Question about Measuring Tools & Sensors
Info on adjusting ACURITE to connect with new batteries
How to connect interior ACurite with new batteries?
fixya-surfer
  • 73 Answers
SOURCE: my acurite inside unit keeps
There is no way to turn off beeping. From this site: http://www.chaneyinstruments.com/FAQ.aspx
found solution - Q: My wireless weather station periodically beeps, why?
A: Make sure that any alert and/or alarm features are deactivated first. Constant, sporadic beeping is generally due to the unit's ability to detect a foreign radio frequency of another wireless unit when that unit transmits a signal. Wireless devices that may cause beeping but are not limited to these devices are; scanners; computers w/wireless keyboard/mouse; or other wireless weather instruments. Essentially, any wireless devices transmitting on a radio frequency have the potential to interfere with each other. Limit the amount of wireless devices to lesson the chance of interference. When beeping occurs, one device will need to be deactivated.
There is no way to turn off beeping, d/s designers forgot. I had the same problem, another external temp gauge showed up on the other channel, so my neighbor or someone is using the similar unit. MY SOLUTION: opened back of case and cut black wire to piezo speaker (at base if rear cover opposite side of stand-up prop) that creates beep. Don't use any sound features, ALL good now.
Posted on Mar 03, 2011
SOURCE: I have the Acurite 00604RX
how do i set my clock for accurite 00604RX
Posted on Sep 07, 2011
SOURCE: manual for acurite ik634160 weather station
http://www.acu-rite.com/product-manuals.html
http://www.ehow.com/way_5552159_acurite-atomic-clock-setting-instructions.html
Please find what you want at the above links....
Posted on Oct 12, 2011
jthomp12
SOURCE: how to program ACURITE 8550
how do you set this device
Posted on May 21, 2014
  • 20 Answers
SOURCE: my acurite model75321a1 does not tell out side temperature
We would recommend a reset of your Weather Station. Please verify that you are using a good-quality, standard alkaline battery, and follow the steps below.
  1. Remove the batteries from the outdoor sensor only.
  2. In the outdoor section on the main unit, there will be a "CH" and number 1-3.
  3. If on CH 1, press and hold the channel button on the back of the unit for 5 seconds.
  4. Press and release the channel button one time, it should show CH 2.
    • If it does not change to CH 2, repeat steps 4 and 5.
  5. Press and hold the channel button for 5 seconds.
  6. Press and release the channel button one time, it should show CH 3.
    • If it does not change to CH 3, repeat steps 6 and 7.
  7. Press and hold the channel button for 5 seconds.
  8. Press and release the channel button one time, it should return to CH 1.
    • If it does not change to CH 1, repeat steps 8 and 9.
    ***Regardless of what channel you begin on, clear out each channel by holding the channel button and return to CH 1***
  9. Reinstall batteries in the outdoor sensor.
  10. Press and release the TX button.
  11. Leave both units side by side for up to 30 minutes to gain a strong connection.
If you need any further assistance, please contact AcuRite Customer Support at 1-877-221-1252 or info@chaney-inst.com.
Posted on Mar 17, 2015
Geo button on acurite weather forecaster model 02010 won't work
My opinion would be do do a factory reset. If this does not work, warranty? Do you feel comfortable opening up the case? Could be a connection issue. (Do not do this if it voids the warranty.
The link below are the instructions for reset and other options:
https://www.acurite.com/media/manuals/02010_02014_02015-instructions.pdf
May 16, 2017 | Computers & Internet
Why can't I receive input from the outside sending unit?
Make sure that all the batteries are good!!
This procedure outlines the typical process to pair the sensor and base.
Base Station Battery Installation
·Remove the printed vinyl label from the LCD screen of the base station
·Position the remote sensor near the base station
·Open the battery compartment at the back of the base station and insert (2) AA batteries according to the polarity markings. Replace the battery compartment cover.
·Within a short time the RF signal icon (located to the left of the outdoor temperature channel indicator) will start flashing. This indicates that the base station is ready to pick up the RF outdoor temperature signal from the remote sensor. It will continue to flash for 3 minutes or until the signal from the remote sensor is detected.
Register the Remote Sensor
·Open the battery compartment at the back of the remote sensor and slide the channel selector switch to your desired channel. For the first remote you may select any channel, for additional remotes select any unused channel
·Insert (2) AAA batteries according to the polarity markings. Be sure to install the batteries in the remote within the time that the RF signal icon is flashing on the base station. 1541 WeatherGuide Wireless Weather Forecaster with Barometer
Jan 07, 2016 | Measuring Tools & Sensors
How do I reset the remote after changing the battery life.
To reset your unit, please verify that you are using a good-quality, standard alkaline battery such as Energizer or Rayovac. Then, follow the steps below.
1. Bring both the sensor and display unit indoors and remove at least one battery from each.
2. Make sure the A-B-C switch on both units match. Sometimes changing to a different channel can help.
3. Reinstall the battery in the outdoor sensor.
4. Reinstall the battery in the display unit.
5. Let the units sit within a couple feet of each other for about 20 minutes to gain a strong connection.
Feb 21, 2015 | AcuRite Acu-Rite 00754 Wireless...
My acurite model75321a1 does not tell out side temperature
I checked my Acurite instruction file and found it rather vague about this issue but based on my experience with a similar system I found that battery changes have to be made at the transmitter first, allowing time for the transmitter to begin sending temperature data. Also, the Acurite instructions suggest use of lithium batteries in the transmitter where extreme low temperatures are encountered. My experience has been that the transmitter stops working at low temperatures so the reading comes and goes depending upon the weather. Currently it is 20 degrees F outside headed for 5.
Feb 01, 2015 | Measuring Tools & Sensors
Model 00754W4 does not sense outside temperature..new batteries have been placed correctly in both inside and outside units..noW what do I do?
We would recommend a reset of your unit. Please verify that you are using good-quality, standard alkaline batteries such as Energizer or Rayovac, then follow the steps below.
Dec 03, 2014 | Acu-Rite Acurite Wireless Indooroutdoor...
Acurite wireless weather will not work new last season all new lithium batteries in right and were checked no picture #'s on screen
Hi Jerry,
While lithium batteries are recommended for the outdoor sensor it is not recommended they be used in the indoor display unit. Try using a good quality, fresh alkaline batteries and you should find your display turns back on.
Nov 01, 2014 | Acu-Rite Acurite Wireless Weather...
Need User manual
I cannot find your model L50668TX thermometer on Acurite's website. That said, you can search available product manuals here:
http://www.acurite.com/kbase
Alternatively, if you still need more assistance/User Manual information, you can contact them with these details:
Website: http://www.acurite.com/support
Customer SupportTel: (877) 221-1252
Mon - Fri:
7:00 a.m. - 7:00 p.m. CT
Sat - Sun:
8:00 a.m. - 4:00 p.m. CT (Oct - Feb)
spacer.gifWholesale(866) 249-1045
Mon - Fri: 8:00 a.m. - 5:00 p.m. CT
support-mail.jpgMailing Address
Chaney Instrument Co.
965 Wells St.
Lake Geneva, WI 53147
Email: info@chaney-inst.com
Apr 16, 2014 | Acu-Rite Acurite Wireless Indooroutdoor...
How to reset my Acurite 1099rx after replacing battery
http://www.acurite.com/advancedsearch/result/?q=1099RX
There is no reset button, installing new batteries causes the sensor to reset itself.
Try removing and re-installing the batteries.
Good luck,
Steve
Jan 15, 2013 | Measuring Tools & Sensors
Measuring Tools & Sensors Logo
89 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
