Question about Panasonic Lumix DMC-TS5 Digital Camera, 16.1MP, 1/2.33" CMOS Sensor, 4.6x Optical Zoom, 3.0" TFT LCD, 28-128mm Leica DC Vario-Elmar Lens, Blue
Water in the viewfinder.
A speck of water seems to have got into my viewfinder. Noticed when it fogged up the other day. Any help as to how to remove it would be REALLY appreciated.
    Top Expert:
  • Panasonic Master
  • 10,875 Answers
Put it in a jar of rice for 2 days
Posted on Apr 16, 2015
    Top Expert:
  • Panasonic Master
  • 6,702 Answers
When there is a residue in the water, it most likely will leave a stain or a little fogy spot. Please don't try to remove it. Opening the camera, will make things worse. Try to live with the optical spot. As long as it is not on your pictures.
Black chunks and water after use of V150SG Vicks Steam Guard Vaporizer.
The black specks could be caused by interaction between the heating element and mineral content in the water.
Mar 25, 2014 | Vicks V150SG 1.5 Gallon Warm Steam...
Peugeot 206 front fog light hal filled with water. how do i get rid of this?
You need a new fog light as you one is cracked some where you can remove the light by taking the inner wing off then remove the light by the torques bolt at the top
Aug 01, 2013 | Cars & Trucks
My husband overfilled the water reserve the other day on way to work. Once at his destination it started to burst out all over the place. after work he forgot to chek it...durrr lol then nxt day I cheked...
well in sounds like the reason it was hot was the thermostat had not opened up yet to allow the coolant to flow and when it went to normal temp is when the thermostat opened which allowed the coolant to flow through the motor and radiator which would take your reservoir down to a low level and that is when you top it off to full. If noticed no leaks you should be fine unless you have a bad thermostat which would make the car overheat. Anytime car gets hot you should turn on the heater to help cool the water temp in the motor, when you operate the air conditioner it makes the motor work harder which in essence the motor gets hotter.
Feb 07, 2011 | Ford Taurus Cars & Trucks
Left fog light suddenly has water inside and does not work do I need to remove and replace the whole assy or just replace the bulb
get the fog litht remove drain the water in it,replace the bulb if it did not light check the fog light fuse perhaps it might have got damage if yes change it
Dec 02, 2010 | Honda Accord Cars & Trucks
Slow leak
The water pump should have a vent or "weep" hole. If the coolant is leaking from the hole, the water pump is defective. Hope this helped and best wishes.
Aug 11, 2009 | Dodge Spirit Cars & Trucks
Water leak & no heat from the fans
is the passenger floor wet if so you need a heater core is there a sickly sweet smell do your windows fog all signs of heater core leak
Mar 16, 2009 | 1997 Ford Probe
When i run the heat or air cond. i smell water and windshield fogs up in the middle.
Sounds like your heater core is bad. Have someone check out the heating system and possibly replace heater core.. that should take care of the fog problem also by enabling you to use the defrost... Good Luck!
Oct 26, 2008 | 1999 Jeep Grand Cherokee
Bosch Washer
You know, Dealers would tell you any thing just to sound clever.
it needs a service,The reson being,on the back of the drum and under the drum you get bearings, i think 3 of them,they r filld with grease.Just take if for a service or if you can do it ur self,after that you can clean that door rubber with petrol, YES Petrol :).
Hope this helps you...
Sep 08, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Ice build-up in back of freezer
you probly got a water inlet spout froze over.. take out ice maker and look where water inters icemaker and see i that is froze
Aug 23, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
Panasonic Lumix DMC-TS5 Digital Camera, 16.1MP, 1/2.33" CMOS Sensor, 4.6x Optical Zoom, 3.0" TFT LCD, 28-128mm Leica DC Vario-Elmar Lens, Blue Logo
74 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
