Question about Garden
Cannot push in clutch. When trying to start lawnmower, the clutch will not let you push it in.
When you sit on the seat and try to push on the clutch, it will not allow you to push it. The pulley underneath does have some play in it, but it seems to be around all the parts.
    Sergeant:
  • 462 Answers
Id say your pedal bearing is shot
Posted on Apr 23, 2015
3 Suggested Answers
buffalonyman
  • 1865 Answers
SOURCE: I Have a Craftsman 917.256. The engine will only
There is no way to guess at the problem, you'll have to use a meter and check the safety switches. Most likely there is a problem in the switch for the PTO, find the wire connector that attaches to the switch on the PTO and disconnect it.
If the unit works, then replace that switch
Posted on Nov 23, 2009
  • 6468 Answers
SOURCE: wizard riding mower won't start.
with jumper cables jump from the battery direct to the starter if ok sounds like the safety switch on the brake pedal is bad
Posted on Apr 29, 2012
Murray riding lawnmower #309029X92 can't turn shaft, Won't even start,
Karen, try to spin the top of the engine by hand. it should rotate, if it don't check to see if the starter has locked into the flywheel. make sure the blades are disengaged the brake pedal is pushed in and you are sitting on the seat.
May 30, 2016 | Murray Garden
Cub 1620. Am unable to get starter response cranking with drive lever in neutral position. Probable fix?
pull the ground wire off from the coil and try it,if it runs the safety switches are bad,hook a switch to ground and coil to bypass
Apr 20, 2015 | Garden
Riding lawnmower clutch not releasing
safety switch under seat or cable for clutch needs adjusted
Apr 15, 2015 | Garden
Can I push start a 2007 Honda 500
Hi Linda:
The short answer is yes.
I'll add a couple of extra comments.
- You can push it for ever and it won't start if it does not have fuel or spark. So, I;ll ask, Why do you want to push start it? If the battery is dead, or it won't hold a charge, that sounds like an appropriate fix.
- Push starting a bike can be dangerous. You have to consider that when the motor starts, the bike will want to accelerate, and probably rapidly. Know where you're planning on going if it starts.
- Technique.... It's easier to push a bike that's in neutral than when in gear with the clutch dragging, so the safe and easiest way to push start the bike is to have the ignition switch on, choke set where you think it should be, transmission in neutral, have a rider sit on the bike, and get it rolling downhill. The rider will then pull the clutch lever, put it into second gear, and let the clutch out at the same time as they drop their weight onto the seat. Tricky for a novice, but the weight drop helps to keep the back tire from sliding.
Think Safety!! If you're a novice rider, I would not recommend that you try this.
Mar 29, 2015 | 2007 Honda CBF 500
Doesnot start john deere electric start mower
simple things to ck first :
(1) battery - fastest way to test it is to jump start it
(2) safety's - with tractor off , turn key to first click , then try and engage the mower deck , you should hear a click , shift to 1st gear try again you should not hear click ,back to neutral then hold clutch down , try again you should hear click , all of this assumes your sitting in the operator seat when u try it , as the presence sensor only trips on human presence over 60 lbs if any of these tests does not produce the desired effect check that safety sensor , although ive found on JD's the seat switch is found bad allot
Jun 10, 2014 | Craftsman 675 Torque 190 cc 21" Push Lawn...
Wizard riding mower won't start.
Apr 27, 2012 | Garden
New......battery dead....will not pull start... does someone need to be sitting in seat?
Yes, you need someone in the seat and probably the clutch/brake pushed in to enable the engine to start.
Jul 14, 2011 | Garden
Difficult to start -- bad kill switch?
You have 3 safety switches located on the tractor, any one of which can cause the tractor to not crank over.
I assume the deck lever is not engaged, you are sitting in the seat and you push the clutch down when trying to start?
Start by lifting the seat and disconnecting the seat switch, push the clutch in and try to start.
Start there and we'll go from there.
Regards,
Aug 21, 2009 | Craftsman Garden
Craftsman 42" 19.5hp B&S Stalling
i have a crafsman mower and it only cranks it wont start wat would be wrong
Jan 04, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
37 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
