Question about Garden
How do you start it?
I am trying to start this leaf blower and I am not sure if I should have the choke vertical to start or horizontal. Also where the trigger is what does the I and O mean
  • 2,760 Answers
I means "ON" and o means "OFF"
choke should be closed to richen the fuel mix to start open it slowly after it starts and runs
also note most (2cycle) gas powered leaf blowers require a gas/oil mix to run properly , straight gas will destroy blower motor
Posted on May 28, 2015
boscia
  • 163 Answers
SOURCE: mightylite 26 leaf blower
have you tried changing the air filter and spark plug?
Posted on Nov 29, 2008
bbreton
  • 437 Answers
SOURCE: mb 3200 gas leaf blower will start when choke
The carburetor could need rebuilding or you have some bad gas. I would mix up some 2 cycle oil and fresh gas from the station. I would try the new fuel mixture first.
Good Day.
Posted on Nov 02, 2009
SOURCE: My Homelite Zip start Leaf Blower dies when I turn
Gas Aluminium Cable head is broke.
Posted on Apr 06, 2010
rycgl
  • 1545 Answers
SOURCE: my leaf blower runs at half choke but only for a
This sounds like a fuel delivery problem. Check the fuel filter and also the carburetor bowl and main jet. Make sure the fuel lines and the carb are clear and clean.. Carb may need to be removed and cleaned....it's not picking up the fuel and delivering it to the engine. There may be some small debris that has entered the carb and is stopping the complete flow of fuel.
Posted on Jul 18, 2010
gvince4
  • 31 Answers
SOURCE: my leaf blower will not remain running unless the
you need the carb adjusted.
Posted on Nov 26, 2010
I recently tuned up my blower. It starts great but if I turn it off Nd try to restart it it floods and will not start until I let it sit for awhile.
If the engine is warm and you shut it down, leave the choke off, lower the revs and start it. (when the choke is wide open you are using the fresh air coming in to dry the spark plugs and prevent flooding). If the motor is already flooded use that procedure to dry the plugs, then go back to full choke until it tries to start and quits again, then use half choke and pull one more time... works all the time.
Oct 22, 2013 | Echo Pb-251 Leaf Blowers
What is the starting procedure?
Start with the choke on full press the fuel siphon button till the lines are full of fuel. pull handle until it tries to start but stops. move the choke to half then start again. let it run for 60 seconds on full. don't move the choke to full or it will stop. Either slow the revs and then put the choke on full or keep the revs high and slowly move the choke to full (to allow the governor to slowly advance with the new revs)
Nov 03, 2012 | kawasaki Krb750b Backpack Leaf Blower
My homelite blower starts but after on run position shuts down
Ck and see if it has a choke. If it is on full choke, reduse choke after you put in on full run.
Oct 05, 2011 | Homelite 'Yard Broom' Leaf Blower
Leaf blower wont stay started, ran out of gas earlier is it flooded
you have pluggered the primer bulb untill it got full of gas set choke then tried starting it
Nov 08, 2009 | Husqvarna 155bt Gas Backpack Leaf Blower
Mb 3200 gas leaf blower will start when choke
Good Day.
Nov 02, 2009 | McCulloch 26cc Gas Blower Mcb3208
Homelite leaf blover run with choke soon when chokeis off ,cant rev up and die
if he put fuel in it dump it out & put yours in it , if problem persist there are 2 screws on the carberator turn the 1 on the right or th bottom 1/4 turn to the left!
Jun 02, 2009 | Homelite 'Yard Broom' Leaf Blower
I am trying to start my homelite leaf blower but i dont have the starting instruction sticker that came on it. the sticker had all the steps on how to adjust the two valves, throtle and choke. so if...
Hello ben_brumett:
On My Homelite Blower I Simply Set the Throttle Lock. Pull Out the Choke (on the other I Move a Lever) and Turn on the Switch. Now Pull Until it Starts or Attempts to Start. Remove the Choke and Allow it to Warm Up for 2 or 3 Minutes.
You can Get a Manual from the Following Site Addy;
https://register.homelite.com/contact_us/new and Fill Out the Required Information. Remember to have the UT Number if this Unit has One.
Apr 17, 2009 | Homelite 'Yard Broom' Leaf Blower
Echo pb 200 leaf blower want start
Turn on ignition switch, Choke, prime bulb 5 times (or until fuel flows), hold throttle down and pull starter cord sharply until it tries to start, then place choke in mid position pull cord sharply again until it runs then move choke to off when it will allow it.
Also you can go to toro.com then customer care, then manuals and parts then type in model no. and download an owners manual.
Apr 06, 2009 | Echo Garden
Garden Logo
146 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
