Question about HobbyTron Nano Hercules Unbreakable 3.5CH RC Helicopter 3-Pack Bundle Deal
Nano hercules top rotor does not turn
Just got it today, worked fine for the first few flights. Now the top rotor does not turn.
Spins to left, will not take off/lift?
GYRO Nano Hercules Unbreakable 3.5CH Electric RTF RC ...
www.amazon.com/Hercules-Unbreakable.../B00AAOJ...
Amazon.com, Inc.GYRO Nano Hercules Unbreakable 3.5CH Electric RTF RC Helicopter (Color ... you can remove the 8 or so screws that allow you to pull the fairing off, remove .... Also we purchased our helicopter from HobbyTron.com through Amazon and .... won't spin, so the entire helicopter spins, and doesn't generate enough lift to fly.
GYRO Nano Hercules Unbreakable 3.5 CH Electric RTF RC
Amazon.com, Inc.Nano Hercules Unbreakable Glow in the Dark 3.5CH RC Helicopter ... It can go forward, backward, up, down, left, right and hover. .... It worked for a few flights and now the copter will not fly off the ground. ... and ive had it for a year now and everytime I start it up and it takes lift off it starts to fly backwards but otherwise ok toy.
Hercules Unbreakable 3.5CH RC Helicopter - HobbyTron.com
Dec 26, 2015 | HobbyTron Nano Hercules Unbreakable 3.5CH...
My hercules doesnt lift. rotors turn but it spins counter clockwise uncontrollably.
i am really glad that this isnt a REAL helecopter. if you got it for christmas, you might want to return it- that is, after you verify that it is FULLY charged. this sounds like a half charged battery, that isnt spinning the bigger blades as fast as it should.
this could also be caused by any obstructions to the blades ability to rotate freely, something stuck to the blades- adding weight, bent blades, or internal belt/gear issues, regarding regulating the main blades, and the rear stabilizing blades timings.
if, before the charge, the dying battery caused the copter to crash, a blade could easily be bent, or have mud or something on it, weighing it down.
if the copter really is indestructable, i would go right back to a bad battery.
if the rechargeable battery got a memory after 4 days, i feel bad for you and your kids.
Dec 29, 2014 | Hercules Unbreakable Radio - controlled...
It won't move forward/backward or sideways with the gyro(safe) off
Check this video on YouTube to understand all about the three flight modes and the SAFE technology. Blade Nano QX Basic Overview and set up
Aug 29, 2014 | Red Rocket Hobbies Blade Nano QX BNF
My back rotor for my Hercules Helicopter's wont work need help!
Motor failure. They don't last long. Look on fleabay for a cheap replacement. If you have a soldering iron, you can unsolder them both and insert a 3v watch battery. If it runs, then it could be the control board or else the transmitter stick control.
Jun 26, 2013 | HobbyTron GYRO Hercules Unbreakable 3.5CH...
I turn the on switch on the remote control and ready to fly. The heli starts for about two seconds and shuts down?
I have a Hercules "unbreakable" helicopter that shows that"shut down" sympton when the battery is low. I assume it does that to prevent the battery completely dying while in flight.
Feb 23, 2013 | RC New 3 Ch Co-Comanche RAH-66 Helicopter
Bought Nano Hercules RC Helicopter. Flew it once and now lower rotor won't turn. Tried to call World Tech
I, too, have the Nano RC heli. Mine spins and spins faster if I try and take off.
Yours is a relatively easy fix. There are SCREWS under the rotor blades on the bottom. Tighten those.
Dec 28, 2012 | Toys
Lower rotor of my nano hercules helicopter is not turning
I have the nano hercules and I had the same problem. The lower rotor would spin funny or not at all. Upon taking apart the heli (there really isnt too many pieces, just a lot of little screws so keep track of them), i found the culprit to be a tiny white gear with teeth had broken and the larger spinning gear was barely making a connection to the small teeth on the small gear (excuse my lack of technical vocabulary). I was able to remove the motor, slide the small gear w small teeth down just a tad so the big gear and the small gear lined up, added a bit of modelling glue for support and it works like new again. Hope that helps!
Dec 26, 2012 | Toys
My iPod nano won't turn on
To reset the nano, you slide the hold button on the top to red then back to black, the hold down the center button and the menu button at the same time for a few seconds. Works for all versions of the nano
Aug 18, 2009 | Apple iPod nano
My ipod nano third generation won't work.
try resetting your ipod by sliding the "hold' thingy back and forth once, then pressing Menu and Select at the same time(it may take a few seconds, but then the Apple logo will show up, and it should be back to normal). I hope this helps!
Mar 08, 2009 | Apple iPod nano 3rd Generation
Need blade for world tech skyhawk helicopter
Syma DragonFly 9093 or 9083 rc heli... has the same exact size tail blade... just put one on myself... works fine..
Dec 23, 2008 | Toys
HobbyTron Nano Hercules Unbreakable 3.5CH RC Helicopter 3-Pack Bundle Deal Logo
338 people viewed this question
Top HobbyTron Toys Experts
King
King
MeAndMyBrain
Level 1 Expert
 Russ Hill
Russ Hill
Are you a HobbyTron Toy Expert? Answer questions, earn points and help others
