Question about Garden
Lose drive power after mowing awhile 20 min. or so is a hydrostatic forwards or reverse, motor runs fine, cuts good after setting 40 mins. or so runs good for awhile cooling fan seems to work ok
    Sergeant:
  • Garden Expert
  • 187 Answers
Unfortunately, it does sound like the symptoms of a failing transmission. You don't say how many hours are on the meter and how often you have changed the tranny fluid. What follows is a general discussion of Hydro-trannys. If this is your problem the info may help.
For a machine specific diagnoses we need
Make
Model
Year
Engine Model (Briggs engines,look above the starter on single cylinder models, opposite side on twin cylinder models)
Transmission Model (sticker on back of tranny axle)
Deck Size
Hours on meter (indicates wear patterns and problems that only occur with time.)
If you haven't already done so, add a short description of the events preceding the beginning of the problem.
The NOT SERVICEABLE UN-TRUTH.
The Huskvarna YTH150 uses Hydrogear transmission 319-0650, drive model 150071. One place to find parts and diagrams for most Huskvarnas is here: http://www.m-and-d.com/Hydro-Gear_parts.html
MTDs use Hydrogear trannys also. Go to the site and enter 618-0319 in the search box. It will bring up a selection of MTD transmissions.
Sears Craftsmen mowers also have trannys from Hydro-Gear.
The best lawn tractor Hydrostatic Transmission Fluid is actually 10W-50 synthetic motor oil (like Mobil 1). Do not use hydraulic fluid or transmission fluid.
Hydro static transmissions on most lawn tractors are very similar. Most of them are made by one or two manufacturers. Tuff Torq makes a lot of them, but not the Huskvarnas. They do make all the John Deere lawn tractor hydro drives. The lawn tractor manufacturers (like JD) often say they are sealed and not serviceable. That is flat out, an untruth. All of the JD hydros, and most all others, are serviceable. A complete line of rebuild/replacement parts can be found at Tuff Torq. Info and instructions can be found there. They have a lot of good general info for anyone rebuilding their tranny.
Additionally, I have found that the mower manufacturers fill them (or spec them) with motor oil, 10W-30W. In the service manual, and at the hydro manufacturer, you are told if your tractor is used in extreme or heavy duty situations it's best to drain the oil and replace it with 10W-50 synthetic motor oil (like Mobil 1™). Truth is the tranny should have this oil from the get go. It will give you more power and extend the life of the tranny. The mower manufacturers are all just being cheap. They figure why not, you're the one who has to pay for the early failure. Oh yeah, one other minor detail, the tranny manufacturer also recommends regular oil changes, like every 100 hours.
Virtually all of these trannys have a black drain plug on the top, if they do not have the add on reservoir. You have to remove the tranny from the mower (not a difficult things to do, it takes about 30 min). Pull that black plug (I used a 1" putty knife to pry mine out) and turn the tranny upside down for about 30 min to completely drain. Most hold about 2 quarts. Flip it back, right side up, and refill. Install plug and reinstall tranny. Note: under the plug there is often a magnet which collects metal shavings. Lift this magnet out while you have the plug out; clean it and replace it. It may fall out while the tranny is upside down. If anything else falls out, you have a broken tranny and will have to take it apart.
When you refill the fluid just keep filling till it comes up within a quarter inch of the plug. You may have to go through a bleed process after reinstalling the tranny. The tuff torq site explains the bleed process.
Tuff Torq Lawn Garden
Posted on Apr 16, 2015
    Top Expert:
  • Garden Master
  • 43,079 Answers
Blow all the dirt and grass away from the cooling area of the transaxle it can not cool properly with grass plugging the fins
Posted on Apr 15, 2015
    Top Expert:
  • Garden Master
  • 42,190 Answers
Hydrostatic units are re-nouned for failures
Talk with the service dealer as to what oil to use, how much to use , when to change
2008 cub cadet rzt 50 run for 20 min than dies while mowing put new pump on, new fuel filter, new air cleaner, new plugs. has a 22hp kawasaki engine. fuel lines clear
When it stalls out did you check the spark? I suspect the engine is losing spark due to an ignition system failure.
May 17, 2017 | Cars & Trucks
21 hp B@S engine exhausting blue smoke
sounds like blown head gasket.
does it have a fuel pump, if so is there oil around it (by the brass colored screen)
if so then you have blown head gasket
Oct 24, 2015 | Craftsman 46 In. 21hp Briggs & Stratton...
Toro zero turn wont go forward or reverse
zero turn has 2 hydrostatic transmissions. Check drive belt, pulley tensioners for clog.
Remove clog with stick instead of your fingers if in the way of mechanism, belt or pulley wheels.
Check to be sure belt is taught and pulleys move. wd-40 is ok .
Do not get wd-40 onto pulley guides, or pulleys but only to tensioner mechanism and springs.
Paper towels are good spray blockers, wrap belt in paper towels if wd-40, do not use white lithium spray but only small amounts of grease when perform full breakdown and assembly maintenance on deck and drive.
The hydrostatic pumps might be drain&fill possible if they each have a vent hole and a drain plug next to vent hole somewhere. Clean them up with carb cleaner or use starter fluid if really nasty build up. Then check for hex tool drain plug and vent hole or vent cap over hole. Do not use vent hole for topping off hydro's
Jul 11, 2014 | Garden
My Craftsman lawn tractor with 19 horse B & S Twin with hydrostatic transmission loses speed and power in forward and reverse as it warms up. Within 20 minutes reverse will be gone and forward mo
more than likely your low on transmission fluid. I heard alot of this pertaining to hydrostatic transmissions on yards with inclines. I would check your fluid level .
May 14, 2014 | Craftsman Garden
Husqvarna Riding Lawn Mower Yth24v48ls 48 Inch Cut hydrostatic transmission slipping
first i would check the belt tension also check the belt for oil is so look for the cause of the leak the repair the leak and replace the belt
Jul 30, 2012 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
My toro zero turn seems to overheat and stops moving from left side about half hour it runs fine.?
First check to see if you have any leaks especially on the problem let side. This includes the wheel motor. where hydro oil comes out, air can go in. either way it sounds like you need to take your pump out and open it up and check for metal inside. If you do not have any metal inside check the 5 pistons to see if they are stuck. What series hydro pump do you have?
10L 10A etc.
Jul 28, 2012 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
I have a L118 John Deere mower. When cold, the mower moves forward and reverse without problems. I mow my 1/2 acre yard and at the last couple passes, the mower barely moves forward and has no reverse. ...
Hi, remove the battery and battery support tray and clean all debris from around the hydrostatic drive, fan and cooling fins. Your problem is caused by the hydrostatic drive overheating. Hope this helps, regards Phil
May 23, 2011 | John Deere Garden
Craftsman 19.5 riding mower starts runs quits no power
When you let it sit did you remove all the fuel or add a additive? If you did not then I would recommend that you remove all the fuel and add brand new fuel to your system. Gasoline only last for about 3 to 4 months before it will start to go bad and this sounds like your problem
May 22, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Ariens Yard Tractor 935 Series - initially drives, then stops moving as it gets warm
Is it a hydrostatic tranmission? If so, sounds like the fluid might be old or not the right viscosity. Recommend changing the trans fluid, and use recommended viscosity of fluid.
Sep 12, 2008 | Garden
Garden Logo
85 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
