Question about Exercise & Fitness
What is the answer to this problem? Diana ran 5 miles and walked 2/6 of a mile. how much farther did Diana run than walk?
Diana ran 5 miles and walked 2/6.how do I find the answer to the question how much farther did Diana run than walk?
    Top Expert:
  • 44,387 Answers
She ran 5 miles
the walk is extra to the run so she ran 5 miles
Posted on Apr 15, 2015
  • 33 Answers
SOURCE: While walking on treadmill it will suddenly slow
hai more friction with flatform and belt
Posted on Oct 01, 2009
  • 16 Answers
SOURCE: How do I repair the seam of the walking belt?
Be extremely careful when trying to trim a belt. Understand that many hazards exist when performing these steps that can result in serious injury. If you have any question whether you can perform these steps or not, please call a professional and do NOT attempt this repair.
There are two methods that can be used to trim a walking belt when it has developed a tattered edge:
1) Remove the belt from the treadmill for trimming.
a) All walking belts are cut at some point during their life, whether in manufacturing or later during service, so this will not compromise the integrity of the belt as long as you cut a straight line and do not leave a rough edge.
b) Remove the walking belt from the treadmill, lay the belt flat and even on the ground, and measure and equal distance on each end of the belt and mark the belt for cutting on each end of the belt. Cut no more than necessary to restore a smooth edge.
c) Use a piece of flat steel or other metal object that is straight and long enough and connect the two markings on the belt with the metal object.
d) Using a new razor knife, box knife, or similar instrument, cut the belt along the steel object. If the knife has a new edge, you should cut through the belt in one or two passes of the knife.
e) Check the belt for a smooth edge and reinstall the belt.
2) Cut the belt while it is mounted on the treadmill. This method should only be considered by those who are familiar with treadmills and very good with tools. This can be a dangerous process.
a) Track or center the belt off center to the opposite side of the tattered edge (i.e.- if the belt is tattered on the right side, track the belt off centered to the left side by about 1/2 to 3/4").
b) Operate the treadmill at a very slow speed. Usually 1.0 or 1.5 MPH will be sufficient.
c) Using both hands, line a new razor knife up on the tattered side of the belt. Make sure to cut no more than necessary to make a smooth edge.
d) With the belt moving and using both hands, lift the knife up and contact the belt making sure to hold the knife steady and keeping your hands and clothing as free from the moving roller as possible. You will not damage the roller to the point where it will hurt the operation of the treadmill.
e) Do not lower the knife until you see the belt separate from the tattered edge. Once this happens, turn the treadmill off, unplug the treadmill, and cut the tattered strip off the treadmill.
f) Track or center the belt and operate normally.
Posted on Feb 21, 2010
Testimonial: "A great solution & I am going to keep it ready. Using a previous idea, I glued it with Loctite Ultra Gel-a super glue for rubber. So far, so good."
  • 218 Answers
SOURCE: The belt is sliping as I walk or run
* take nail polish or paint and place a mark starting on the front roller pulley and going onto the front roller metal shaft
* then try to walk on it and see if the white mark separates
* if it does then the roller is bad and would need replaced or tap screws placed through the pulley into the metal shaft to hold it in place
* if it doesn't separate then the drive belt is slipping and most likely will need replaced, although you could try spraying belt dressing on it to see if that would be a temporary fix.
* if neither of these is your problem and the walk belt is slipping then you will need to try to adjust the screws in the back of the treadmill through the end caps. these are allen wrench screws.
Tighten each one the same amount such as 1 full turn to start with.
see if you can now walk without it slipping.
If not then tighten 1-2 more turn on both sides.
If after 2-3 full turns it is not tight enough
I would recommend replacing the walk belt.
Hopefully this helps with your problem!
Posted on Aug 11, 2010
ercupa190
  • 12223 Answers
SOURCE: lcd screen is malfunctioning. cant
1) Retight the cable connector between the console and controller board, and clean it.
2) Adjust the Reed switch and Optic sensor and determine if faulty, before the LCD is faulty.
11_15_2011_9_12_01_am.gifFinally after I you did check all step, the problem will be LCD faulty replace it.11_15_2011_9_12_20_am.gif
Posted on Nov 15, 2011
ercupa190
  • 12223 Answers
SOURCE: after walking for about 2 miles the treadmill turns off
please the video and proceed according and fix it. God bless you
Posted on Mar 22, 2013
The track at Oak Middle School is 1/4 of a mile for each lap. Jacob walked around the track and completed 7 laps in 30 minutes. What is the unit rate of Jacob's speed?
I edited the question to show 1/4 mile. Jacob walked 7X1/4 that is 1 and 1/4 miles. 1.25 / 30 = .041 miles in 1/2 hr. .041 x 2 is .082 miles an hour.
Dec 13, 2016 | The Watches
You run from your friends house that is 3 miles away.You then walk home. What distance did you trave
You travel the distance between the friend's house and your home which is stated to be 3 miles.
Nov 05, 2015 | Cars & Trucks
Two hikers at 11 miles apart walking toward each other. They meet in two hours. Find rate of each hiker if one walks 1.1mph faster than the other
If they meet in 2 hours, they are travelling at 6.5 Miles per HOUR (2 hours, equals 11 miles) if they were travelling at the same pace. if one is 1.1 MPH faster than the other, you steal 1.1 from one walker and give it to the other walker.
Try and work it out yourself. Let me know if you can't :>)
It is important that you know how to do things rather than someone just telling you the answer.
Oct 03, 2015 | Exercise & Fitness
My Horizon T80 treadmill is emitting a smell after operating a while not an electric smell but a rubber chemical smell
How old is the walking belt? When was it last replaced? How many miles are on the belt. Seem like your belt and deck is worn.
Jan 01, 2014 | Horizon T92 - Treadmill
After walking for about 2 miles the treadmill turns off
Mar 22, 2013 | Exercise & Fitness
Codes
walk to a hill. from hilltop you have 10 miles
Mar 31, 2012 | Motorola Talkabout® FV510 Two Way Radio
There was a scientist who after doing research, found that color of skin of animals vary with change in distance.One day he started to chase a beer. He walked 1 mile towards north, then turned and walked 1...
There was a scientist who after doing research, found that color of skin of animals vary with change in distance. One day he started to chase a beer. He walked 1 mile towards north, then turned and walked 1 mile towards east and then caught the beer and radio-rib boned the beer Then he left the beer at that spot and returned to his base-station taking a turn towards south (walked 1 mile towards south). Then what was the color of beer at that spot?
Aug 18, 2010 | Computers & Internet
Electrical
after another check,determined it was bad alternator
Jul 08, 2008 | 1998 Ford Windstar
Exercise & Fitness Logo
177 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
