My computer comes on but no display says no signal then display shuts off but computer stays on
  • jane pool
    jane pool Apr 16, 2015
    Thank you Robert for your answer. I opened up the case and reseated everything and now display is working.
  • 4 Answers
Check cable connections from gpu inside pc tower. If you have a second monitor or can borrow one, see if that monitor works. If colours/image are distorted then you may need to replace the gpu.
Posted on Apr 15, 2015
DS-1900S DoubleSight Displays keep shutting off
Sometime the cross-talk of signals causes this. Separate the wiring behind the computer. No touching, no problems.
Mar 06, 2014 | DoubleSight Displays - DoubleSight...
Replace power supply, computer on, monitor no signal, help
Did you forget to connect the 4 pin power plug to the display card or motherboard??????????
May 16, 2010 | E-Machines eMachines Desktop PC
TV displays RGB code and then displays, no signal and then shuts off. What does the RGB code mean?
It means the source is not set correctly. Switch the source to input 0 (cable or antenna depending on your particular set up).
http://www.vizio.com/l32hdtv10a.html#support
Will lead you to the manual and quick start information if you need more specific instruction.
Joe
Jan 03, 2010 | Vizio L32 32 in. LCD HDTV
TV will not stay on.
MIne did this at first. Unplug from source for 2-3 minutes, then try again to turn on. Should come up then.
Apr 03, 2009 | Vizio L6 20.1 in. HD-Ready LCD Television
Monitor flashes on then goes black.
I think you have the display shut off. the button on the bottom left will shut screen off. It will come on for a few seconds if you touch the screen, but will shut off again. just push the display button again and it should stay on.
Apr 02, 2009 | ViewSonic OptiQuest Monitor
Monitor does not come on when powered on, it says no input signal
Check your video card. It sounds like it has went bad. Hope this helps.
Jan 08, 2009 | Gateway 420GR PC Desktop
No signal then orange light on my Gateway FPD1975W 19Inch Monitor
If you have a add on display/graphic card in your CPU then shutdown the system, open the case and try to press the display card gently. Sometimes if the card get loose the display will not come.
If you don't have add on display then try to press the Memory gently after shutting down the PC and try the signal again.
If not resolve let me know whether any beep/sound is coming out of your CPU box?
Rate my answer please.
Thanks.
Jan 04, 2009 | Gateway FPD1975W 19" LCD Monitor
No Signal
no signal mean that vga signal from cpu is not coming to it or may be this is a cable breakage relavant to signal from cpu.
2ndly, the matter of computer shuts down is out of sense because this kind of problem doent happens at this case.
check ur vga card, if it is seperately installed on motherboard.
the other thing that u can do is that;
unplug all the cables of data relavant to hdd, cd, dvd and anyothers and then switch on ur pc. hope it should work if anything is not wrong with the motherboad and ram, including vga
ragards,
Jul 26, 2008 | Acer Aspireā„¢ T180 PC Desktop
Computers & Internet Logo
151 people viewed this question
David Payne
David Payne
