Question about Rinnai Heating & Cooling
My rinani 85 heater has not been used for couple years, now I go to start and ithe burner will not fire, I can hear it make some noise like it is going to fire up but nothing?
  • 494 Answers
Here is the Rinnai website to look up your model's manual, so you can go thru the trouble shooting section or call them directly for help. Your particular model # will start with either a "C" or an "R". http://www.rinnai.us/customer-care/manuals-literature
Posted on Apr 18, 2015
2 Suggested Answers
  • 674 Answers
SOURCE: My Reddy heater torpedo multi fuel heater won't
Remove the top cover and rotate the fan by hand. If should turn pretty easily. If not may you can put some oil where the shaft passes through the ends otherwise you will need a new motor. If the fan turns easily then the capacitor is probably shot. I don't know if you can get the capacitor seperate from the motor or not. There is a small low pressure compressor attached to the back of the motor. Your problem may also lie in there. The covers come off easily so you can check it out.
Posted on Dec 30, 2010
I can get the pilot light to stay on but main gas burner won't fire up
If the pilot is lighting and the thermo couple is in the fire and turned red and the pilot still does not stary on change the thermo couple. They are available in any home improvment store.
Nov 04, 2014 | RTO Suburban Rv Water Heater Dsi Gas Valve...
Weil McLain Clicks and then burners shut down
it needs a new thermal coupling ,this tell the gas valve to open if it goes bad your heater shuts off for safety reasons.
Nov 29, 2012 | Watches
I have turbo CG4TDBRN and It stoped working. I used to push in the knob and hear clicking and the fire would start. now no clicking no fire. the Rotiserie went out a couple of years ago and I would like...
Some igniters need batteries. Try calling the company and asking them. They might also be able to sell you a replacement igniter. In the mean time you can always start the grill with a long lighter or by lighting a stick and putting it near the burners before turning on the gas.
Jun 05, 2011 | Barbeques Galore Turbo STS 4-Burner with...
Remote controlled gas log fire will not ignite,relaced batteries,cleaned logs etc,worked a couple of times then refused to ignite again ,can hear ignition ticking but cannot hear any gas coming through ,...
If you're using propane gas, the banging noise you hear is air in the gas line, which means either your tank is empty or the the tank regulator is frozen (if it's ,below freezing in your area). If the tank regulator is frozen, soak a bath towel in hot water and quickly place it around the regulator. It should thaw fairly quickly and the gas will start flowing again. However, you may need to purge the air out of the gas line to gas log burner. Rather than using the electronic ignitor, do it manually, until you smell gas, left off the control knob and wait 5 minutes and then try lighting the pilot electronically.
If you're using Natural Gas, it may still be a pressure problem to the burner. You'll need to have that professionally checked.
Hope this helped to solve your problem.
Feb 27, 2011 | Heating & Cooling
My 9 year old Sta Rite SR400NA pool heater starts normally, but about 30 sec. after the burner fires, it makes a loud noise (ca-chunk) and shakes several times. At that point, I can hear the burner go out...
Your "bypass valve" is open and the water in your heater is boiling. Close the valve at least 1/2 way (or more) , which will force water through the heater and restore operation. The bypass valve is located on the pipe leaving the filter just past the first tee.
Oct 26, 2010 | Sta Rite SR400NA Max E Therm Pool Spa...
Pilot lit clicking noise no burner
make sure knob on gas valve(inside heater)is turned to on position.3/4" should be fine as long as heater is not larger than than 175,000 btu
Jul 14, 2009 | Jandy Lite 2 Natural Gas Pilot Light...
Have a 85 f-250 diesel that won't start
7.3 diesel i assume?i had one years ago and the controller for the glow plugs went bad,couldnt heat up the fuel enough to ignite,or the injection pump went bad or is out of timing
Apr 25, 2009 | 1985 Ford F 250
Heating & Cooling Logo
128 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
