My washing machine wont fill with water. When i turn it on to a cycle all the water is running out of the drain hose. it just beeps when its been on for a few mintues and my clothes arent even wet
    Top Expert:
  • Washing Mach... Master
  • 44,260 Answers
Call a repair man we can look for nothing as you did not include make or model
Posted on Apr 15, 2015
  • 3 more comments
  • jess cole Apr 15, 2015
    Hi sorry its a 9.5kg top loader haier hwmp95tl washing machine. I received it off a friend and ive had it for a few months now and it has always worked perfectly. And now it just started not filling with water
  • ray gallant Apr 15, 2015
    I would suspect the timer then
    Do you know if there is a way to fix that myself?
    It was working fine the other day but now instead of filling with water all the water that it is meant to fill with is just running out the drain hose
  • ray gallant Apr 16, 2015
    usually the drain line has to be higher off the floor than the washers full level if below that it will always run freely
  • jess cole Apr 16, 2015
    Ok thank you. Will try that. It had fallen down so that's probably my problem
My washing machine wont fill up with water, what would the problem be, ive cleaned the hose at both ends so its not blocked?
usually the hot and cold water solenoid fail stopping water to flow
replaceable part
location
in where the hoses attach to the washing machine
May 09, 2016 | Washing Machines
Fills to wash, drains but then tub won't fill for rinse cycle;
u need a new cold water valve, if u check the temp of the water while its filling it is mainly hot, or u have the hot nd cold hoses on the wrong way , as all rinses r cold
Jan 31, 2010 | Fisher and Paykel GWL11 Top Load Washer
Washing machine wont hold water on any setting
raise the main drain hose to the top of the back control head. there may be a problem with the main hose being to low and the water is gravity siphoning out of the washer.make sure the washer is off when you lift the hose up but do not remove it from the wall,you should here water drain out once it has stopped draining restart you machine and it should fill to the proper level and quit then go into your wash cycle
Jan 31, 2010 | Whirlpool Inglis IP4400 Washer
What is the best way to winterize a standard large capacity washing machine?
If the product will be exposed to sub-freezing temperatures, turn off the water supply to washer, disconnect fill hoses, drain them and reconnect. Remove the drain hose from the standpipe in the wall and place it into a shallow pan at floor level untill the water floe stops. Unplug unit and you are good to go.
If no sub-freezing temps are expected, turn off water supply. Turn on washer for a warm wash cycle for a few seconds to relieve the pressure in the hoses. Turn off machine and unplug it.
Nov 04, 2009 | Kenmore 22422 Top Load Washer
Sometimes my new machine will not fill with water
make sure that your drain hose is coming up ( 90 degrees ) from the base of the machine. and then drains near or close to the height of the machine. the drain hose at least needs to be at a 45 degree angle to fill properly otherwise it will continuosly drain. hope this helps.
Oct 18, 2009 | Washing Machines
Washer won't drain.
My washer fills up with water and goes thru the wash cycle but when it's time to drain, it just sits there and clicks.
Oct 17, 2009 | Tecnik TKL9260 Front Load Washer
Rinse cycle wont fill
check your drain hose. needs to be at hieght of tub before entering the drain....should only be 3-4 inches in the drain and secured with a ziptie.
Jun 08, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Water runs into tub but does not fill?
be sure the drain hose is not lower than the wash tub this will caust the water to run out, 2nd be sure the drain hose is not pushed to far into the house stand pipe and the there is rome for air to go inbetween the drain hose and stand pipe eather of these will cause the machine to siphon mostly on rince cycle or on the 2nd and third loads you do. last your house drain could be starting to back up fill the washer with water and listen to it drain if you hear a gurggling sound in the house pipe you may need a plumber to cleanthis out for you.
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Will not hold water during initial cycle
The drain hose needs to be lifted above the high fill level in washer.The easiest way to fix this is take the drain hose (if your drain hose starts from the bottom of machine and goes up)tie or strap it to the back of the washer so it cant sag or drop down and start syphoning the water.Remember the washer will drain out the water if the drain hose is lower than the amount of water in the tub.Thats why your making sure by tieing the drain hose to the highest point before it makes it way to the drain .
May 21, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machine stopped through cycle and now will not turn on
I can help with this. I work on the units they make. If you can email me @ curator@artinallforms.com I will guide you through
Jun 16, 2007 | Fisher Paykel EcoSmart GWL15
Washing Machines Logo
35 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
