Question about Hitachi 43GX01B 43" Rear Projection Television
Ultrascan hitachi 43" hd tv
Please help me indentify the problem in my tv.( 9 years old). When you turn on tv am getting the duble picture and curling up at the top of the screen. The colors split into red, blue,green and yellow.
  • 934 Answers
Re: ultrascan hitachi 43" hd tv
What you're describing is convergence and the amps need to be replaced... IK04 and Ik05 are two STK392-110 and Hitachi suggests replacing them with the STK392-150's for greater reliability..
If you're not too capable in electronics this is one to leave for the professionals. But at least you can call around and ask what each shop charges for replacing the convergence amps in this unit...
Hope this helps.
Posted on Nov 14, 2007
0 characters
3 Points
Pic suddenly went dark, very dark. Images seen are oversaturated. hitachi ultrascan hd is about 8 years old. Help!
I have the same problem. I took the back cover off of the TV and blew all of the dust out and the TV started working again. But this only lasted 2 days. Now the TV is dark again.
Jan 19, 2010 | Hitachi 43UWX10B 43" Rear Projection...
My Hitachi Ultrascan is about 8 or 9 years old and it has been the best TV until lately the colors are not lining up. There is a blue arch at the bottom of the screen and over the past few weeks I was able...
Very common in DLP tv u lucky is last it this long.Usally 2-3 years the Convergence ICS are dying will be dead and all it supporting resistors is dead .The convergence is dead,must know how to solders,repalaced Convergence ICs all it resistors.Tries Tv Repair, for the convergence kit.The shop will cost u 300 for parts and labors.
Jan 15, 2010 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi UltraScan HD... picture is way off and has red lines
Its a convergence problem. You may want to check the site Every thing they said every description was right on. The best money I ever spent and the confidence you get from doing it yourself, Its a great feeling of achievement not to forget the live messenger support is instantaneous, friendly and informative if you need to fix your tv go to I fixed a philips 60 inch tv in 45 minutes, The convergecne chips were bad thanks a million. You guys saved me 250.00 bucks. I'll be recommending you to everyone I know!
Aug 18, 2009 | Hitachi 43GX01B 43" Rear Projection...
Yes, it is HD TV ready but you must have a set top box from your cable or dish company that provides a Hi Def signal. The inputs must also be connected with the YRB cable. Only certain channels on my box are HD. The screen is so large that HD isn't nearly as impressive as some of the smaller models but it is still HD. I also have the 53FDX10B.
Mar 03, 2009 | Hitachi 53FDX01B 53" Rear Projection...
Hitachi ultrascan hd- no picture, just makes clicking sound
wires are crossed over to wrong amplifiers when hooked up you might have blown completly
Dec 06, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Red arched ghost
Thats not a valid Hitachi model number the sp4400 are audio speakers, but hitachi doesnt have model numbers for tV with sp can you please respond to this post with your model number and I will help you. SP43H is more like a Samsung model number.
Jul 15, 2008 | Hitachi 57F500 57" Rear Projection...
Hitachi ultrascan HD tv 43 inch
Good Day;
If you don't hear the relay click suspect Q003. No power suspect Q912, Q914 & I901. Good Luck, big IRISH.
Jul 11, 2008 | Hitachi 43UWX10B 43" Rear Projection...
HITACHI ultrascan hd tv....
Convergence amp ic bad
Or send to
good luck
please mark the post with a fixya
Feb 24, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Hitachi ultrascan hd tv
Or send to
good luck
Feb 20, 2008 | Hitachi 43GX01B 43" Rear Projection...
Free TV
It probably has a broken mirror or somethings inside the set blocking part of the pic. Now for ther picture all red. If your not a tech I highly advise you going insidew this . Unless you know about the saftey issues and the HI voltage issues. Your problem could be a shorted Picture tube all the way to na bad distribution block . Good Luck
Jun 30, 2006 | Hitachi 43GX01B 43" Rear Projection...
Hitachi 43GX01B 43" Rear Projection Television Logo
165 people viewed this question
Top Hitachi Projection Televisions Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Projection Television Expert? Answer questions, earn points and help others
