Hi i just replaced hard drive and I am having issues with loading os 9.2 on my ibook it just goes to the blinking ? & smile faces, how do i get around this and ge the instalation started
    New Friend:
    Problem Solver:
A blinking ? mark means there is no system folder. Make sure the drive is formatted Mac OS Extended (Journaled). Make sure your install disk is a retail version of OS 9.2.
Format the drive using Disk Utility in the Utilities folder.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0CB4QFjAA&url=https%3A%2F%2Fwww.ifixit.com%2FMisc%2FHD_Software_install.pdf&ei=E9REVbvqJY2FNpmigMgD&usg=AFQjCNHspv7sImCPAvmfH-iBTFkhzkeVmg&bvm=bv.92291466,d.eXY
Posted on May 02, 2015
  • 55 Answers
SOURCE: help pls.
You have a problem with the hard drive, either it is not working correctly or system software on it is missing or corrupted.
Posted on Oct 15, 2008
Joed911
  • 4338 Answers
SOURCE: IBOOK G4
You may have a RAM problem.One of the most serious problems that can afflict your Mac is "bad memory" -- the common term for a defective RAM chip.
Apple provides Apple Hardware Test with every new Mac -- it's either on the Mac OS X Install/Restore disc, or on a separate Hardware Test disc.
Here are the instruction on how to run the Apple Hardware Test CD:
http://support.apple.com/kb/TA25668?viewlocale=en_US
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 16, 2008
Joed911
  • 4338 Answers
SOURCE: please help me
Nothing can be more frustrating than turning on your Mac only to find that it won't start up. Instead of seeing the Finder, you see a blue or gray screen, an icon of a broken folder, a kernel panic, a flashing question mark, or a computer that just sits there. What can you do? Don't worry. It could be a simple issue that you can fix yourself. Follow the steps in this document to diagnose and fix the problem:
http://support.apple.com/kb/TS1411#symp1
copy and paste the link into your browser.
Thanks, Joe
Posted on Nov 28, 2008
seaniepie
  • 250 Answers
SOURCE: model A1005 mac ibook
When you say recovery disk I assume you mean the main OS disk. A recovery disk on a mac generally is one you would make as a back up. Depending on the OS you used you would need to get a new one. These you can pick up from eBay pretty cheaply, both OS9 and OSX10.4.
All the best
Sean
PiDigital
Posted on Dec 16, 2008
thomtime
  • 38 Answers
SOURCE: just repaired g3 ibook. Hard drive needs
With the OS X Installer CD in the drive, try booting your mac and holding down the option key immediately after you hear the start up chime. This will (hopefully) load a firmware boot loader that will show available start up discs. Hopefully the OSX installer will show up as CD Icon. Select the Icon with your mouse or keyboard and press enter to start up with the Installer CD. From the installer you should be able to erase and format the drive as Mac OS Extended before installing OS X.
If the computer still won't boot from the CD double check that it is a retail OS X installer CD. If your CD has "software restore" or "ibook restore" or any other varient of restore written on the label; or if it names a particular model such as "ibook install" or "imac install" it is not a retail copy and may not be a bootable disc. A retail copy will only name the version of the operating system followed by the word install written on it's label and usually have a brief instruction on booting from the CD by holding the C key at startup.
Hope this helps, let me know what happens.
Posted on Apr 03, 2009
My iBook is very slow to load after contact with a magnet
Run a demagnetizer around the area she had the magnet around the computer. The conductivity has sent a pulsation into that particular area. Demagnetizers were used on cassete recorders and are very hard to find these days
Jul 15, 2010 | Apple iBook Mac Notebook
I picked up a Powerbook G4 12' Aluminum guesing 1.5 from a local college that was going to trash it, and when I press the power button the start up chime rings and turns straight to a blinking ?/Mac OS...
Get the gray OS discs specific for the PowerBook. Your iBook gray discs won't work. You can also install the OS by getting a black label retail version disc of whatever cat you like- Panther or Tiger. If the software installs, but you hear noises or get the spinning beach ball of death, then the hard drive is fu.k.d up. You then have to open up the computer and install a new hard drive and re-install the OS. Good luck old chap. Cheers.
Dec 31, 2009 | Office Equipment & Supplies
I was trying to install Mac OS X 10.3 on my G3 iBook, it did not work, and now neither does the iBook.
It sounds like you have a hardware issue of some sort - likely a bad hard drive, due to age. I would suggest taking the laptop to a repair shop (don't bother with the Apple Store, they'll tell you to buy a new laptop or just turn you away). Best of luck!
Nov 09, 2009 | Apple iBook G3 Mac Notebook
Will not start. Goes to a gray screen with apple on it then stops
You may need to boot from the MacOS X CD to do a repair. Insert the CD in the drive, and restart. Keep pressing the C key to boot from the CD, once the CD boots, you may have options to repair your MacOS installation, or alternatively reinstall the system software.
May 24, 2009 | Apple iBook G3 Mac Notebook
Just repaired g3 ibook. Hard drive needs formatting, as it has xp loaded on it. Ibook starts up, boot tone, proceeds to load, then screen has a file in the center of screen with the osx finder square face...
Apr 03, 2009 | Apple iBook G3 Mac Notebook
Stuck
the flashing ? mark means its not seeing any bootable device do you have the original OS disk from apple???? If you do you need to boot with them and test the hard drive to see if its functioning and or there is an OS issue.
Oct 31, 2008 | Apple iBook Blueberry Mac Notebook
Help pls.
Oct 04, 2008 | Apple iBook G3 Clamshell (M2453B) Mac...
1999 apple laptop
The laptop is looking for the Apple OS. I suspect the hard drive is corrupt - or has been "told" to boot to OS 9 instead of OS X - and you may not have 9 installed.
If at all possible, reinstall the operating system.
May 15, 2008 | Apple iBook Mac Notebook
Cant load os
Hi Tajjek,
Try booitng the Mac from the installation disc which was shipped with the machine,make sure to use the right disc( which was shipped with the machine). If the unit does not boots to the OS disc,then remove the internal hard drive and power on the machine if you get flashing question mark after start up boot chimme then it is issue with the internal hard drive. Please get backt to me with your observation if issue persists.
Feb 13, 2008 | Apple iBook G4 (Z0AZW13397068) PC Notebook
Computers & Internet Logo
306 people viewed this question
David Payne
David Payne
