Question about AEG Ovens
How do I change the bulb inside the cooker of the B5741 cooker
Model number B5741 AEG electric single oven, we had it in stalled in 2006.
    Master:
  • AEG Master
  • 489 Answers
Oven Lighting
Warning: There is a danger of electric shock! Prior to changing
the oven light bulb:
  • Switch off the oven!
  • Disconnect from the electricity supply.
Place a cloth on the oven floor to protect the oven light and glass cover.
Replacing the oven light bulb/cleaning the glass cover
  1. Remove the glass cover by turning it anticlockwise and then clean it.
  2. If necessary:
Replace bulb with a 40 watt, 230 V, 300 °C heat-resistant
oven light bulb.
3. Refit the glass cover.
how do I change the bulb inside the cooker of the  - 25648864-wjkdtau3hzetwygkyoujq3j4-2-0.jpg
Dado
Posted on Nov 07, 2015
  • 1462 Answers
SOURCE: clock settings
press 1st and third buttons together. use rhs button to set time and it should then work
Posted on Jul 14, 2008
  • 18 Answers
SOURCE: Whirlpool single electric oven - model unknown
Turn the breaker off that supplies the power to the oven for 5 minutes to allow the computer to reset. If this doesn't work you my have a bad board.
Posted on Aug 04, 2008
SOURCE: changing the oven from celsius to fahrenheit
You will need to push the broil button down for at least 10 seconds then you will see the c change to a f for farenheit
Posted on Nov 06, 2008
barkencoa
  • 3463 Answers
SOURCE: I have an AEG cooker but the marking around the cooker knobs have
Hi.
You need thermostat knob and main oven control knob.
Posted on Nov 20, 2008
samrat_babui
  • 296 Answers
SOURCE: how to replace oven light bulb for beko DC543 electric cooker
hi
You may need to remove the glass cover by turning it anti-clockwise.
On some models access to the bulb is from outside so the oven has to be slid out of it's housing and an access plate removed.
chek this following steps..
Step 1 Make sure the bulb is actually burned out. Confirm the oven is plugged in and that a circuit breaker is not tripped.
  • Step 2 Look for the manual to determine what size bulb is required. Most use a 40 watt appliance bulb. If you can not find the manual, then buy a bulb to replace it after you take out the old one.
  • Step 3 Confirm that the oven is not on. Allow it to cool to room temperature if it has recently been used.
  • Step 4 Open the door and use a flashlight to light the area where the bulb is located. Do not put weight on the door itself, but go in at an angle or sideways.
  • Step 5 Find the shield or cover over the bulb, gently pull or twist it off. Some glass covers are surrounded by a wire clip or a ring that is screwed in to the back.
  • Step 6 Gently remove either the wire clip or ring. Since the cover is most likely glass, be cautious. Unscrew the entire glass cover similar to a jar lid in older versions of ovens. Then repeat process if there is more than one bulb.
  • chek this usefull link
    http://www.espares.co.uk/advice/cookers-and-hobs/a/1/112/changing-your-oven-light-bulb.html
    hope u will b helpfull
    tnx for contactin fixya
    regards
    Posted on Jul 12, 2009
    How do I change the bulb inside the oven
    The glass cover unscrews counter clockwise and removes to be able to access the bulb itself. Note there may be a guard that has to be removed before accessing the glass cover
    Apr 15, 2015 | AEG Ovens
    AEG error meesage F01
    Oven door can't be locked so test door locking system.
    Dado
    Jul 06, 2014 | AEG B5741-4 Electric Single Oven
    My zanussi electric cooker has heated up, gone bang and there is black ash all over inside
    Sharon First turn off power on this oven or unplug it if you where useing the oven then that element went bad if it was the broiler then it is that one , very easy to fix and it is cheep also, with a flash light look at the elment for damage don't touch it unless the power is off , get back to me with the information like make model serial number and i will locate the element for you and you can buy it at the place if find it for you . good luck Frank
    Dec 07, 2011 | AEG B2100-4 Electric Single Oven
    Replacing oven bulb
    what type of oven isthis and model , can you get to the bulb, is it broken inside the socket ?
    Dec 06, 2011 | Ovens
    Aeg b5741-14 oven has code f5 -what does this mean?
    Here is a list of oven error codes for your model Kenmore oven.
    1. F0 indicates a Stuck key pad.
    2. F1 and F7 may mean relay is turned on.
    3. F2 indicates that the oven is over temperature in one of the following modes within either cooking or cleaning mode of operation. The control is sensing over 615 degrees with the door lock circuit in the unlock mode. Control senses oven temperature above 915 degrees with the door in the locked mode.
    4. F3 and F4 indicates an open or shorted oven sensor or sensor circuit.
    5. F5 indicates a loss of relay drive circuit.
    6. FF indicates a loss of door motor safety switch.
    7. FC indicates a door lock circuit problem.
    If the display of your control is flashing "F" followed by a number or letter its a range malfunction. Press the clear/off pad. Let the range cool for 1 hour and place the range back into operation.
    If the problem repeats, call for service.
    Jul 16, 2011 | AEG B5741-4 Electric Single Oven
    I have recently had a MCC3880E-m oven fitted in to a housing unit by a Magnet kitchen fitter and It keeps flashing up a red ErC on the left hand side of the display panel - the Kitchen designer at Magnet...
    The "technician" has no idea why your oven is defective but the fact remains it was defective when installed. Magnet needs to take responsibility for replacing it.
    Jun 10, 2017 | AEG B5741-4 Electric Single Oven
    OVEN WILL NOT OPERATE
    F4 is a fault with the temperature sensor for the oven which normally will need replacing.Hope this helps.
    May 08, 2010 | AEG B5741-4 Electric Single Oven
    In fan mode oven very slow to heat up [ fan is working] all other functions ok
    If you can, test the oven fan element, if you can't, then feel \at the back of the oven compartment in front of the fan, you shoud feel hot air blowing, if not, then you need to replace the oven element.
    Please rate my solution.
    Thanks.
    Nov 04, 2009 | AEG B5741-4 Electric Single Oven
    My AEG pyrolytic oven won't run the cleaning cycle.
    clean it the old fashioned way with aerosol oven cleaner . then use oven shields or pans under things to catch drips .
    Oct 31, 2017 | AEG B5741-4 Electric Single Oven
    Ovens Logo
    223 people viewed this question
    Top AEG Ovens Experts
    Sal De
    Steve
    Samyfam
    Samyfam
    Are you an AEG Oven Expert? Answer questions, earn points and help others
