Question about Liebherr Premium Plus HCB1560 30" Fully Integrated Bottom-Freezer Refrigerator with Glass Shelves, BioFresh Compartment, Ice Maker, 2 Freezer Drawers and Requires Custom Panels/Handles: Right Hinge Door Swing
How to retrieve the relay from compressor Zel GVY53AD
Our Coke machine door was accidentally left open for days. Because of this, the compressor is shot. $800 is a lot to throw away over a $130 compressor. Help !!!!
I would contact tecumseh refrigeration compressors. It will still cost a pretty penny to replace. Proper diagnosing tel if the compressor is shot or there is a bad part that keeps it from running
Nov 02, 2015 | American Retro AR-15002 1930s Coca-Cola...
If Klixon relay attached to my compressor rattles, is it definitely no goad?
If the relay was faulty, the compressor would not start when cold. To test the relay put a continuity meter in the 2 pins for common and start. there should be no reading. Turn it upside down there should be continuity. If there is a capacitor attached to the relay as well, change it as it may be failing. Apart from these, check all else is working ok, particularly the condenser fan and gas level. if all else is ok, the compressor is overheating and siezing and will need replacing.
Apr 23, 2014 | Freezers
Not getting cold enough on the inside... the exterior too hot to touch.. why could this be?
Compressor relay could be fried. Feel the compressor. If it is too hot to touch then check your relay. The relays contacts could be welded together making bot windings stay powered up and overheating the compressor causing compressor shutdown on overload.
Sep 02, 2011 | Whirlpool 14.8 cu. ft. / 419 liter Chest...
Over temperature warning light has come on
When the overtemperature light comes on it is an indication of possible failure.
But before panicing check these items first.
1.Condenser clean
2. Condenser fan operating (if so equipped)
3. Clearence around unit to allow proper air flow
4. Is compressor running ? (if not check relay, overload)
The compressor relay's purpose is to start the compressor. A faulty relay can result in the compressor failing to cycle on. The relay is accessed from the lower rear of the refrigerator.
Before testing a compressor relay, unplug the refrigerator to avoid an electrical shock hazard. Also, if the compressor uses a capacitor, it must be discharged first to avoid the risk of electrical shock.
The compressor relay can be accessed by removing the terminal cover box. The cover is held on by tension or with a retaining clip.
Remove the compressor relay by pulling it straight off from the compressor
Pull the wire off of the side terminal of the relay. It is connected with a slip on connector. Firmly pull the connector, do not pull on the wire. You may need to use a pair of needle-nose pliers.
Inspect the connector and terminal for corrosion. If either is corroded they should be cleaned or replaced.
There are two types of relays you may encounter, wire coil and solid state. If the relay has an exposed wound wire coil it can be tested for continuity. Otherwise, the relay is of solid state design and requires specialized equipment for testing.
Test the compressor relay for continuity using a multitester. Set the multitester to the ohms setting X1.
With the relay upside down, place the probes into the terminals labeled "S" and "M". The multitester should display a reading of zero ohms, indicating continuity (or if using a continuity tester, it should light up).
relaytest1b.jpg With the probes still in place, turn the relay over. You should hear the click of the magnetic switch engaging. The multitester should now display an ohm reading of infinity (or the tester should not light up).
Turn the relay upside down again, place the probe on the "S" terminal and place it on the side terminal labeled "L".
relaytest3b.jpg The multitester should now display a reading of zero ohms (continuity). Turn the relay over and the reading should change to infinity.
With the relay upside down place one probe on the "L" terminal and the other probe on terminal labeled "M".
relaytest2b.jpg The multitester should display a reading of zero ohms. Turn the relay over and the reading will stay the same, zero ohms.
If the compressor relay does not pass all of these tests, it should be replaced
Aug 07, 2011 | Swan SR5170 Freezer
My bottom freezer amana refrigerator is making a clicking noise. And my freezer is barely cold.
Refrigerator making clicking noise compressor not running.
The clicking could be the start relay.If the start relay is bad, the compressor will not start and you will hear a clicking noise in 2-5 minute intervals. The clicking noise is the overload cutting the compressor off when it overheats from trying to start with a bad start relay. To find out if this is bad first unplug the refrigerator. Remove the lower cover from your refrigerator. Then take the cover off that is on the side of the compressor,you will see wires going to this. Now you should be able to see the start relay plugged on to the side of the compressor and unplug it. Now the best way to tell if it's bad is to shake it. If it rattles, it's bad and needs to be replaced. If not, most of the time it's ok. But rather than saying the compressors bad, you might want to replace it anyways because it does not cost much. A quick check on the compressor is to remove the start relay. You will see 3 pins connect a multi meter set for continuity. You should have continuity between any of the 3 pins. If you do not the compressor is bad. Also check from each pin to a good ground on the cabinet. There should be no continuity if there is the compressor is bad. If you replace it and it doesn't work then the compressor is bad and you'll need to call a repairman. (Note that compressors are very costly and are normally not worth fixing).You can enter your model # at Refrigerator clicking for diagrams and illustrations or to purchase a start relay. A 3 in 1 start relay will also work fine.
Jan 29, 2011 | Amana Freezers
NOT COOLING ....CLICKING SOUND FROM COMPRESSOR
Compressor Start Relay/Overload or Compressor is bad. A bad compressor can cause Start Relay/Overload to go bad but the only way to know is to replace the Start Relay/Overload if you still have the same prob. or it works a week or so and it happens again the Compressor is bad or if luck is on your side it will work.
May 22, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
Compressor kicking on and off now not anything
Make sure you have 120volts at relay if not jump out thermostat if it starts to run and stays running Replace the thermostat. If you have 120volts at relay and it is not running or it's kicking off and on replace Start Relay/Overload but a bad compressor can make a Start Relay go bad so if you have the same Prob. after replacing Start Relay/Overload Compressor is bad
May 20, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
My kelvinator upright freezer stopped freezing and it just kicks on and kicks right back of what could be wrong with it?
Start Relay/Overload or Compressor is bad. A bad compressor can make a Start Relay/Overload go bad but the only way to find out if compressor or Start Relay/Overload is bad is to replace the Start Relay/Overload if it starts and stays running you fixed it if Prob. returns in a week or so or if you have the same Prob. after replacing the relay the compressor is bad.
May 20, 2010 | GE 13.7 cu. ft. General Electric Upright...
Freezer will not cool,i.e.freeze food.Compressor is very hot.
The compressor may be overloading because of a bad relay. The relay is on the side of the compressor. Disconnect power from refrigerator then remove the cover and remove the relay. Then shake the relay and if it rattles it is bad. http://www.appliance-repair-it.com/Refrigerator-repair.html
Sep 18, 2009 | Freezers
Buzzing compressor
heres a part number for the overload relay assy 5304468029.. its mounted on the side of compressor. its a tricky one, usually my experience has been the noise comes from a bad compressor( which you should have 5 year full warr from manufacture). sometimes the overload relay does go bad preventing compressor from starting,the n ew compressor will come with a new overload relay
Nov 19, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
Liebherr Premium Plus HCB1560 30" Fully Integrated Bottom-Freezer Refrigerator with Glass Shelves, BioFresh Compartment, Ice Maker, 2 Freezer Drawers and Requires Custom Panels/Handles: Right Hinge Door Swing Logo
78 people viewed this question
Top Liebherr Freezers Experts
richie46
ray gallant
Tom Chichester
Are you a Liebherr Freezer Expert? Answer questions, earn points and help others
