:\ root folder, use the following command instead:
C:\bootsect.exe /nt60 C:
A successful message is the command completes successfully.
9. Change the name or label of the boot system partition local disk to BDCP or any name you prefer that easier to remember and type (in DOS command promot, use label command).
10. Restart the computer.
11. After booting up, the system will start the corresponding Windows installation process. Select the applicable language to install, time and currency format (regional settings locale) and keyboard or input method in the installation wizard dialog.
12. On the next screen, user will be presented with option to Install Windows. DO NOT press on Install Windows button, instead, click on Repair My Computer link on the bottom left corner.
13. In the Windows Recovery Environment (WinRE) System Recovery Options dialog window, click on Command Prompt to open a DOS Prompt window.
14. Run the format command to format the primary hard disk or partition to clean state:
format c: /q
Note: /q switch, which perform quick format can be omitted to full format. And if existing hard disk partition is of FAT32 filesystem format, use format c: /q /fs:ntfs to convert the file system to NTFS while formatting. Before formatting begins, the command may prompt for hard disk drive or partition label name, if so, enter accordingly (i.e. BDCP).
15. After format completed, start the Windows Vista or Windows 7 installation process again by manually running the setup.exe located in the copied. Note that the setup.exe is not the one located on boot system drive which copied at later step, as the boot drive has been formatted. For example:
E:\Windows7\sources\setup.exe
16. Continue with installation procedures by following on-screen instructions as per normal practice.
on May 19, 2010 | Computers & Internet
How to reformat the computer?
To reformat the windows vista.There are two options to approach the reformat:
  • Option #1: Boot from the Windows Vista DVD. This is more complicated to do, but it destroys all data and partitions.
  • Option #2: Re-install Vista without leaving the desktop. This preserves the previous installation in a folder called Windows.old. Not all info is wiped, however, and you can't destroy your partitions.
First, restart your system. When the computer starts to boot, look for an option before you get to the Windows screen that reads: “Setup” “CMOS,” or “Bios”. This varies between manufacturers. For example, on the boot screen, it says:
“F2 =Setup”.
The option will flash by quickly so be ready for it and react quickly. You may need to reboot a few times to catch it.
Once in the BIOS, look for a setting that says "Boot" or "Boot Sequence". You might have to dig through the menus with your keyboard’s arrow keys to locate the setting. In the listed as Boot Sequence. And to navigate to Startup, then Boot, and then Boot Priority Setting.
When you find the setting, change your DVD drive so that it occupies the top of the list. The hard drive that contains Windows Vista should be listed as second in the boot list.
And put the Windows Vista installation disc in the designated drive. Now, select the Save Changes and Exit option in the BIOS. The computer will restart and will attempt to read the optical drive you just assigned as the first bootable drive.
The system will use the Windows Vista disc to boot and the reformat and reinstall process will start. But You will need to reinstall any programs that are not bundled with Windows Vista and reinstate your preferences and personal files after reformatting the computer and reinstalling Vista.
Windows Vista Home Premium Edition upgrade Click here.This downloadable version of Windows Vista is an upgrade only. Users can upgrade to Windows Vista Home Premium from Windows XP Home or Windows Media Center edition.
All the Best!
Sep 05, 2010 | Microsoft Windows Vista Home Premium...
Black screen just before login
Just boot your vista setup dvd and select repair option from the setup menu .... your problem will be solved... dont have to worry its just corrupt in your logon files its easy to recover.
Jul 19, 2010 | Microsoft Windows Vista Home Premium with...
How to dual boot xp and vista?
First of all partition a drive up. Make sure its a large capacity drive, something well over 100GB.
Boot the computer with CD/DVD set as the first boot device and pop the XPmag-glass_10x10.gif CD in the drive and allow setup to begin. When you come to the screen where you select the drive partition you should see the drive listed with all the space listed as unpartitioned. If the drive was in use previously, you'll need to delete all the existing partitions. To do this you'll have to hit the 'D' key followed by the 'L' key. The screen instructions will be visible to guide the process.
Once all the existing partitions are deleted the display will show the total unpartitioned disk space.
Hit the 'C' key to create a partition. Personally i partion mine to 80GB (81920MB)
On the newly created partition, (not the raw one) install XP on that. Carry on with the installation until its final restart, it will be a light blue screen.
Quickly pop the Vista disk into the drive and start the Vista install. When it askes where you want Vista choose the unallocated partition. If you let XP load up first then you will not have the dual boot option on start up.
If you have done this correctly then each time the computer restarts during Vista install you see a boot message on screen saying "older version of window(XP) and Vista.
Lets Vista fully install right up until it loads the welcome screen. Then you can restart the computer, choose older version of windows to complete and load the XP operating system.
You then have to switch between them both to install drivers, software etc.
If you want to use both operating systems at a time then you need a virtual operating system installed but they are not that good as memory is kept at a minimum.
Good luck and please post back if you need anymore advice.
Regards.
Jul 15, 2010 | Biostar MCP6P-M2 Motherboard - v6.0,...
I want to convert windows vista to xp but not succes. windows vista boot easy but windows xp i couldn't in my hp G-60 laptop. how it do
You jave to do a clean install, simply put the xp cd in the cd/dvd drive and reboot the computer, please make sure that your cd/dvd drive is the first option on the boot priority. Normally you find these setings in the bios(setup) and you have to press a button when the computer start. Normally they write on the screen : press "(the button)" to setup.
Hope that helps
have a nice computing
Please rate my answer
Nov 14, 2009 | Computers & Internet
How to unlock screen for vista
Click Start, type msconfig in the Search field and press . After you click through the UAC prompt, a system configuration window will open. Select the Boot tab.
In the Boot tab, check the box marked No GUI boot. Click Apply and click OK. Windows will prompt you to restart the PC so click Restart.
Nov 07, 2009 | Microsoft Windows Vista Home Premium with...
How to install windows xp on preloaded vista
If you have Windows XP OS installation CD, just put it in and boot your computer.
Leave the system till it comes to a blue screen. Choose to install a new OS and follow teh on-screen instructions.
Choose to format the C drive if you wish to delete Vista and the data in you C drive. Proceed with the instructions and you will be able to install the OS.
Hope this helps!
Mar 29, 2009 | Microsoft Windows XP Professional With...
2 operating systems
The Boot Configuration Data (BCD) store contains boot configuration parameters and controls how the operating system is started in Microsoft®Windows Vista.
Remove Windows Vista From Dual Boot System Windows Vista works slightly different from earlier versions of Windows when installed on a dual boot system, in that it has a completely different boot loader.
When Windows Vista is first installed as a dual boot operating system a new boot folder is added to the root directory of your PC. This is a hidden file and therefore is not noticed. When you boot your PC a menu appears with the following options:
  • Earlier versions of Windows
  • Windows Vista
Clicking the Windows Vista option will boot the PC into Windows Vista. If, however, you select the earlier versions of Windows option, another menu will appear from which you can choose Windows XP or whatever earlier version - Windows 2000 or Windows 2003 server - you installed first.
Because of this new boot loader it is not as easy to remove Vista from a dual boot system scenario. Simply deleting the Vista partition will, of course, remove Windows Vista, but, unfortunately, it will not remove the Windows Vista boot loader. For this reason, if you simply delete the Windows Vista partition, on rebooting your machine you will not automatically boot into Windows XP (or an earlier version). Instead you will once again be presented with a menu from which you have to choose which operating system you wish to boot to.
Obviously, once you have removed the boot loader and rebooted the Vista operating system will still be on the partition you originally installed it on. To remove Vista completely you will need to Delete the partition that Windows Vista was installed upon.
To remove this menu, or more to the point, the boot loader, proceed as follows:
1/ Boot the PC to Windows Vista
2/ Ensure you are logged onto the Internet and then download the freeware boot loader utility VistaBootPro (www.vistabootpro.org)
3/ Once you have downloaded VistaBootPro, install it on your machine
4/ During Install VistaBootPro will install an icon on your desktop
5/ Locate the VistaBootPro icon and Right Click on it. Then, from the drop down menu, Click on the Run As Administrator option
6/ User Account Control (UAC) will pop up and ask for permission to run the program
7/ After you have given UAC permission - you must be the administrator or have administrator privileges - VistaBootPro will run.
8/ Once VistaBootPro opens, Click on the Bootloader tab
9/ In the Bootloader Maintenance section, Click on the Radio button next to the option marked 'Uninstall the Vista Bootloader (Used to restore Legacy OS) option' and then Click the Apply button
10/ Finally Reboot your PC
11/ On rebooting your machine you will boot directly into Windows XP (or an earlier operating system). No menu will appear.
12/ All that is left to do now is to delete the partition which originally contained Windows Vista. (Assuming you wish to remove the Vista partition from your hard drive).
Sep 12, 2008 | Acer Aspire 3680 Laptop
Microsoft Windows Vista Home Premium with Service Pack 1: Windows Logo
54 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
