Question about Coby Audio Players & Recorders
My COBY MP620-4G MP3 payer doesn't take charge. Perhaps, the built-in battery is dead. Please advise how and where could replace the battery. Thanks Joe
SOURCE: coby mpc7095 mp3 player
try resetting the device while plugged into your computer... also some of the pins might be bent inside de port of the player, make sure they are correctly set with a flat, small tool, what do you have to lose?
Posted on Apr 14, 2008
snow_cedar28
  • 12 Answers
SOURCE: Charging the coby clip 1gb m582 mp3 player
the manual says something about turning the player on when inserted into the usb port so it  can charge
Posted on Mar 10, 2009
SOURCE: my coby mp3 player is completly dead and will not turn on when charged up or reseted
how do you try to tourn it on try charging it to a point to where it wont even do anything and then try it
Posted on Jun 02, 2009
YourZEN
  • 820 Answers
SOURCE: How do I recharge Coby MP3 player? I plugged into
Coby MPC7085 requires a 12 hours charge when used for the first time.
Always use a direct connection to the computer when charging with the USB cable: a hub or cardreader should be self-powered.
See page 12 of the manual:
http://www.cobyusa.com/files/manuals/MPC7085_MN.pdf
Posted on Sep 28, 2009
Testimonial: "This was very good info. Thanks."
  • 13 Answers
SOURCE: Not sure if player is charging
QUESTION ONE:
Can you see it in "My Computer"? It will show under "Removable Drive/Storage"
QUESTION TWO:
Double click the removable drive to open the folders. Can you see your music, photo and movie folders?
QUESTION THREE:
Can you see the player in Coby Manager - under the "DEVICE" tab?
QUESTION FOUR:
When disconnected from the computer, how long can you listen to the Coby player before it goes off?
If not present in My Computer or in Coby Manager/Device Tab, then it is not plugged in correctly.
a. Disconnect the player from the computer.
b. Wait for it to cycle through "Please Wait" and "Updating Library" screens.
c. Make sure the player is TURNED OFF
d. With player TURNED OFF, reconnect wire to the player then to the computer.
e. You will see a USB connector icon on the player screen and the player charging.
It will appear to be charging all the while it is connected to the computer.
After it has been plugged into the computer for an hour, it should be well charged unless the battery is completely run down. In that case, you need to do an initial 8 hour charge - with the coby player OFF - through the computer. (This one got me when I first got my player!)
f. Use the Coby Manager to disconnect the player (Found HERE CobyMedia Manager fix for MP822 (Windows XP/2000/Vista)
1. Open Coby Manager
2. Go to the DEVICE TAB
3. CLICK on EJECT Button in lower right hand corner.
4. It will have a pop-up screen to ask "Do you want to eject?" Click YES.
5. The second pop-up screen will tell you "The device can now be safely removed from the system."
6. Disconnect the player from the computer.
7. The Coby will now show "Please Wait..."
8. It will take the Coby about 10 minutes on the "Please Wait" screen and then on the "UPDATE the Library" screen - Be PATIENT
You should now have enough battery power to use it. To check the battery level,
1. Turn on the player
2. The battery icon is in the upper right hand corner of the screen - it is ALWAYS RED until it starts to go down... I've not had mine down very far, but believe the red line gets shorter as the battery is wearing down.
Hope this helps.
Posted on Apr 10, 2010
Why won't my mp3 coby player won't charge
Your coby is not charging anymore..The battery probably needs to be replaced with a new one..Please check your connection when you charge it..There should be an icon that shows your battery is charging. If it does so that means your coby is charging but your battery cant store the energy anymore.
Feb 19, 2012 | Coby MP-610 MP3 Player
My coby mp826 mp3 wont turn on when i try to turn it on and when i plug it in to charge my cp wont decdect it and it wont charge it doesn't even turn on when i plug it in
Sorry to say it but it sounds like it is dead. You could try to leave it alone for at least a day to potentially kill off the battery in case of a firmware crash, then try charging again, or press and hold the power switch for 15-35 seconds. Other than that, I have had similar issues with rather cheaply built mp3 players, which are fragile to drops, faulty firmware, and of course, water.
Jun 01, 2011 | Coby MP826 MP3 Player
Battery problem
This problem is due to a bad battery. All rechargeable battery have a charging limit of upto 1000-3000 charges, after that it will loose its ability to get charged, so you will have to replace the battery.
Jun 05, 2010 | Coby CBY705 MP3 Player
How come my mp3 player doesn't charge? i hook it up and all i see is a dead battery!! please help me!
Use a cellular phone charger !
I have a motorolla, and it's the same plug. Just make sure the player says "charge". You may have to play with the on/off switch for that.
Apr 11, 2010 | Coby MP-C582 MP3 Player
I have tried to charge and it will not charge
Hello :
First check the charger or the power cord . If they are OK , then I recommend you to replace the battery , because it seems that the battery is dead [ can't be recharged anymore ] .
good luck .
please rate !
Mar 30, 2010 | Coby MP300 MP3 Player
MY COBY MP3 WONT TURN ON EVEN AFTER CHARGING AND
The most common cause is a flat battery. There is a trick to charging the battery in these small mp3 players. It wont charge if it is turned on, and it won't charges if it's turned off. Here what to do...
1. plug the payer into your USB port. or wall charger
2. switch thje palyer on using the mechanical switch (on the side)
3. turn it off by either holding down the play button, or selecting "System" from the menu
4. The screen will go black and the battery will begin charging.
Mar 27, 2010 | Audio Players & Recorders
I just purchased 2 8 gb mp3 players and i can't get them to charge. help
Check the usb players if they are working well. 2ndly, hope the battery cells are not dead, because you need to charge an mp3 player to full first before usage. If they are dead then you might need to replace them.
Dec 27, 2009 | Coby MP-C7085 MP3 Player
Its frozen saying please wait and wont charge
replace battery of your player it may be dead.
Dec 25, 2009 | Coby MPC-848 MP3 Player
My coby mp3 player is completly dead and will not turn on when charged up or reseted
Jun 01, 2009 | Coby MP-C7085 MP3 Player
MP3 Player Not Charging!!! (USB)
on, and it won't charges if it's in sleep mode (zzzz). Here what to do...
2. switch thje player on
Feb 15, 2009 | Coby MP-C7092 (2 GB) MP3 Player
115 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
