Question about Garden
I have a 95 John deer Saber. I have an electrician issue. I have a new cellinoid, bypassed the seat safety switch and also the clutch safety switch. It jumps off and runs great. What's my next move?
    Top Expert:
  • Garden Master
  • 44,387 Answers
Fix the faulty wiring or switches as they are a part of the safety for the machine
Posted on Apr 15, 2015
2 Suggested Answers
  • 4134 Answers
SOURCE: I have a 1995 John deer sabre. It won't start unless I jump It. I've changed the silinoid, bypassed the seat safety switch and the clutch. Everything has juice. What's my next step?
You're saying that it will start if you use a booster battery (jump start)? If it starts and runs but then needs a jump again next time you want to use it, then you have either a bad battery or a bad charging system.
Posted on Apr 14, 2015
John Deere 790 stalling out
My problem with my John Deere 790 stalling was my safety seat switch. It's a quick fix! What I had to do to fix my 2006 John Deere 790, was:
1. Un-hook the switch wires under the seat that connect to the seat switch.
2. Then, connect all of them with little wire clamps (or you can use a raw wire and connect them all) inside the wire connector, with the 4 connectors in it, to bypass the seat switch. Hot wire all of them together. It somehow resets the switch.
3. Then, with my 790 Deere in neutral, I started it up and held the key in starter position for about 2 seconds. (Instead of letting go right when it fires up) Somehow, in doing this, the seat switch reset and I was able to reconnect the switch and the seat switch works as it should now. My Deere 790 front loader fires right up without stalling now, while in neutral, of course. So, try this first because it's a quick fix. I hope this helps.
Cheers,
Aaron
Nov 15, 2013 | John Deere 420,1020,2010,2020,2510,2520...
My 155c John Deere will not start! Brand new charged battery....I turn the key...nothing(no clicking either). When bypassing it to cellinoid, it starts right up. When I shut off the mower, I have to...
Usually when the key is turned to start position the starter soleniod engages thus applying power to the starter. There are three possible causes to your problem . (1) Check for 12vdc at the terminal on the soleniod when the key is turned to start position, if there is 12vdc at the terminal then the key switch is good. (2) loose or bad cable connection at the soleniod, check connections. (3) bad soleniod -- replace it. generally you will hear a click from the soleniod when the key is turned to start position. Also be sure to check that ALL safety switches are engaged. You may need someone to sit in the drivers seat so that switch will be "made" / engaged. Park Brake is set, mowing blades are "NOT " being engaged, on some mowers if the transmission is in reverse ,even tho the brake is set the mower will not start.
Nov 10, 2013 | Garden
John Deere L110 riding mower automatic won't start
have you checked the micro switch under the seat
May 31, 2013 | Garden
L130 John Deere PTO problems
you have a bad seat switch
Sep 21, 2012 | John Deere Garden
John deere 116 briggs & straton wont get spark. new coil, still nothing. will try to bypass seat safety switch.
there is a black wire a that goes to the ignition on the side of the engine next to the manifold unplug that and see if you get spark with that off if you do follow that wire back to the safety switches
Apr 06, 2012 | John Deere Garden
John Deere f1145 front mower's engine stops
You must be in the seat to run the mower ... safety interlocks ... operator presence control is what it is called.
May 02, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Wanting to by pass seat switch for john deere ride on lawn mower
the seat switch is a safety feature mandated by law. it would be illegal and a liability issue for anybody on this website to instruct you how to bypass the switch
Sep 26, 2009 | Garden
It is not fireing
These mowers have several safety switches that disable the ignition when a safety problem could exist. Switches may have to be bypassed for troubleshooting and service, one on the seat, one on the blade clutch and one on the transmission or drive clutch. First close the covers, sit in the operators seat, disengage the blade and transmission and then attempt to start it, Chances are if you ran out of gas the mower deck is still engaged.
Good Luck.
Sep 01, 2009 | John Deere Garden
Garden Logo
60 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
