Question about Samsung Refrigerators
Samsung RB1844SW won't stop beeping and fridge light is off. Tried unplugging and restarting and beeping continues but the light in the fridge will go back on for a few minutes
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 75 Answers
Door switch is magnetic. either the door swith malfunctioning or fridge magnets in proximity will cause this
Posted on May 05, 2015
  • 1462 Answers
SOURCE: Fridge problem
means the temperature has gone up and freezer temperature is too high. fault should rectify itself given some time
Posted on May 12, 2007
SOURCE: Samsung SR-L39 fridge freezer switching off
tarsia upatvane
Posted on Aug 30, 2008
SOURCE: Samsung Fridge can't get temp down
it is probably the door switch. I just pulled the switch from a rb2055 and disassembled the switch. one of the contacts is broken.
If you unplug the fridge and plug it back in, the light should work. push in on the switch button with the door open. If the light does not go out, switch is bad.
pry the switch gently out with screwdriver, unplug it and get a replacement.
If you are watching this I can also probably tell you how to jerry-rig it to run while waiting for replacement swicth.
Posted on Jan 03, 2009
heatman101
  • 43501 Answers
SOURCE: My refrigerator beeps 5 times every few minutes
The refrigerator is probably beeping because it is too warm. It has a sensor thaat will make it beep to warn you if it gets too warm. After being off for such a long time it will take a long time to get it cold enough again to stop the beeping. Give it time and it will stop.
Posted on Nov 16, 2009
SOURCE: Samsung RB1855SW won't stop beeping and fridge malfunctioning
Thanks so much for the advice. I just gently pried the door sensor switch on my Samsung RB1855SL out with a butter knife and then pulled out the electrical connection and it fired up right away. It looks like some orange juice seeped in and corroded it. What a relief to have the fridge working again, not to mention to not have to listen to the beeping.
Posted on Feb 12, 2010
My fridge will not stop beeping its model795.5132 or 795.5131
If working ok, just locate and disconnect the ****** beeper till permanent repair can be affected.
Oct 10, 2016 | Refrigerators
Temperature controls seem to be playing up and then stopped completely
Try resetting system. Unplug for 10 min. Then plug back in. Set all temps. 36 ref. 0 fre.
Jun 18, 2017 | Refrigerators
Hi, I have a Bosch undercounter freezer and it won't stop beeping!!! All the lights flash whilst beeping, the lights are under the super freeze button, mute button and the temperatures. If I hold...
The beeping is a signal that the fridge has not got down to, or holding temperature... You may have a thermostat or gas system fault. Check and see that the fridge has actually got cold.
Jul 31, 2011 | 2007 Harley Davidson FLHX Street Glide
The alarm beeper keeps beeping even though the doors are closed. The fridge has been sitting for about a year.
hi,
you can check a limit switch at its door. it is located usually at the door area inside.
maybe it is not working already or get stuck that is why it doesn't sense that the door is closed.
most of the time it is getting stuck and you can fix it by just pulling it out or other ways to do it.
hope that solves your problem.
Don't forget to rate me. Thanks...
Regards,
John
Jan 10, 2011 | Samsung RB215LASH
The alarm beep which tells you to close refrigerator or freezer door now beeps even after either door has been closed. It beeps three times at approx twenty second intervals, then beeps continuously for...
Sounds like you have a bad door switch. Depending on the age of the fridge, it might still be under warranty. If it's not, then you might be able to access the door switch yourself and pull it out & replace it.
Good luck......
Aug 15, 2010 | Fisher and Paykel Active SmartĀ® E522BR...
Apr 01, 2009 | Refrigerators
Frigidaire refrigerator making beeping sound
Unplug your refrigerator from the ac outlet, and 0open theref door for approx. 5 minutes. Then plug it again, after you hear the beeping close the door. wallah it's fixed.
Dec 21, 2008 | Frigidaire FRS3R5EMB Side by Side...
May 05, 2008 | Samsung RB2155SH Bottom Freezer...
Refrigerators Logo
329 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
