Question about Vornado 133 Compact Air Circulator Fan
I just bought one of these and a friend says there are many applications for use. What else can I use this fan for besides blowing at me directly?
    Top Expert:
  • Vornado Master
  • 42,145 Answers
Fans are designed to move air only
whether this is at you, around the room, to move hot air from the ceiling, blow fumes away, exhaust an area or what ever
some fans have an accessory where there is a small pump and a spray of water behind the fan but these are specifically designed so that there is no possibility of electrocution from the water contact with the power
Posted on Apr 15, 2015
Is it possible fan motor in freezer wrong rotation?
Yes if you have the wires reversed..motors run in two directions polarity is what it is called....need to make sure it is spinning in the in the direction the manufacturers set...some designed to pull sir and others push...good luck..
Jun 24, 2015 | Refrigerators
Suzuki samuri won't blow on high
what year?
the fan will not blow on high has only 1 cause (besides wires )
1: the fans switch is bad
if others speeds fail the fan resistor is bad.
Aug 13, 2013 | Suzuki Cars & Trucks
2000 NISSAN 4X4 P/U A/C SYSTEM WILL BLOW COLD WHEN OUTSIDE AIR TEMP IS COOL, WHEN HOT OUTSIDE AIR BLOWS HOT.
your auxillary fan is not working. this fan is responsible for cooling the freon that is being circulated in your cooling system... check if there are any loose wires in front of the engine bay.
the auxillary fan is located right beside your radiator fan.
May 17, 2012 | 2000 Nissan Frontier
How do I make the fan blow from inside to outside? It is ducted to go outside but is blowing inside. I just bought this house and I need to know if there is a setting or fan direction switch?
this is easy. take it off the wall and on the top in the back there is a panel take it off and switch the direction of the diverter. so it si facing either sraigft up or facing out to the back , so it lines up with your duct work.
Sep 11, 2011 | Whirlpool MH1150XMQ Microwave Oven
Hi i just bought 3 chassis fan and i installed 2 on top and 1 rear... there is already one installed in the front when i bought the case....i want to know wich direction i have to put my 3 chassis fans (2...
Case fans tend to blow in the air out of the side of the fan which has the four plastic bars and normally the sticker. The fan may also have a set of arrows describing direction of rotation and flow of air.
May 18, 2011 | Computers & Internet
Can I change airflow direction with Goodman GMS8?
I would probably use a furnace for the correct application. However some motors do have a reverse speed connection. Besides the blower speed taps,
capacitor wires and the nuetral wire. There are two wire sets that you can switch that can do this if your blower motor is equipped.
You might experience some airflow problems, probably a lack of airflow, if the furnace was installed
as an upflow model instead of a counterflow.
Feb 17, 2010 | Goodman GMS90703BXA Heater
I need to replace my condenser fan motor. I replaced it once before but instead of blowing out the top, it was blowing on the condenser. Should it blow out of the top? If so, what direction should the...
Yes. It should blow out the top. The rotation of the fan does determine the direction of air. Either have the motor replaced and indicate the direction of rotation.
May 08, 2009 | Heating & Cooling
No air or heat blowing from vents
if the fan is blowing this could be a problem with the climate controll switch that changes the direction of air from floor to defrost to vents, some are vacuum controlled through a vacuum operated mechanism that opens and closes a door in the vents which redirects the air to different places.
Mar 24, 2009 | 1999 Volvo S80
Overheating
unplug the fan and run 12 volts direct to the fan from the battery if the fan turns then it is good if not then replace the fan and problem should be solved
Jun 26, 2008 | 1999 Dodge Grand Caravan
Ionic pro compact and ionic pro turbo
The clean light stays on and purifier doesn't work but unit is clean.
Jun 09, 2008 | Ionic Pro Air Purifiers
Vornado 133 Compact Air Circulator Fan Logo
103 people viewed this question
Top Vornado Dryers Experts
Dusty Ryan
Level 1 Expert
Steve
Mack Baxter
Are you a Vornado Dryer Expert? Answer questions, earn points and help others
