Question about Boating
I have a short shaft Johnson 6hp outboard, the Jon boat I mounted it on is too deep, and motor doesn't reach water. Is there a way to lower motor? A bracket to lower motor to reach water?
    Top Expert:
  • Boating Master
  • 50,093 Answers
Outboard motor manufacturers supply a long shaft leg for just this problem
Talk with your Johnson dealer and check used outboards on e bay
Lowering the whole motor may affect the boat and floatation aspects besides making it harder to steer and start
Posted on Apr 15, 2015
Fame_Guru
  • 483 Answers
SOURCE: Yamaha outboard motor manual
You got it :
http://www.yamaha-motor.com/outboard/service/viewmanuals/outboard_manuals.aspx
here !
Posted on Mar 20, 2009
captainjeffq
  • 52 Answers
SOURCE: 1974 60hp johnson outboard won't run on full throttle.
Carbs probably need to be cleaned and re-built. Common problem in outboards that havent been run in a while
Posted on Apr 13, 2009
  • 6 Answers
SOURCE: 35hp Johnson evinrude outboard not running at full potential
Hi, did you buy your engine used? Sounds like your gonna have to get the carb or carbs cleaned. Its possible you could have a stopped up fuel filter, or not enough spark but i am guessing its gonna be the carbs. They got some gunk in em i bet. Probably old fuel turned to gunk from setting up. I had the same problem on my 40 horse.
Posted on Aug 22, 2009
Testimonial: "Hi, thank you very much for your help, I will strip the carb down and have a look. Once again, many thanks, I am very greatful"
  • 10865 Answers
SOURCE: 6hp Johnson outboard stalls & quits
go to an auto parts store and get a can of gasoline additive called seafoam. Read the label so you know how much to add to your 6 gallon tank. This stuff works wonders on outboard motors.
Posted on Sep 16, 2009
SOURCE: how to remove the lower unit on a 35hp Johnson outboard yr 2000.
if you haven't fixed this already, take the pastic water pick up covers off there are two joiner nuts in there undo them, there is a plastic cone on each end take them off and it will slip through. I own the same model and year outboard.
Posted on Jan 13, 2010
I have a 50 hp Johnson outboard or do I disconnect the shift linkage to get the lower unit off
have a look at the videos
How to remove the lower unit on a outboard engine - YouTube
? 3:24
https://www.youtube.com/watch?v=R6wVMc8GD0w
Mar 29, 2015 - Uploaded by Greg Drinkwater
How to remove the lower unit on a 1989 Johnson 88 SPL Help me remove lower unit. Johnson 90 hp ...
Johnson 50hp Outboard Lower Unit - YouTube
? 2:15
https://www.youtube.com/watch?v=DnU7vKcJkeE
Apr 9, 2016 - Uploaded by Stacy Wyoming
Removing Bearing Housing From a 50 HP Evinrude - Duration: 2:15. Brandon's Garage 274 views · 2:15 ...
how to remove lower unit on johnson outboard - YouTube
? 0:47
https://www.youtube.com/watch?v=_ygxZSxU6-I
May 24, 2016 - Uploaded by 2222buster2222
How to remove your lower unit on a 1984 Johnson Outboard 70HP.
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump ...
? 24:26
https://www.youtube.com/watch?v=Hv8gXqsO2fg
Jun 3, 2015 - Uploaded by Ralph Pierre
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump Service. ... Just bought a Bass Tracker ...
50 hp Johnson outboard remove lower unit Google Search
Jul 07, 2017 | Johnson Boating
6hp johnson outboard repair
cut down or oil in mixture. test tanks never a good idea as that is too much load for small motors
Jun 25, 2014 | Boating
Can't get 1976 evinrude 6hp to pump water I changed water pump
have you changed the impeller inside the lower unit.
There is copper pipe to redirect water up into the engine.
When you replaced the impeller make the copper pipe is insert onto the engine.
Jul 31, 2012 | Light Outboard Motor Boat Bass Fishing...
Johnson 6hp outboard engine fuel pump diagram
Here is where you can get a service manual, they have a lot of info you might need...
Johnson Evinrude Manuals 1917 2007
Jun 11, 2012 | Johnson Boating
How to adjust timing on johnson 6hp outboard motor
look at a manuel i think it is automatic in the switch no manuei adjustment get it timming through the cd like some of the mercks
Nov 08, 2011 | Light Outboard Motor Boat Bass Fishing...
I need to change a water pump on a johnson 6hp outbord moater. modle no. 6R-70B
unbolt lower unit and you will be right there . shift rods vary so check where it is and how to unhook.
Mar 15, 2010 | Light Outboard Motor Boat Bass Fishing...
Sep 16, 2009 | Boating
I have a johnson outboard motor that drips oil from the prop.why is this ?,maybe a seal is blown?
Yes the prop shaft seal needs to be replaced.Do this sooner than later as water will get into the lower g/box.Sometimes they wear out or fishing line is a bad culprit.Its not a big job but it really needs to be done.The oil will also need replacing.Hope this helps
Sep 09, 2009 | Light Outboard Motor Boat Bass Fishing...
2002 15hp mercurty 2 stroke long shaft need 2 know installation specs 4 propeller depth from top of transom model # 1015211zd
I have a 1979 Johnson 15hp Long shaft, and as a single motor just followed the rule of a shortshaft motor for a short transom and a longshaft for a deep transom. You have a little adjustment in the mount clamp. You want enough shaft not to cavitate and want the trim fin below the hull. If this is a kicker motor you want it deep enough for water pickup but less deep for drag on fixed mount.
May 11, 2009 | Boating
Boating Logo
223 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
