Question about Sharp Royal Alpha 9155SC Cash Register
Reciept side ink not printing
Very light ink not ledgeable
    Sergeant:
  • 290 Answers
Need a new ink cartridge. Just like any printer they do not last forever before it needs changing and faded ink is classic sign that is the case. Skipped spots but good darkness would indicate some thing is dirty instead but that is not your situation.
Posted on Apr 16, 2015
Hi, i have a CASIO SE C2000. The ink is not printing on the reciept. I do have the right till rolls but it just stopped printing. Any ide why?
If it is feeding the paper but it is blank, then you may have the paper around the wrong way. the shiny side must be towards the front. Otherwise, it may not be thermal paper. If it is not feeding out at all, make sure it has not been turned off (paper saving)
Jul 15, 2011 | Casio Parts Cash Register PC Desktop
Epson 9600 magenta won't print - have new cap assembly installed
The ink should come out of the cart. if not the cart is the problem at this point try anothere magenta if that does not shore it up then you need to then start looking at the print head where it goes it itself now the store you bought the ink from will give you a replacement no questions asked sometimes even if you dont got the reciept. Try those steps you be glad you did.
Apr 23, 2009 | Epson Stylus Pro 9600 InkJet Printer
Can't find ink storage
look at this
Details Issue: How do I replace or insert an ink tank?
Solution: Install the Print Head and Ink Tanks - MP620 / MP620B
  1. Open the Paper Output Tray (A), then lift the Scanning Unit (Cover) (B) until it locks into place.
    The Scanning Unit (Cover) (B) is fixed automatically.
    The Print Head Holder (C) comes out. (This is where you install the Print Head.)
    Note : Close the Document Cover (D) and lift it with the Scanning Unit (Cover).
  2. Raise the Print Head Lock Lever (E).
    i_expl.gifCaution : Firmly raise the Print Head Lock Lever until it stops. (The Print Head Lock Lever may feel heavy.)
    i_note_e.gif Note : If the Print Head Holder does not move, make sure that the machine is turned on.
  3. Remove the Print Head from the silver package.
    i_expl.gifCaution : There may be some transparent or light blue ink on the inside of the bag the Print Head comes in, or the inside of the protective cap - this has no effect on print quality. Be careful not to get ink on yourself when handling these items. Be careful not to stain your hands.
  4. Remove and discard the orange protective cap.
  5. Tilt the Print Head and set it in place. Lower the Print Head Lock Lever (E) completely.
    i_expl.gifCaution : Do not knock the Print Head against the sides of the Holder.
    Be sure to install it in a well-lit environment.
    Pinch the Print Head Lock Lever firmly and lower it gently.
    Once you have installed the Print Head, do not remove it unnecessarily.
Install the Ink Tanks
  1. Pull the orange tape (1) in the direction of the arrow to peel off the protective film and remove the film (2) completely.
  2. While pressing down with your left thumb, twist off the orange protective cap (A) located on the bottom of the ink tank.
    i_expl.gifCaution : Do not hold the sides of the ink tank; ink may splash.
  3. Install the Ink Tank
    Press the PUSH mark on the ink tank until it clicks into place.
    Make sure the Ink lamp lights red.
    i_expl.gifCaution :Be sure to install it in a well-lit environment
    i_important.gif Important : Match the labels when installing.
  4. Install all the other ink tanks in the same way.
    Install all the ink tanks.
    i_expl.gifCaution :Once you have installed the ink tanks, do not remove them unnecessarily.
    i_important_e.gif Important : Make sure all the Ink lamp lights red.
  5. Close the Scanning Unit (Cover) (B).
Mark
Apr 16, 2009 | Canon PIXMA MP620 All-In-One InkJet...
Blinking teardrop light blinking
Blinking drop light on HP6122 signifies an ink cartridge is out of ink. There are two cartridges -- color (larger of two) and black (smaller of two). Blinking drop light only indicates either, but not which. HP6122 service software and print driver are available from HP website http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=83027&lc=en&cc=us&dlc=en&lang=en&cc=us. HP6122 service software has a printer maintenance utility which includes ink cartridge monitor. Use the maitenance service utility to determine which (or both) cartridge is out of ink. With cartridge replacement, printer should automatically print test page, then reset and be ready for printing from your computer. To clear printed documents from print que, open the HP6122 print que via control panel > printers > double-click on HP6122 driver to show que > select document tab > select cancel.
Mar 26, 2009 | HP DeskJet 6122 InkJet Printer
Color printed copy appeared unbalance, one side is light.
Please do the following
1) Take the Ink cartridge out and shake it well.
2) Wipe the print head with a tissue to eliminate all dried ink particales.
Once dont please insert the cart ridge again and try printing
Please rate the fix
Feb 14, 2009 | Xerox WorkCentre M-24 Color Copier
Print reciept
please refer the followsing link
http://www.sharpusa.com/files/cas_man_XEA404.pdf
page number 14 in pdf will provide information about Reciept ON/OFF function
please vote if this information is helpful
Dec 31, 2008 | Sharp XE-A404 PC Desktop
D1360 black ink didn't print and green light keep flashing
just unplug the power cable and usb cable from the back side of the printer and let it be for an hour it will help
Apr 15, 2008 | HP Deskjet D2360 InkJet Printer
Hp 1210 all in one prints anything but reciept?
Sir, I have lost my CD to install my hp 1210 printer, where can i find a download program to assist me?
Mar 31, 2008 | HP PSC 1210 All-In-One InkJet Printer
Faded print on one side of page
I have a SCX-4100 Samsung, replaced the tonger cartridge, it was working fine for a few hundred sheets of printing, but after that, the left side of the page was printed very light, faded.
If I run the "Clean Drum", it will print a litter better, but still faded.
What can I do to correct this problem?
Thank you
TT
Nov 24, 2007 | Samsung ML 1710 Laser Printer
Light print of incoming faxes, cannot read
are copies light too? if not then it is sending fax, but most times it is inferior ink or drum causing the problem sometimes damp paper (try printing on reverse side as well)
Oct 31, 2007 | Brother IntelliFAX 2600 Fax
Sharp Royal Alpha 9155SC Cash Register Logo
151 people viewed this question
Top Sharp Retail Supplies Experts
k24674
Electroboy
Electroboy
Are you a Sharp Retail Supply Expert? Answer questions, earn points and help others
