Question about Elegant Home Fashions Madison Avenue Linen Tower Bathroom Shelf - CF5QOE
I totally unpacked lst night and put together but my channel lock screws wont stay in place. I need help please. I love this cabinet and am otherwise pleased but I'm stuck putting it together.
Thank you, Sheila "onyxmsw@gmail.com"
    New Friend:
  • 169 Answers
Would you send us some photos showing the channel and the lock screws?
Posted on Apr 15, 2015
How to remove hard drive from HP Pavilion a1243w
Hard drives in towers are easy to replace. Once you've opened the cabinet, the drive is held in place with screws or clips. If it's clips, you may just have to spring the front off to slide it out forwards, put the screws into the new drive and slide it back in otherwise just undo the screws, slide it out into the cabinet taking care not to pull any other plugs out then slide and fix the new one into place.
Of course, it's no use doing this if you don't have the recovery discs or a windows disc to re-install the operating system.
Feb 25, 2013 | Computers & Internet
My reciever continues to give me problems after 45 min of usage. after that point it starts to shut down certain channels. Help.
heat is the problem but the reason for the heat is the fan inside the unit is not working. I didn't even know there was a fan inside until I opened mine. The fan looked brand new The voltage off of the board where it hooks up is not correct or something so I hooked up the black to the middle pin where it hooks up and the red I cut and put under a screw(Grounded) the yellow is cut off. Mine works now and the speaker has not cut off since. I have left it on for hours and no more speakers cutting out. The fan is actually very quiet. but you can hear it.if it doesn't work make it so you will not overheat. Remember the fan plug the middle wire should be black the yellow can be cut away and the red needs to be stripped enough to go under a screw. I put mine under one of the screws that hold the fan in place. The front does need to be kinda removed so be careful not to break anything. and don't lose any screws. put it back together the way it came apart the front was not totally removed just enough to get to the fan screws. Its a little work but its worth it unplug your receiver before you go inside to avoid shock.
Nov 10, 2009 | Pioneer VSX-816-K/S Receiver
Cobra 200gtl night watch went out. worst case... how much to fix. thanx
You need to order the part from cobra, and then take the face off and replace it. I don't know about availability of the part.
Some times its a pain in the but to pull the face apart. Have to pull the knobs off. Take the covers off. un screw the face and any other screws holding it in place. Then you need to unsolder the wires from the old part, and solder on the one from the new part, then put it back together.
Oct 31, 2009 | Cobra 200 GTL DX 4-Channels Base CB Radio
I have a bathroom cabinet door that came off and now I can't get the screws to stay in as the inside of the cabinet is so damaged and wood filler does not work , even glue will not hold this door back on...
Buy a dowel pin the size of the hole in the cabnet then use carpenters glue to glue the dowel pin in place where the old hole was make sure it is a good tight fit. Next saw off the dowel pin and let set over night then drill a strating hole in the dowel pin and reinstall the door works like a chanp. Hope this helps.
Sep 28, 2009 | Duravit 6130 Starck 1.2.3 Vanity Unit w/ 2...
Replacing motor coupling
Removing the cabinet. UNPLUG the washer. There are two screws holding the control panel to the cabinet. Most models the screw are in front but, some models have the screws in back. They are on each end. Now raise the control panel up and let it rest on the hinges. Unplug the lid switch harness and locate the clips on each side (bronze in color) and release them.
Now the cabinet will lift off the frame and you can set it aside.
How to replace a coupler:
Now that the cabinet is out of the way, remove the pump from the motor and set the pump off to the side. Remove the two screws holding the clips on the motor and remove the clips. Unplug the motor harness and on some models you wil need to unplug the capacitor.
Now you will need to replace all three parts to the coupler. I use a ½” socket and a small hammer to force the coupler onto the motor and transmission shafts. Put the rubber part onto the coupler half on the transmission and then line up the post on the motor shaft with the holes on the rubber part and it should go on ok. Put the clips that hold the motor in place and plug in the harnesses.
Put the pump back on and the clips to hold it in place. Set the cabinet back on the frame. Make sure the lip on the front cabinet is under the front rail of the frame. Ease the cabinet on the frame making sure the two rear sides of the cabinet set down on the tabs of the frame.
Put the two clips back on that hold the cabinet and plug the lid switch back in. Fasten the control panel down and you are all set.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 01, 2009 | Washing Machines
Washer wont spin at end of cycle
Hi, it sounds like the coupler or lid switch is bad. Do you hear the motor running during these cycles?
If you do, the coupler has gone bad. Here are the instruction on how to change the coupler. Part# 285852
Normal 0 Removing the cabinet. UNPLUG the washer. There are two screws holding the control panel to the cabinet. Most models the screw are in front but, some models have the screws in back. They are on each end. Now raise the control panel up and let it rest on the hinges. Unplug the lid switch harness and locate the clips on each side (bronze in color) and release them.
Normal 0 How to replace a coupler.
I know this is lengthy but I hope it helps. Please let me know if I can assist you further.
Thanks
Vic
May 25, 2009 | Washing Machines
Remove lid of top loading washing machine Kenmore 110.92575110
Remove 2 screws that hold the console in place. Most are at the rear corners of the console. Pull console forward and up and tilt back.There are 2 brass clips holding the cabinet in place. then the cabinet can be removed by tilting forward and away from base. there is no reason to remove the lid.
Jan 04, 2009 | Kenmore 24032\24036 Top Load Washer
Door wont shut properly and washer will not start
Is this a problem that just happened at once or gradually got worse?
Does the D/W seem to be installed tightly to counter??If it is firmly mounted than you need to take loose the screws that are holding it in place to your counter.Usually there are just 2 of them.Only remove these if the door seems to be hitting something just before it is shut.By opening & closing slowely I need to know if the door seems like it bumps the inside right before its locked.By removing the 2 screws that hold this snug it will allow the squarness of the cabinet to become free & the door will align itself.Alot of installers over tighten the legs & lift the dishwasher into the counter so high that it forces the door to miss the Latch.I'll help you through this ,so let me know ,Thank You!
Apr 16, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
LST-3510A
Hello, I've been reading up on the LG LST, I got the same device. Two options that you may want to try (and there may be a third). 1st) Make sure nothing has happened to your DVI cable, make sure it is tight on both ends. Undo it and blow on the connectors and resecure it if need be. HDCP involves communication between the HDCP chip on your LST and the HDCP chip in you display. If you cable is loose, dog chewed or too long then it may be interfering with your HDCP handshake. 2nd) You should be able to go to RGB display option and dispay in HD over the same DVI cable. This was discussed much in the forums I have been reading about. I hope one of the above options helps you. In fact I hope the vacume or kids knocked the cable slightly loose and you are back in business after tightening it. The 3rd option would be to do a google search for LST-3510a and HDCP, you will find all kinds of solutions, work arounds and firmware update discussions. Good luck! Scott
Sep 26, 2006 | LG LST-3510A DVD Player/Receiver
Elegant Home Fashions Madison Avenue Linen Tower Bathroom Shelf - CF5QOE Logo
998 people viewed this question
Top Elegant Home Fashions Home Experts
john h
Tom Chichester
Are you an Elegant Home Fashions Home Expert? Answer questions, earn points and help others
