Question about Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune gas dryer does not produce heat
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 40 Answers
Could be a numerous amount of things. Most common is a blown thermal fuse or high limit safety switch has a open circuit rather than a closed circuit.
Posted on Apr 17, 2015
The upper cabinet of our Maytag Neptune MCG8000AW Gas Dryer has always "dried" my dress shirts to come out without wrinkles. Now it seems to have power and light but it is not producing any heat
Most of the time a "no heat" condition on a gas dryer is due to one of two things: burned out ignitor Appliance Parts and Accessories Repair Appliance Parts Discount Parts... OR it could be a thermal limit switch that has failed which are easily replaced with this kit Dryer Thermostat Kit At one time, there was a TSB (Technical Service Bulletin) out on this particular dryer that referred to a change that was made to the electronic control board eliminating the need for an external heater relay in December 2002 (Series 61). The new control board is supposed to work in place of all previous electronic control boards. Good luck.
Mar 12, 2014 | Maytag Neptune MDG5500AW Gas Dryer
No dryer heat
If the coils are bad the unit will light with flame for 4 - 8 times then all of a sudden the ignitor will glow, kick off with no gas coming threw valve. it sounds like the high limit thermostat is short cycling the flame. This is the thermostat that sits on top of the burner chamber. remove 1 screw from the thermostat and blend it upwards away from the heat. Then plug unit back in and test to see if the flame stays on longer. Click here to see maytag dryer no heat posts. Contact me anytime here. Hope this helps..
May 20, 2013 | Maytag Neptune MDG6700A Gas Dryer
Maytag Neptune wont heat up what is problem
We just converted my neptune gas dryer to propane. It ignited yesterday but we could smell propane. So, my husband fixed that ,now it won't ignite and heat up
Nov 10, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Maytag gas dryer will not heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jul 06, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Our Neptune gas dryer seems to work fine but suddenly produces no heat. The vent is clear and the gas line attached and open.
Look at the glow ignitor. If it is broken then it needs to be replaced. About 20 dollars, and a 5/16 wrench will fix this issue, just make sure that you unplug the dryer before you start touching the electrical. This piece is located in the bottom of the dryer behind the back panel.
May 08, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Dryer works but does not produce heat
THE HEATING ELEMENT NEEDS TO BE REPLACED, NEED A SERVICE TECH, IT IS NOT A COSTLY PROBLEM , IF YOU AVE THE ORIGINAL BOOK IT SHOULD TELL YOU HOW TO DO IT YOUR SELF JUST ORDER THE PART THRU THE COMPANY IT'S NOT THAT HARD TO DO,
May 29, 2009 | Maytag Neptune MDE6700A Electric Dryer
The dryier does not heat
the problem are your gas coils are faulty
Jul 26, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
219 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
