Question about Maytag Kitchen Ranges
My maytag range always has dust between the glass/ Have to cover the glass with a towel all the time LOOKS TERRIBLE how do I dust between the two pieces of glass
    Top Expert:
  • Maytag Master
  • 48,486 Answers
You don't sad to say .
Posted on Apr 20, 2015
SOURCE: Clean Oven Door Glass
Using a long stick/tool, attach a cloth to the end. Remove the drawer and look up at the oven door. There are 2- 3 openings that are big enough for you to reach the mess. Make sure that whatever you are using to clean the glass will not stay stuck inside, so make sure its attached securely. I used the end of back scratcher with a thin cloth attached to it. After a few attempts, I was able to completely remove the stain that was caught between the two panels. AND... I didn't need to remove any screws or dismantle the door. This could void your warranty.
Posted on Feb 17, 2009
SOURCE: Maytag Gemini oven glass door panels impossible to clean
We had an ugly spill of hot grease/water from a roast, and lots of it ran right into the vent holes on our oven door, covering various layers of glass and other parts inside the door. Yuck. Thankfully we found this site!
"fixetheoven" was certainly on the right track, but missed a key step that makes this job much, much easier. (Maybe they had a few too many sips of wine during the process?! :-)
Anyway, the key to make the job easy, and do-able by one person, is to pull the door off the hinges before starting to remove any screws! Here's how we did it:
1. Open the door about four inches or so, it will stay in place. Hold the door at the sides and lift it up, sliding it right off of the hinges! Now lay it carefully face up on a table so you have easy access to the screws, and no danger of the glass dropping out of the bottom of the door (as apparently happened to "fixedtheoven".)
2. Remove the two screws that hold the panel on one side of the door. (One screw is halfway up the side panel, the other is on the bottom edge of the door.)
3. Slide the panel off, paying close attention to how it fits into place so you can return it to its original position later!
4. Remove the two screws that hold the panel on the other side of the door, and slide that panel out as well.
5. Remove the three screws that hold the panel across the bottom edge of the door, and remove that panel.
6. Now you can slide the front glass out from under the top edge of the door.
7. Clean the front glass, the side panels, and the bottom panel, as needed.
8. There will be another layer of glass inside the door. If it needs cleaning on the underside, remove the screws from one of the metal brackets that hold the glass in place. You can then slide this piece of glass out from the metal bracket at the other side.
9. After cleaning everything, reassemble the door by reversing the above steps.
10. Lift the door by the sides and carefully slide it back into place on the hinges. Be sure it is properly in place and being held there before you let go!!
11. Now go pour that glass of wine and sip to your heart's content, while admiring how clean your oven door is!
Posted on Jul 29, 2009
SOURCE: Black, burned looking spot on glass cooktop of my
I called my Frigidaire repair man and got the info I needed for free.
Posted on Aug 04, 2009
heatman101
  • 43501 Answers
SOURCE: admiral range lgr333oadz. middle glass on door exploded
Unfortunately that is a very common thing...I see many of those problems go through Fixya everyday..
here are a couple of tips... one on replacing the glass and one on why not to use the clean mode...
heatman101
http://www.fixya.com/support/r4391163-range_stove_oven_door_glass_replacement
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
Posted on Mar 26, 2010
Testimonial: "Thanks,thought Id need a new door.The middle glass that shattered fell through the bottom of the door was that normal? Shouldnt that have been sealed?"
machinetech7
  • 1344 Answers
SOURCE: how do i take replace to outer glass panel on a maytag gas range
Here is a step by step on door glass repair:
1) open the oven door and look at the hinge on each side, there should be a moveable part sort of near the middle of the exposed part of the hinge. This is the hinge lock, or stop, whichever you prefer.
2) flip the hinge locks in place.
3) with the locks on place, try to close the door slowly. you'll notice that the door will push upward.
4) when it does this, you can now lift the door and remove it from the rest of the machine
5) To access the glass you going to have to take all the screws pretty much, making sure you remember where and how each one goes
6) now the door should come apart and you have access to the glass
****Note that there are a great number of makes, models, etc. This is a general instruction, and some extra steps may be needed ****
Posted on May 12, 2012
Unable to remove oven Light glass cover.
Most oven lights will have a flat cover with 2 clips or a round glass knob. These sometimes become stuck in place due to the heat and fats from the food. Don't be scared to give the flat glass a tap with a blunt object. You can use multigrips on the glass knob but just be gentle.
Feb 13, 2011 | Maytag MER5770 Electric Kitchen Range
The tv looks too dim. you have to stand right in front of it to see the picture but it still looks dim.
Other than a circuit problem it may be dirt or dust on the lens. The model indicated has 3 picture tubes.
If you unplug set and remove back cover you should be able to see and reach the large black lens dead center and above the circuit boards. If the lens are very dirty the picture will be dark and dull looking.
There is also at inside top back of set a mirror--if it is dusty or has grime on it, same thing--not as easy to get at but with back off you can use a small mirror to examine it.
Clean the lens with a lens cloth or a paper towel with glass cleaner sprayed on the towel.
With back off, 2 minute job and if picture now much brighter, you are in business. Lens, depending on how much dust etc in your area should be cleaned one time a year or more-----do it yourself job and easy.
If this told you something you did not know, rate this solution as very helpful as I do this here for free.
SD TECH
Aug 19, 2010 | Sony KP-43HT20 43" Rear Projection...
Maytag Microwage display screen is foggy
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you can detach the keypad connector (as per attached photo) then remove the control panel screws.
Be careful not to crack the glass display when handling it, or it's a goner.
Then you can use a soft cloth (not a paper towel) and a mild cleaner (not ammonia-based) to clean the front surface of the VFD display glass and the rear side of the clear bezel (display window) that's attached to the keypad.
Direct spraying of cleaners on the keypad and steam from the cooktop can damage the controls.
I always recommend that you spray non-ammonia cleaner on a soft cloth (not a paper towel which can scratch) and gently wipe the keypad.
May 18, 2009 | Microwave Ovens
Drip marks in between the two layers of glass
No they are factory sealed and what you are seeing is the glue from the factory. Return the item for warranty.
Apr 23, 2009 | Maytag Appliances Over-the-Range Microwave...
How to get grease stains off
Hi, Is this a glass top type? If it is then DO NOT use any abrasives, soft scrub, ect. Use a razor scraper like for paint and keep it flat. Then purchase any commercial glass/ceramic cook top cleaner (grocery or hardware or diy store) and use a drop about the size of a dime on each burner. Fold a couple of paper towels and in a circular motion buff the top and when it looks clean turn the towels over on to the dry side and polish it to like new. Good Luck!
Feb 02, 2009 | Frigidaire FGF316 Gas Kitchen Range
Can't get the top clean and it always looks dirty
you can purchase the ceramiic cook top cleaner from the supermarket,apply as you would wax a car, in small circular motions until it dries to a haze then in similiar fashion, wipe off. As far as the stubborn spots that remain, reapply the creme and scrape off with anew clean razor blade, held flat to the cooktop ( not using the corners) will get just about any stain form hte unit. Manufacture usedto supply such razor blade scrapers, but for liabiltiy reasons no longer can package in. use a terrycloth towell as well, paper towell are filled with lint and can actually scratch
Nov 30, 2008 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Jul 22, 2008 | Maytag PER5510 Performa Electric Kitchen...
Top of Gemini range
Hello patricialc,
Welcome,
You said, you have the stainless Gemini range and the top is black. I cannot get the top clean. It looks like the paint or the surface is "bubbled". I have tried EVERYTHING and it always looks like there is grease spatters on the top. I have all Maytag appliances and I am VERY disappointed with this stove. If I could, I would take it back...but I keep trying. I let the Maytag stove I had go. It was made in the late '50's, so I could 'update'. What a mistake!!!
The other option is to order a new glass top and have it replaced.
No abrasives!!
Let me know how you do.
Huuum
Please remember to leave a rating!
Jun 29, 2008 | Maytag MGR6772 Gemini Gas Kitchen Range
Kitchen Ranges Logo
176 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
