Visit this web page for a picture guide to repair your screen.
http://tiny.cc/YaTayDirections to repair the screen on an LG Shine:
Step 1. Take off back cover and remove
battery and SIM card.
Step 2.
Remove the six screws holding on the back cover.
Step 3. Get a thin piece of metal and pry off
back piece of the main phone unit.
Step
4. Once you get the back piece off you can see a green unit at
the top of phone. This is the camera, all you do is pull on it and it
should un-clip.
Step 5. Once the
camera is removed you can see 4 more screws, unscrew these.
Step 6. Now that the screws are out you can pull
off the main board. The first thing you need to do is un-clip the black
ribbon that is at the top. Then you have to un-clip the clip on all four
corners, after you do this the main board will come out.
Step 7. Now That you have that off there are 2
screws on the back that you must unscrew.
Step 8. With the screws gone you can now pull the
slider away from the piece that has the number pad on it.
Step 9. On the back of the slider there are 6
screw you must unscrew. The Two screws at the top have small black
circles glued on-top of them. Just wedge something under the black
peices and they will come off.
Step 10.
Now that the screws are out you can pry off the plastic LCD
screen cover from the metal slider piece.
Step 11. After the LCD screen cover is gone you
must unscrew 2 screws to the left and right of the joystick. After you
remove the screws the joystick cover comes off.
Step 12. Now that you have the cover off you need
to turn the plate where the joystick is on over and pull out of the LCD
screen clip.
Step 13. After you
do this you can now put in the replacement and put the phone back
together.
If this information was helpful, please give me a big thumbs-up when you rate my answer. Thank you.
