Question about Jenn-Air JGD8130 Gas Cooktop
Have cast iron grates with no enamel on them. Burned on grease, etc on grates from previous owner. Can I clean them in a self cleaning oven? If not, what is best way to clean? Thankyou.
    Top Expert:
  • Jenn-Air Master
  • 43,095 Answers
I would spray them down with a good oven cleaner ,outdoors and let them sit there soaking a couple days . then wash off and see what they look like .
Posted on Oct 04, 2015
How do i lock the self cleaning ge oven door when i put it on self clean
If you have a self cleaning oven, the door will lock automatically as the self cleaning begins. Give it some time ,it will happen. When cleaning is done it will take a while for the door to unlock. GOOD LUCK FRIEND.
Nov 08, 2014 | General Electric GE 24" Single...
I have black swirl scratches from using abrasive sponge on front of black oven door
There is this white stuff sold for glass-top stoves. I presume it is good old iron cleaner, a very mild cleaner/polish. Also consider toothpaste.
Dec 01, 2013 | Amana 30" Self Cleaning Electric Range...
Adjust flame
Do not attempt to do this task yourself, you should call a Gas Safe engineer to solve the problem.
Jun 29, 2013 | Verona CTG424SE Gas Four Burner Cooktop,...
Wfg361lvd
If you have a standing pilot (always lit), the adjustment screw is normally located behind the burner control knobs.
Dec 22, 2012 | Whirlpool WFG361LVD - 5.0 Cu Ft,...
I cannot get my burners on my stainless steel gas stove top clean
What I would try. Assuming the "burners" means the cast iron assemblies on top of the stainless steel, remove them to an area outside. Perhaps on a piece of plywood, and clean them with oven cleaner. Grease may drip off them, so a deck or driveway are unacceptable. Wear gloves and watch splatters. Wash thoroughly with fresh water before reusing. Beware. Caustic chemicals can discolor stainless
spencer
Aug 20, 2010 | Thermador 37 in. SGSX365 Gas Cooktop
Grease-encrusted cast iron trivets
Try soaking in hot soapy water that you've dropped several denture cleaning tablets in. That's helped me get some tough stuff off, or at least loosened up enough that some elbow grease and a scrubbie can finish off the job.
Put them in the oven and run the self clean cycle
Oven cleaner. That stuff is second only to industrial grade hydrogen peroxide
Batender's Friend. That stuff is amazing!
Good Luck
Jul 31, 2010 | Viking 31 in. VGSU101 Gas Cooktop
Can you put the top oven grates in the oven while it is self cleaning
The top burner grates are designed to handle direct heat in excess of self clean temperatures.
You can put the grates in to the oven during self clean... but it will not clean them. The baked on residue needs some chemical reaction to break down the reside on them. I would suggest soaking them in an oven cleaner like easy off. Spray them down good then using rubber gloves put them into a plastic garbage bag, spray them again in the bag and close it up. Let them sit and soak for an hour or so then wash them off. This is best done outside so the odors will not be in the home in an enclosed area.
Apr 26, 2010 | GE Profile JGP636 Gas Cooktop
Enamel chips and flakes revealing the iron
anything gas same problem no matter what it gets super hot, unless u get like a heavy duty porcelin or a darker color the heat is too much
Feb 26, 2010 | Cooktops
Stained gas range burner grates
Hey y'all. I have the same lame GE profile gas cooktop with the gray grates and burner covers. I know this is the expensive way to go, but I use Easy-Off "self-cleaning oven" oven cleaning spray. For about $5, you get 3 cleanings. It is a pain to do, but I have better things to do than scrub these grates all the time. I don't know why, but the baked on crud just drives me crazy. I tried everything to clean them completely. I even tried to scrub the darn things with a kitchen pumice stone(sold at walmart)but it is impossible to get the curvy areas clean. Now the paint has started to wear off on the burner covers.
I do not use the oven cleaner on the cooktop itself. I use soft-scrub with baking soda, then cover the cooktop with a sheet of heavy duty aluminum foil and cut out holes for the burners. This keeps most of the spills contained, and helps with cleanup.
I visited to the GE parts web page, and they only sell gray grates and covers. I am going to buy black BBQ grill paint(spray can)from Home Depot and try it on the burner covers first. They are the least expensive to replace if it fails, and if it works, I will paint the grates with this high temperature paint. I will keep you posted on the results.
Regards,
Laura D.
Feb 14, 2009 | GE 30 in. JGP337 Gas Cooktop
Cleaning grates of GE profile gas stove
Sounds crazy, but this works. Soak the grates in warm to hot water with 2 dryer sheets (Bounce), let them soak for an hour or two. Unbeliveable how they came clean. I did have to use a Scotch Brite pad on the two that I use most, but it sure beats replacing them.
Jul 02, 2008 | GE Profile JGP636 Gas Cooktop
Jenn-Air JGD8130 Gas Cooktop Logo
236 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
paulcarew
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
