Question about Magic Chef Freezers
Where is the reset button on model MCUF88W? - Magic Chef Freezers
Can not get my freezer to reset after its been unplugged
Thank you for your inquiry, friend!
I understand that you are having difficulty resetting your Frigidaire freezer. Do you want to start your freezer on again? If so, depending on your freezer's control panel style, you may have to push the "Up" button three times or the "Down" button three times. What kind of model freezer do you have? You can locate the serial tag (which lists the model number) on the interior wall of your freezer. Once I have more information I can make sure to provide you with additional assistance. -Matt
Aug 28, 2014 | Frigidaire Freezers
Setting tempture
Turn the temperature control in the direction furthest away from the off setting.
Nov 19, 2013 | Magic Chef Freezer. 8.8 cu. ft. Upright...
Wont freeze or get cold
it has cooling problem or somewhere of wires are ligued.so you face this problem.
Mar 21, 2013 | Magic Chef Freezer. 8.8 cu. ft. Upright...
Magic chef freezer model mcuf88w won't freeze
When you thawed it, did you remove ice from it using a metal object. That may have damaged the coils when would allow freon to leak out. This is too coincidental to be a problem itself with the compressor. The t'stat might be the problem. Try turning it off at the t'stat for a few minutes, then turn back on to the normal setting. Keep door closed for 30 minutes and check the inside and see if the walls are freezing. If not, you may have a compressor problem, or t'stat, or relay switch problem.
Feb 04, 2013 | Magic Chef Freezer. 8.8 cu. ft. Upright...
We defrosted our upright magic chef freezer. When we plugged it back in, it will not work. There is a clicking sound from time to time but it only runs for a few seconds at a time.
I have the same problem, but so far, I have no resolution to the problem. My model however; is MCUF88W. There is a 1-888-775-0202 telephone number, but when I called, there is a busy tone. I need a solution to the problem.
The freezer is only two years for crying out loud. No solution here, SORRY. HELP!!!!!!!!
Aug 08, 2011 | Magic Chef 11.8 cu. ft. / 334 liter...
MAGIC CHEF FREEZER THE DOOR IS NOT OPENING FOR 8.8 CU FT UPRIGHT FREEZER MCUF88W -- BRAND NEW JUST BOUGHT?? HELP
If You run Your finger in between the rubber seal that is resting on the freezer and the frame of the door , the rubber seal will break lose. When you open the door the seal is attache to the door.
Just had the same problem after unboxing.
Simple, just be sure to do the entire door.
Sep 27, 2010 | Magic Chef 11.8 cu. ft. / 334 liter...
Is there a reset button for the freezer. Inside lights work, no power to compressor. Model T-49F
http://www.truemfg.com/pdf/InstallManuals/T-SERIES/t_series_english.pdf
Start with this web site. The install manual has good info.
I do not know of any reset buttons on the unit that come stock from the factory. An after market one could have been added at some time by a tech.
If you need more help, just let me know.
Oct 20, 2009 | Freezers
My freezer is stuck in defrost mode causing the alarm light to remain on
My freezer wouldn't run and I did find there was a reset button on the back of the freezer where the chord runs into the switch.
Jun 09, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Freezers Logo
111 people viewed this question
Top Magic Chef Freezers Experts
Dan Webster
Dan Webster
AJMAL KHAN
Tom Chichester
Are you a Magic Chef Freezer Expert? Answer questions, earn points and help others
