Question about Panasonic Lands Phones
KX-TG7644m Phone system. Display says "line in use"
There is no dial tone and no phones are in use
    Top Expert:
  • Panasonic Master
  • 10,875 Answers
Press off 2 times
Posted on Apr 19, 2015
SOURCE: avaya phone not working
Yes, check the wiring. Sounds like the blue pair isnt working at that jack.
What happens when you plug that phone into the extension port of the system?
Posted on Sep 17, 2008
SOURCE: panasonic cordless phone #KX-TGA931T
For the speakerphone switching phone off problem, substitute the 630 mAh Ni-MH battery that comes with the phone with a better Ni-Mh battery of higher mAh such as Duracell or better yet eneloop.
Posted on Apr 18, 2009
SOURCE: I pick the phone up, no dial tone. Display says
We called the phone company.....There was a problem up on the telephone pole. They fixed it, no charge.
Posted on Jan 25, 2010
SOURCE: Panasonic KX-TGA601CB cordless phone Was working
phone says move closer to base
Posted on Jan 28, 2010
Phonesmith
  • 113 Answers
SOURCE: Panasonic KX-T7433
These phones are digital proprietary telephones which means that they only work on panasonic telephone systems and not on normal analog lines. If you have a panasonic system the correct way is to plug the line into the " To Main Unit ", the handset into " Handset/Headset" and a normal analog phone into " To Tel ". If the wiring on the line jack was not done digitally the phone will also not work
Posted on Mar 19, 2010
Testimonial: "Thanks Heaps Buddy"
How do I intergrate a KX-TD 7896 into existing phone system?
Take one of the existing extensions on the system and listen with a normal telephone if you get Dial tone...Then if you do Plug in your Cordless phone and listen if you do get it then... If not..most probably the cordless is faulty.
May 27, 2014 | Panasonic KX-TD7896 Cordless Phone
Dial tone on speaker-phone but no dial tone on line 1
Either button mapping or no dial tone at the system cabinet. If your desplay sas CO1 and you have no dial tone, go to the sytsem cabinet ans swap the modular plugs for CO1 and CO2. If the No Dial Tone moves, "mus be sumpin wrong wit yo lines".
Carl
Aug 13, 2010 | Panasonic KX-T7730 Corded Phone
Returned home from vacation. Had been lightening
panasonic KX-TG5632
No dial tone ,no link to the base,move closerto base,try again
Dec 02, 2009 | Panasonic KX-TG5431 Cordless Phone
Can not get kx-t7885 to get a dial tone. The phone is paired with it's base, and will get the panasonic dial tone but not an outside line.
How are you trying to get an outside line? By dialing 9? If the host system happens to be a TA series, you have to tell it how many lines you have, or that you don't have lines that have hardware ports but no dial tone, since systems select outside lines from the top down.
From System programming, program 400 defines connected lines.
Carl
Nov 22, 2009 | Panasonic KX-T7885 Cordless Phone
Line in use not going from phone display kx-tg2432al
my line in use light will not stop flashing and i don't have a dial tone
Oct 06, 2009 | Panasonic GigaRange KX-TG2432 Cordless...
Need to change phone back to tone dialing
Here's what the manual says: Changing the Dial Mode (Tone or Pulse Dialing) (HS1 only) Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most phone networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, follow the steps below to modify your phone?s settings: With the phone in standby, press and hold [cid/menu]. Press [vol/ / ] to move the pointer to select DIAL. Press [select/channel] to set the phone to pulse dialing. Press [end]. Return the handset to the base. The handset communicates the new setting to the base, and the base activates the setting on any other handsets. Hope this helps out. K
Jun 05, 2009 | Uniden 2.4 GHz Cordless Phone System
Panasonic KX-FM220 fax machine does not have a dial tone
is your line provider ok.connect your line to ordinary phone to check if there is really a dial tone from the line provider.if there is a dial tone please let the analog board be cheked by a technician near you
May 01, 2008 | Panasonic KX-FM220 Plain Paper Thermal Fax
Panasonic KX-FM220 fax machine does have a dial tone
I would double check your phone cord. There is usually 2 jacks in the back of the fax machine. 1 is for Line, and 1 is for phone.
Your phone cord should be hooked up in the LINE jack that goes to the wall.
I would also double check your phone cord on another phone to make sure the cord is good.
If you look at the clear connector that you plug into your wall and fax machine, does it have 4 copper/gold color wires contacts imbedded in the clear plastic connector?
Another thing to try, if you fax machine has a Line and a Phone connector, try plugging in a phone in the PHONE connector. Then hook up another phone cord going from the LINE to the WALL jack.
If you get a dial tone on your Phone, then you know you have it connected correctly. If no dial tone, then I would go back to the phone cord.
check those things and get back to me and I will see if I can help you with more suggestions.
Good luck.
Mac =)
Phone cords
With the lines lit on the phone, it's indicating an off-hook condition or no battery from the line. Check the lines for dial tone at the demarc to determine if it's phone company problem. Thank you. Jer
Feb 18, 2008 | Panasonic KX-T7730 Corded Phone
Lands Phones Logo
54 people viewed this question
Top Panasonic Lands Phones Experts
john milligan
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
