Question about Jeep 2001 Grand Cherokee Laredo
What causes the fans not to turn on 2001 Jeep Grand Cherokee Larado v6 engine? Which cause the truck to run hot
I have replaced the thermostat. I have checked and replaced relay's also.
  • Jeep Master
  • 2,428 Answers
It could be a connection problem .
If the fan dosn't opperate the vehicle will run hot especialy at low speeds or in traffic.
Wiggle conections that relate to the fan around with it running watch your hands seeif it spins at all .
The next thing you can do is jump 12 volts off the battery with jumper leads .The vehicle dosn't need to be running just the key on .Unplug the connecter to the motor look for the black wire that will be ground alliagtor clips are helpful clip to corrasponding pin on motor plug then touch the rest of the pins 1 at a time .
If the motor spins its good and the problem is connections relay or switches . but at least you know what you should be looking for
Posted on Apr 15, 2015
  • 4 Answers
Check the fan belts and washers/spools that hold belt. Had a washer break apart in my old dodge and it stopped the fan dead in its tracks though the belt was still functioning.
I can't find the radiator fan relay on my 2001 jeep cherokee larado with a v6 4.0 motor. could you tell me where it is?
It is located under the passenger side headlight assembly, behind the inner fender well skirt.
Jul 28, 2011 | 2001 Jeep Grand Cherokee
I'm dealing with a 2005 Jeep Grand Cherokee with 3.7 litre V6. I just replaced a leaking radiator and thermostat and the car still runs hot. The fan is working and I see no leaks. What's next? Tell...
The rise in engine temp after replacing the radiator and thermostat could possibly be caused by air pockets trapped in the cooling system. You will need to run the engine with the radiator cap off and let the air escape. DO THIS only when the engine is cold, and let it build up to temp. Coolant will over flow during this process, but eventually coolant will need to be added once the air is released.
May 06, 2011 | 2005 Jeep Grand Cherokee
I have a 2001 Grand cherokee Laredo, 4.0, 6 cyl. Have had the Fan Relay replaced and Control Module because of overheating. Now it is overheating again. Any suggestions? And are the fan relay and...
If the fan is not cycling when the engine gets hot, you'll have to test the fan motor and the temperature sensor. If the fan is running and it's still hot, the thermostat may be the cause.
Oct 21, 2010 | 2001 Jeep Grand Cherokee
My jeep 2000 Grand Cherokee Larado is over heating. I have changed the thermostat and coolant. The fan seems to stop turning when it over heats. What can be causing the fan to stop when it should be...
Replace the cooling fan clutch. It is the silverish round device that the fan attaches to. This component is heat sensitive and will only function correctly when hot. They are known to fail over time. Also inspect the radiator for good coolant flow. DO THIS when engine is cold only or have a shop check it out for you.
May 21, 2010 | 2000 Jeep Grand Cherokee
2001 jeep gd. cherokee larado 4.0 4wd auto. when
Have you run an engine control system fault code test? If not do that first.
Jun 08, 2017 | 2001 Jeep Grand Cherokee
I have a 1999 jeep grand Cherokee larado V6.
The P1391 code indicates that the crank or cam sensor(s) have sent an intermitant code to the ecm. The most common cause for this is loose wiring or debris on the contacts of one of the sensors.
Nov 05, 2009 | 1999 Jeep Grand Cherokee
Radiator fan stays on after long hot drive.
Check your relay. I believe one of the terminal connections is an always hot connection. If your relay has gotten stuck in the on position, it will cause your fans to remain on.
Jun 28, 2009 | 2001 Jeep Grand Cherokee
Jeep Cherokee Radiator Fan
It is near the thermostat housing.
Nov 09, 2008 | 2001 Jeep Grand Cherokee
2001 Jeep Grand Cherokee- fan that sits closest to radiator
Have you tested the fan sending unit on the engine? disconnect that and if the fan runs (Key on) that is most likely the problem.
Oct 17, 2008 | 2001 Jeep Grand Cherokee
Jeep 2001 Grand Cherokee Laredo Logo
85 people viewed this question
Top Jeep Audio Players & Recorders Experts
Thomas Perkins
Thomas Perkins
Tom Chichester
Duff Howell
Are you a Jeep Audio Player and Recorder Expert? Answer questions, earn points and help others
