How to finalize disc - Televison & Video
    Top Expert:
  • 10,875 Answers
Finish it so it will play in other dvd players
Posted on Apr 15, 2015
My centrios edw8020 dvr records o.k. but won't play dvd on any other dvd systems
If the disc is not "finalized" it will not play on other DVD players. The steps to finalize the disc are part of the DISC Utilities Menu. under "DISC OPERATIONS". Choose "FInalize DISC". Instructions refer to finalizing DVD=R disc, so you may want to try this type of disc first and see if it works. Says It can be used as DVD-Video disc but results are not guaranteed. You can not edit disc after finalizing, only playback.
Jan 28, 2014 | Centrios EDW8020 DVD Recorder
Finalizing a DVD-R blank disc
try changeing the disk name and then see if the finalize option is availalbe.
Jun 18, 2008 | Sony RDR-GX315 DVD Recorder
DVD Recorder is ruining the DVDs
Here is the link to the manual for LG DR1F9H
read pages 33&34
you may be using wrong
disc or wrong mode
Dec 13, 2007 | Televison & Video
I just bougth a marantz cdr 300 cd recorder,everything seems to be working fine, but I'm not able to listen what I just recordered on any other cd player.Marantz cd 72 mr 2020.Thanks
It sounds like you haven't followed the last step to the burning procedure. All you need to do once you've completed burning your disc is to Finalize the disc. Read below why you need to finalize as well as the steps to follow in order to finalize the disc.
Hope this helps ;)
How to Finalize Finalizing is writing the TOC (table of contents) on a disc so a CD player can recognize the number of tracks, the total time for each track, and their location on the disc. A recorded disc must be finalized to playback on a standard CD player. Once finalized a CD-R disc can be played on CD players that support CD-R playback. CD-RW discs can only be played on CD players that support CD-RW playback. Consult your CD player owner's manual to confirm supported formats. Finalizing is necessary to: • be able to play a recorded CD-R or CD-RW disc on a CD player • prevent further recording on a disc • avoid erasing tracks on a CD-RW disc • record text information onto a disc you record Notes: • A finalized CD-R disc can never be recorded onto again. • A finalized CD-RW disc can be unfinalized for more recording. • The CDR300 can play back unfinalized CD-R or CD-RW discs. • SYNC REC+FINAL mode automatically finalizes.
Here are the steps in order to Finalize your disk
1 Push Stop. The display shows the number of tracks and their total playing time. 2 Push FINALIZE. FINALIZE is displayed for about 3 seconds.
Jul 27, 2011 | Audio Players & Recorders
Dvd does not show what was recorded from my sony camcorder error message C13:02 flashing
This is Disc Access Error, Disk Access Error, Check disc error, Check disk, C error unreadable, disc error code 13, disk error code c1302, c:13:O2 DISC ERROR, Disc Error C:13:02 message Sony mini dvd finalize error code C1302 DVD not finalised, Rec Disabled Record Disable after dropping the camera, DVD not finalized, DVD Disc not finalized, DVD Disk not finalized, DVD Disc not finalised, DVD Disk not finalised, Disc won't finalize, Disk won't finalise DVD Disc Error, DVD Disk Error, DVD Disc Format Error, DVD Disk Format Error, Rec. Disable, not correct disk, the disk in drive is not formatted do you want to format it now.
Nov 15, 2009 | Motorcycles
Finalizing
All units are different but you'll insert the disc to be finalized,
go into your disc menu, edit disc and you should see a finalize disc.
The disc will finalize (this usually takes a few minutes).
You will no longer be able to record on this disc so make sure you are finished with it!
If the disc is not finalized, you will not be able to play it in any DVD player other than the one you recorded it in!
I know it's not step by step but I hope this helps :)
Jan 08, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Samsung R155 Recording from VHS Issues
The reason why you are having this problem is because you haven't finalized the disc. In able for you to play that Burned DVD that you have you need to Finalized the disc. Finalizing a recordable optical disc means writing the disc's lead-in (the Table of Contents or TOC) and lead-out information (blank data that fills up the unused space at the end of the disc) so that a DVD player will know where the various tracks begin and end. Without the TOC, a conventional DVD player will not be able to read the contents of the disc. Once the disc is finalized, no more information can be written to it. Finalizing takes about two or three minutes. To finalize a DVD-RW/DVD-R: 1. Press the Menu button with the disc stopped. 2. Select Disc Manager and press Enter or the right arrow. 3. Select Disc Finalize and press Enter or the right arrow. You will be asked twice if you are sure that you want to finalize the disc. Select Yes and press Enter. Once the disc is finalized, you cannot delete entries from the record list. After being finalized, the DVD-R/DVD-RW (video mode) operates in the same manner as a DVD-Video. Recorded discs must be finalized in order to play back in non-Samsung DVD players. A DVD-RW disc that has been recorded by DAO (disk-at-once mode) in a PC cannot be unfinalized. A DVD-RW disc that has been recorded in Video Mode on a non-Samsung recorder cannot be unfinalized by a Samsung recorder. A DVD-R disc cannot be unfinalized. Note: Finalization does not apply to DVD-RAM. If you cannot finalize a DVD-R or DVD-RW disc, make sure that Disc Protection is turned off. If you are still having difficulty, you may try calling technical support of SAMSUNG. Note: Do not turn the recorder off while it is finalizing the disc. Data on the disc will be damaged if the finalization process is interrupted.
Sep 17, 2007 | Samsung DVD-R155
Power disconnected during finalization
There's no way you can continue the finalization of the disc, the disc has been marked as finalized already, even a single power fluctuation when you are using ac power adaptor can affect the disc finalizing process, so it is better to use battery when disc finalizing
Aug 30, 2007 | Sony DCR-DVD301 DVD Camcorder
How long does it take to finalize? Can I finalize on other recorders?
The finalizing time depends on the remaining time on the DVD-R disc; Approximately 8 minutes to finalize with 20 minutes recording time on disc Approximately 3 minutes to finalize with 10 minutes recording time on disc Approximately 2 minutes to finalize with no recording time on disc. DVD-R discs recorded on the DVD-Camcorder cannot be finalized on other DVD-R Recorders or PCs.
Sep 05, 2005 | Hitachi DZ-GX20A DVD Camcorder
Finalizing Discs
The only reason that you have to finalize a DVD-R disc is so that you can play it back in an external DVD. Once finalized, you can no longer add motion video to that particular disc. Discs that are not finalized can still be played back when inserted in the DVD-camcorder.
Televison & Video Logo
Top Televison & Video Experts
