Question about Ali Industries 7231 Hand Sander Hook & Loop - Each
Where could I find a big quantity, between 500 to a 1000 of triangular sand paper compatible with this sander..
    Top Expert:
  • Ali Industries Master
  • 10,875 Answers
Hardware store or ali industries
Posted on Apr 16, 2015
How do you attach the sand paper to the sander. I have no instruction manuel.
Depends on the model. Probably spring-loaded arms that hold paper tight on the sanding block...
Jul 31, 2016 | Tools & Hardware - Others
Why is my 5" sanding disks not sticking to my sander?
The holes are to suction dust for a vacuum attachment or dust collection bag. The sander will have a very smooth pad almost shiny if it takes stick-on discs (PSA). If not it will be a velcro pad and in that case you need the velcro discs. This description sounds like you have a velcro pad. Sticky discs wont stick to a velcro pad.
Apr 24, 2016 | Sander Tools & Hardware - Others
When I bought my sander it has what i would describe as a rubber pad onj the sander. Is this the sanding pad?
That sounds right. It is probably the type that uses adhesive backed paper. You stick the paper to the rubber pad.
Jul 14, 2012 | Dewalt DW 411 HAND PALM SANDER
Can't figure out how to load the sand paper on to the mouse sander
Just stick the sand paper sheet to the base of the mouse sander... it's velcro it will hold... match the forme of the paper with the forme of the sander's base... that's all...
Cheers!
Aug 06, 2011 | Black & Decker Mouse Sander/Polisher
How to replace the sand paper on skil sander hi speed 439
the skil 439 is a palm orbital finish sander. To replace the paper, pop the springs off the side where they take a 90 degree turn towards the work surface. To replace paper, rip a piece of standard sand paper into quarters, reverse removal and done. It's a pretty nice older sander and yes I have one.
Jul 11, 2011 | Garden
How do I secure a piece of sandpaper on the dewalt orbit palm sander?
I think your model holds the paper with glue that is on the sand paper.Just take apart the back cover of the sand paper to expose the glue.
Nov 08, 2010 | Dewalt DW421 5'' orbital sander
How do I change the sanding belt on my 7447 belt sander
To change the belt, you must release tension of the rollers by pushing the front roller straight back until you hear it click and lock in position to change paper. Remove old paper and replace with new paper. Make sure if new paper has directional arrows to install properly.
Now you must release the front roller to put tension on paper. To do this push the front roller from the side that has the adjustment screw. This will release the front roller and allow it to go back into position. Be careful as it pops back quickly and with some force.
Turn on sander and adjust centering of paper with adjustment screw found near the front and side of sander.
Aug 27, 2010 | Black & Decker 3"x21"HD Vs Belt Sander
Clarke FM1700 buffer-sander, problems with using it
what is the condition of the felt pad on the driver?? The sander should not be that hard, usually you need to lift up or slightly bear down to get the machine to move left or right. Are there any exposed nails in the area you are sanding and check the grit for the sanding conditions
Aug 23, 2009 | Clarke Floor Sander Floor Sander Orbital...
Orbital sander flicking the sand paper off
You did not specify how the sanding discs are meant to be attached to your sander's backing pad.  My experience with this type of problem is material from the sanding process builds up on the backing pad and does not allow the sanding discs to adhere properly.  If you have a velcro type system, clean the hooks on the sander's backing bad by soaking the pad's face in a plate of paint thinner for 20 to 30 minutes then use a wire brush to remove the rest of the paint physically.    For adhesive pads clean the sander's backing pad surface with denatured alcohol.  Do not use isopropryl or rubbing alcohol as this may not be 100% alcohol and could contain a lubricant like glycerin.  When the sander's backing pad is completely dry and clean it will hold adhesive backed pads fine.    Flaky paint is best scraped off before sanding, use a wide putty knife or a paint scaper to remove large flakes before sanding.  This will minimize airborne dust and cleanup.    For best results with adhesives, always keep your surfaces  clean!    Good luck and happy sanding!  Michael Mittelsdorf
Jan 07, 2009 | Bosch Power Tools Sanders Orbital Sanders
How many Types of Sanders?
Belt sanders: Belt sanders are useful for removing large quantities of wood stock quickly. They are generally used for rough sanding before fine finishing with a smaller sander. Palm sanders: Palm sanders are ultra-portable and useful for finishing small projects. Orbit sanders: Orbit sanders are usually more heavy-duty than palm sanders and appropriate for larger projects.
Aug 27, 2008 | Bosch 3X18 Belt Sander
Ali Industries 7231 Hand Sander Hook & Loop - Each Logo
44 people viewed this question
Top Ali Industries Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you an Ali Industries Tool and Hardware - Other Expert? Answer questions, earn points and help others
