Question about Sony SPP AQ600 Cordless Phone
Stopped charging. Put in new battery pack and still won't charge. What can I do. Checked all connections.
  • 164 Answers
The last thing to check is whether the electrical contacts between the bottom of the handset and the station are fine. If the contacts are not touching, use a small tool to pull them out to make them touch. If the contacts are fine, it seems that the station electronics is not working. Then, you probably need to bring it to the service people.
Posted on Apr 15, 2015
New alternator not charging 2000 Ford Excursion V10
Check for blown fusible link and possible bad relay. On relay, with everything off and hot battery hook u battery and give it ten minuets or so, then feel the top of eac relay. if you find a warm or hot one Bingo!
Jul 13, 2015 | 2000 Ford Excursion
My firestorm 24 volt double charger the lite is on but it won't charge the battery
It is charging the battery but the battery is not holding the charge probably from a faulty batter in the pack.so the charge is going in and out at the same time. Take the pack to a battery shop that specialises in replacement batteries to have it checked out . Take the charger also for tests.
Jan 14, 2013 | Tools & Hardware - Others
Put in new alternator - battery still won't charge
Have you checked the alternator, I work at a auto parts store and see this all the time, check the inline fuel filter, also have your checked the coil, mine went out and that was the last thing I checked but am back on the road.
Jun 03, 2012 | 1986 Chevrolet Camaro
Go-go battery won't charge
PLEASE NOTE: The Low Voltage Protection feature on this battery charger will not allow the charger to activate unless it is connected to a battery pack that has a minimum voltage of 16 volts. Battery packs with voltages below that level of charge cannot be recovered or recharged. This is a safety feature to prevent overheating in the event of a faulty battery. This battery charger will not output any voltage to the XLR connector until connected to a battery pack meeting this minimum voltage requirement.
Dec 27, 2011 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
1990 plymouth colt, new alternator, still won,t charge. what tells alternator to charge battery?
Have you also had the battery checked? If the battery is bad, then it won't charge. All of the terminals need to be checked for corrosion. All wires must be secured properly. Check to see if the ground cable is properly attached to the frame of the vehicle.
May 03, 2011 | Ovens
I have a 1996 toyota camry, it doesnt want to start its not the battery i just put a new one in and it wants to start
If its not battery,still check the voltage of new battery.In many cases it has seen that battery charge is low,because if the new battery is just kept in stock then it will get drained automatically without any use.So check the voltage of new battery first with meter.It should show exact 12 volt.But if its less or no 12 volt then get the new battery charged.
There are some possibilities which you will have to check in this case:--
1) First of all check the power and voltage to the battery. With meter it will show exact 12 volt if the battery is charged. If the voltage is less get the battery charged at local auto repair shop. If the battery is internally drained and not getting charged then its time to replace the battery.
2) When you crank the car do you see spark coming at the spark plug? If no then its time to check the spark plugs and coil pack. If the spark plugs are not worn out and looks new then its time to check coil pack. The spark plug gets power to spark from coil pack.
3) The other thing to check in this case is the starter solenoid of the car. If the battery is charged and you start the car then it gives power to the starter to start the car. But if starter is faulty or not connected properly then car will not start.
4) The other thing to check in this case is fuel in the car. If there is fuel in the car then check the blockages in the fuel pump if the fuel pump looks proper then check the fuel filter above the fuel pump.
5) If all the above possibilities mentioned above checked out OK/perfect then it's a electrical issue and the wiring's in the car needs to be checked. The car gets power from the battery to get started. so the wires from battery needs to be checked one by one.
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Sep 14, 2010 | 1996 Toyota Camry
Install battery
First make sure the scooter is off.
Unscrew and take off the deck
Unplug and remove the old battery pack
Put the new battery pack in and plug it in, using the same connection as the old batteries pack.
Screw the deck on and your done!
Oh, and make sure you give the battery a good charge(the full charging time). The first charge of a battery is the most important one.
May 16, 2010 | Mongoose Currie Schwinn Gt Izip Scooters
How to charge Panasonic lumix DMC-FS4
hello there use your USB cable for charging your camera battery. No need to take out the battery from camera. Some Tips.
  • You may choose our Smart Charger (0.5A,UL listed) for 3.7 V Li-Ion battery Pack to recharge this battery pack. Must charge the battery pack with correct polarity. The estimated charging time is 2.76 hours .
  • You may connect two 3.6v 920 mah pack in either series or parallel connection for making a higher voltage and higher capacity pack.
  • Hope you have those staff with your camera. use that for charging. Follow the link.
    http://www.batteryspace.com/smartcharger05afor37vli-ionpolymerrechargeablebatterypack--ceullisted.aspx
    Thanks, i am waiting for your feed back & if you satisfied then thumps me please.
    Jan 31, 2010 | Panasonic Lumix DMC-FS4 Digital Camera
    Hi-- This is actually a problem with the Canon LK-51B battery pack that goes with the iP90v portable printer. We've charged up the battery pack and all the lights have gone out, indicating full...
    electronics should not be relied on to realy confirm u need to use a second battery pack to connect ur printer n see if the same thing will occure. i guess the battry inside d pack may be dead even though its a new one.
    May 24, 2008 | Canon Office Equipment & Supplies
    Cordless vac won't hold a charge
    Like all batteries after a while they go bad/will not hold a charge. especially the kind that is always plugged in/always charging, like electric shavers, cordless vac and so on.
    get a new battery
    thanks for rating
    Jan 14, 2008 | Vacuums
    Sony SPP AQ600 Cordless Phone Logo
    56 people viewed this question
    Top Sony Lands Phones Experts
    Computer Repairing
    Computer Repairing
    Are you a Sony Lands Phone Expert? Answer questions, earn points and help others
