Question about GE Dryers
What can cause an electric GE dryer to not start? Model number DCVH680EJ1WW. cogtinuity with motor switch, door switch, high limit fuse, thermistor & no cogn. with the thermodisc or heating element.
    Scholar:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 123 Answers
As a repair technician, just came across this crazy situation with GE / Hot Point / Moffat machines several times. It is all made by GE corporation.
The Dryer is not starting because your cycle selector knob is broken inside and it is just turning without turning the timer selector.
GE corporation machines are good. But those damn chinese plastic knobs break from inside. I have driven 50 km to find out the knob is broken. I had to charge the poor customer.
Posted on Apr 25, 2015
Illeagle
  • 525 Answers
SOURCE: Whirlpool Electric Dryer Model LER8858EQ1 TYPE NO. 180-0
Based on the information that you provided, if you open the door in mid-cycle and the motor shuts off, but the element stays on, this will stop the air flow through the dryer and the element. The element temperature will rise drastically because it is not being cooled. Subsequently, to prevent a fire, the thermal fuse will open, shutting the element, and in some cases the motor, down.
A heating element gets its power from the timer, through the cycling thermostat(s),and to 1 side of the element.
When the motor starts, power is passed through the centrifugal switch in the motor, through the hi-limit thermostat and the thermal fuse to the other side of the element.
There is no ground wiring involved in the heat side of the dryer.
1. An element can stay on because it has broken and fell against the metal tube where it picks up a ground. Solution is to replace the element.
2. The centrifugal switch mounted on or in the motor can fail to open when the motor stops and allow current to flow through it
until the points in the timer open up, breaking the circuit.
Below is a link that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 23, 2008
aasc
  • 1606 Answers
SOURCE: Whirlpool duet electric wil not heat
Remove 1 wire from the element . Your 220 V comes from ...110 motor , 110 control board . Check which wire is not getting 110 V , trace it and see which it comes from . That will tell you which one is defective .
Posted on Aug 01, 2009
hiltonjug
  • 612 Answers
SOURCE: LER4634EQ2 whirlpool electric dryer. heating
I know this might sound stupid but try this. Find your fuse box, locate the breaker that runs your dryer. Flip it off and then back on. If i'm correct, it will work. Everything on your dryer works off of one leg of the 220v. The other leg goes to the other side of the element. If you have a meter. check for 220v at the plug. Everything you listed is what makes the dryer heat other than the thermostats. Check the cycling thermostats like you did the other pieces. They look like the thermal cut off. They have two wires and they are round.
Posted on Oct 10, 2009
SOURCE: blowing high limit fuse
My dryer stopped working, using a multimeter I determined that the thermal fuse was open. I unclogged all the ducts then ordered a high limit thermal kit. After changing the fuse, it blew-up on the first cycle. It turns out that even though the high limit checked ok, it was defective. After changing both the fuse and the thermostat(included in the kit $25), the dryer worked correctly.
Posted on Dec 30, 2009
kel1guy2002
  • 3740 Answers
SOURCE: Maytag Performa dryer blowing heating elements
Hi and welcome to FixYa. You should check the dryer vent ducting inside and outside the dryer for restrictions / clogs to include the vent flapper. Poor air flow through the dryer will cause hot spots. If the blower is slipping on the motor shaft this too can cause poor air flow.
When you change the heating element AGAIN... break out the crevice tool and de-lint everything you can access. Also pull out the lint filter and wash it with white vinegar and water then soap and water. Fabric softener sheets material builds up on lint filters. It looks clean but air will not pass through the lint filter.
I think once you get it all ceaned up including all of the ducting to and through the outside wall it will work normally with no problems. I do not think at this time that you have an electrical problem with the outlet supply.
There is one more thing to check and that is the high limit thermostat. It could be STUCK. It will most likely be labeled L180 or L190. That thermostat is suposed to open at either 180 deg or 190 Deg depending on which one is installed. If it does not open then you will keep cooking your elements. We test them with a match and an Ohm Meter. Match under the removed thermostat CLICK. Thermostat opens (no resistance)
Wish ya the best.
Thanks for using FixYa.
Kelly
If anything in the future crops up with this same issue.
Posted on Apr 10, 2010
The dryer will not start. it seems the thermal fuse is good. (2.5 ohms on Ohms meter)
Hello Rusty,
Try holding the Start Button for more than 3 seconds.
  • Check that the door is closed properly. Check the door Catch & Switch with an ohmmeter for continuity when close.
  • Make sure the High Limit Thermostat is good
  • The Thermistor can be open.
  • Check the Heating element for continuity.
  • Idler pulley might be bad.
  • The Control Board my be defective.
  • The Moisture Sensor can also be bad.
  • Last but not least the dryer Motor might also be defective.
Here is a link to Sears Parts. Most of the parts you may need are in the Bulkhead Diagram.
Best of Luck,
JP
MAYTAG RESIDENTIAL DRYER Parts Model MED9700SB0 Sears PartsDirect
Jul 19, 2015 | Maytag MED9700S Electric Dryer
Can a GE electric dryer Thermodisc be tested by cogtinuity?
That picture looks like a thermistor of some type. If you have the wiring diagram (usually inside the control panel) it should tell you the resistance it should be at different temps. If it is a thermal fuse or hi limit it will read like a switch. Closed if good---opened if burned out from too much heat.
Apr 15, 2015 | GE Dryers
Intermittent heat problems with GE dryer. Drum light associated with problem. Light goes out with door open when centrifugal switch disengages. No heat when this occurs.
this problem is related to the thermal hi-limit cutout and its sister thermal fuse. The two can be bought as a repair kit from repairclinic.com or any appliance repair dealer. Enter your model number and the kit will come up high on the hit list of commonly ordered parts.
25361439-xipalmoknr3fbjmp51kycajc-3-0.jpg These two are in series with each other, and can be jumped out temporarily to verify operation. The silver one will look very much like the picture, the black and white one may be round instead of rectangular (depending on model). They should be swapped as a set. You can ohm them out just like regular fuses to check them.
Jan 09, 2015 | GE DWSR405EBWW Electric Dryer
Kenmore 62922 electric dryer
follow this steps and fix it. God bless you
Thermal Fuse
The thermal fuse helps to prevent a dryer fire by shutting off power to the dryer if it overheats. If the dryer won't start check this fuse first. Test the thermal fuse with an ohm meter or continuity checker. This is the most common part to fail when the dryer won't start. Once the thermal fuse has blown, it has to be replaced. It can not be reset.
Enter your model number to see parts for your dryer.
Help me find my model number
Start Switch
The start switch is on the dryer control panel. Depending on the model, either press a button or turn a dial to start the dryer. If the start switch fails the dryer won't start or make any noise. Test the switch with an ohm meter or continuity checker. If the dryer hums when the start switch is activated, or if the motor runs only while activating the start switch, the motor might be defective or something might be binding the drum preventing it from turning freely. If the dryer start switch does not have continuity when it is activated, it will need to be replaced.
Door Switch
The door switch is located near the dryer door and is activated when the door is closed. If the door switch fails, the dryer won't start at all. Most door switches will make an audible click when they are activated. If the door switch makes a clicking sound when activated it is probably not defective. If it doesn't make a click, it can be checked with an ohm meter or continuity checker. The door switch is relatively easy to replace and is usually not very expensive.
Drive Motor
On most dryers the drive motor turns the drum and the blower wheel to exhaust the air. If the dryer won't start the motor might be defective. Before replacing the motor, check the thermal fuse, start switch and door switch because all three are more likely the cause. If the dryer won't start and the dryer motor makes a humming noise there might be something caught in the blower wheel, or the drum might be binding. Try removing the belt from the motor and checking the blower wheel for obstructions. The dryer motor can't be tested easily. If the more common components have been checked and it seems the motor itself is defective, it will need to be replaced. It is not serviceable.
Drive Belt
On most dryers, if the drive belt breaks the motor can still be heard and it will still be blowing air out the exhaust tube, but the drum will not spin. However, in some dryers when the drive belt breaks the tension pulley arm trips a switch which shuts off power to the entire dryer. If the dryer won't start, check to see if the belt is broken. If it is, replace the belt and the dryer should be fine. If the belt is not broken, check the other components that can fail when the dryer won't start.
Thermal Cut Out Fuse Kit
Most dryers have several temperature control devices such as a thermal fuse, thermal cut out, high limit fuse or high limit thermostat. Some manufacturers sell the thermal fuse and thermal cut out in a kit. These kits normally solve no-heat problems rather than when the dryer won't start. However, in some models, this kit will solve both problems. Even though this is not the most common part to fail if the dryer won't start, both can be checked using an ohm meter or continuity checker. If they have continuity they are good. If not, they should be replaced.
Incoming Power Problem
If the dryer won't start, check to make certain there is electricity to the dryer. For a gas dryer, unplug the dryer from the wall and plug something else into the outlet to see if it's working. For an electric dryer, check the home circuit breaker or fuses. If they are working, check the outlet where the dryer plugs in with a volt meter. There should be between 208 and 240 volts. If there is power to the dryer, check the more common items in this troubleshooting guide.
Belt Switch
If the dryer won't start, there might be a belt switch that has failed. This is not a common problem and most dryers do not have this switch. If the dryer has a belt switch, the switch shuts off power to the entire dryer if the belt breaks. It is possible that this switch has failed, even if the belt is not broken. It can be checked with an ohm meter or continuity checker. If the dryer works at all, even if all it does is hum, this is not the problem.
Main Control Board
The main control board is normally not at fault when the dryer won't start. First, check all of the other components in this troubleshooting guide before replacing the main control board. The main control board can not be tested and must be replaced if it is defective. If there are obvious signs of burning or a shorted out component on the board, it should be replaced.
Timer
The timer is normally not at fault when the dryer won't start. In many situations where timers are replaced they end up being returned. First, check all of the more common components in this troubleshooting guide before replacing the timer. If the dryer won't start, the cause is much more likely to be a thermal fuse or switch. The timer can not be tested, it must be replaced if it is defective.
Oct 01, 2013 | Dryers
Not working
Thermal Fuse
Start Switch
Door Switch
Drive Motor
Drive Belt
Belt Switch
Main Control Board
Timer
Jul 09, 2013 | Kenmore Elite Oasis 7808 Gas Dryer
When you hit any button it turns on and the next button shuts it off
Thermal Fuse
Start Switch
Door Switch
Drive Motor
Drive Belt
Belt Switch
Main Control Board
Timer
Problems with GE DWXR483EBWW Electric Dryer. Dryer will not start (no spin,no heat, no attempt to start). Has Power because interior light works. About 6 mo ago start switch was replaced...does not appear...
If a dryer is not working at all that's not good! But it doesn't mean you need to go appliance shopping just yet. It may be something very simple like a broken door latch, a bad door switch or even a broken door switch actuator, in a kenmore dryer there is a tab thats sticks out of a hole in the wall that allows the dryer to run only if the door is shut, other models may have button that protrudes out of the dryer and when the door is shut, this allows the dryer to run. These switches go out from time to time, also if a dryer is full of lint build-up over time this will cause the dryer high limit or fuse to blow. The fuse is located near where the blower is in most cases. When the air in the dryer gets way too hot the fuse/hi-limit will blow and the house wont burn down.
Nov 11, 2009 | GE DWXR483EBCC Electric Dryer
Dryer will not run
If a dryer is not working at all that's not good! But it doesn't mean you need to go appliance shopping just yet. It may be something very simple like a bad door switch or even a broken door switch actuator, in a kenmore dryer there is a tab thats sticks out of a hole in the wall that allows the dryer to run only if the door is shut, other models may have button that protrudes out of the dryer and when the door is shut, this allows the dryer to run. These switches go out from time to time, also if a dryer is full of lint build-up over time this will cause the dryer high limit or fuse to blow. The fuse is located near where the blower is in most cases. When the air in the dryer gets way too hot the fuse/hi-limit will blow and the house wont burn down
Sep 27, 2009 | Whirlpool GEQ9800L Electric Dryer
Ge dryer will not start when i push start button
Look inside door and get me the model number. This could be many different things that can cause this. Bad door switch, high-limit, timer, start button and a lot more, so let me know what happens, check power to dryer and see if timer even runs. Thanks, Sea Breeze
May 01, 2009 | GE Dryers
Dryers Logo
157 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
