Question about Janome D'cor Excel 5018
How do i stop geting puckering when sewing - Janome D'cor Excel 5018
  • Janome Master
  • 10,020 Answers
Frequently, puckering is caused by the tension(s) being too tight. Check your manual for troubleshooting tips.
Posted on Apr 19, 2015
  • 86 Answers
A lot depends upon what you're sewing on, thread, needle, etc. But here are some basics for this problem:
1. Clean your machine! The most common cause of many sewing problems is smutz caught in the bobbin area or tensioning disks.
2. Change your needle and be sure it's the right weight and type for what you're doing. Using a heavyweight needle on lightweight fabric or a 'sharps' needle on knits or an old needle are common causes of puckering.
3. Make sure the thread you're using is appropriate for the fabric and needle. Using light thread on heavy fabric or vice versa can cause puckering as well.
4. Check your tensioning, both upper and bobbin.
5. Take it in and have the timing checked.
Posted on Apr 17, 2015
Singer model 2638 puckers fabric when sewing straight stitch. Have to manually keep fabric taut behind needle to get anything accomplished. Why does this occur and how can it be fixed?
If the fabric is puckering when stitching, usually it is because the tension is too tight. You may need to loosen both the top and bobbin tensions.
Another time the problem occurs is when sewing fine fabric (like chiffon). The fabric does not have enough body to lay flat, so it puckers. You can utilize a stabilizer to help give the fabric body (washaway or tearaway stabilizer, or even use light-weight paper such as adding machine tape or even toilet tissue). Sometimes some spray starch is enough to help it lay flat.
How to Prevent Puckering Sewing Machine
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&ved=0ahUKEwih76G2yuHNAhVBVWMKHV-1DiEQFgggMAE&url=http%3A%2F%2Fwww.amefird.com%2Fwp-content%2Fuploads%2F2010%2F01%2FMinimizing-Seam-Puckering-2-5-10.pdf&usg=AFQjCNF6q0Pk13ZU4Hb3o3RiAGBbL04l-A&cad=rja
http://www.beaconfabric.com/vindex.html?SelectingtheRightStabilizer.htm
http://www.coatsindustrial.com/en/information-hub/apparel-expertise/seam-puckering
Jul 06, 2016 | Singer Sewing Machines
ZIGZAG STITCH PUCKERS MATERIAL
Most sewing machines will cause puckering when zig-zaging, especially when sewing light-weight fabric like chiffon, etc. Try a brand new needle. You can try narrowing the zig-zag so there is not such a large gap between the left & right swing. Can also try loosening the tension a bit so the thread is not pulling so tightly. Another possibility (if your machine has the capability) is to increase the presser foot pressure so there is more pressure applied between the presser foot and the feed dogs. Or, try using a layer of wash-away stabilizer or clean (unused) newsprint paper with the fabric to help give it some stability.
How to Adjust Sewing Machine Tension on Craftsy
How to Prevent Your Sewing Machine from Puckering Fabric Howcast
https://groups.google.com/forum/#!topic/alt.sewing/AOhNY36JOa0
May 22, 2016 | Sewing Machines
Need help with tension as thr stiches are puckering.
If the fabric is puckering when you sew, it is most likely because the thread tension is too tight. Make sure you are using a brand-new needle compatible with your fabric--using a 70 or 80 needle and a lighter weight thread may work better as a 90 or higher needle is big enough that it can stretch the fabric before penetrating it, causing puckering.. Puckering also occurs more frequently when sewing light-weight fabrics and may necessitate using a walking foot or a stabilizer to help give the fabric more body as it is stitched (wash-away stabilizer would probably be good when sewing washable fabrics). Another thing that may cause puckering is when the bobbin is wound at a fast speed. Slowing down when winding the bobbin will reduce the amount of stretch added to the bobbin thread. If it is stretched going onto the bobbin, it will shrink back up when it is stitched to your fabric. Also check whether your machine has a presser foot pressure adjustment. The pressure should be lighter when sewing finer fabrics, ie silk, and heavier when sewing thicker fabrics like wool or denim.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=6&ved=0ahUKEwjcuq2nkIPMAhXlxIMKHVgUAqUQFgg1MAU&url=http%3A%2F%2Fwww.amannusa.com%2Fpdf%2Fnahtkraeuslen_gb.pdf&usg=AFQjCNE-YAZ5WB1V7bFGptxZojumhoodMQ&cad=rja
Stitching is puckering on lightweight fabric SEWING IN GENERAL
All About Needles
Apr 10, 2016 | Sewing Machines
Waht is the best thread to minimise puckering
Depends on why the machine is puckering. Take a look at: http://www.amefird.com/wp-content/uploads/2010/01/Minimizing-Seam-Puckering-2-5-10.pdf Usually, if it is a thread puckering problem, winding the bobbin thread more slowly, using a less elastic thread like a cotton, and reducing machine tensions will help.
Apr 28, 2014 | Janome Sewing Machines
Elna sewing machine fabric is puckering
Check tension and threading up first, sounds like top tension or thread catching somewhere. Also have you changed the needle, i change mine for EACH new sewing project, needles go blunt and need replacing every 4-6 hours of sewing. Lastly, press seams as you go, this improves appearance and blends stitching into the fabric,
Mar 05, 2013 | Elna Sewing Machines
The thread is not straight when I sew
Puckering can be caused by wrong size needle/thread combo. Tension issues... improper threading. Check these first.
Dec 02, 2012 | Janome Magnolia 7330 Sewing Machine
I have a bernina 210 model sewing machine. I'm
#1 Use only Mettler or Gutermann thread. Coats thread is very rough and will pucker the fabric. #2 Make sure that the tensions are balanced. #3 Use the regular zig zag foot. #4 Use a new needle, universal, size 80/12. A blunted point will pucker the fabric.
Jun 02, 2011 | Bernina Activa 140
Brother Super Galaxie
Does it pucker when you are embroidering or just sewing in general? If its puckering when your embroidering it could be a few things. 1. no stabilizer 2. the fabric stretched in the hoop too tight. 3. check you tension
Oct 23, 2007 | Brother SE-270D Computerized Sewing...
Puckering material
You may need to utilize backing to correct the puckering, and/or if possible, also sew on the bias. I do not have enough information to interpret the origin/cause of the "noise". Please click on the URL below for helpful information in correcting typical stitching and machine woes....good luck my friend: http://www.fixya.com/support/t162553-underthread_going_crazy
Jul 26, 2007 | Toyota SE-06 Mechanical Sewing Machine
Sewing Machines Logo
77 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
