Question about Garden
Riding lawnmower clutch not releasing
Riding lawnmower will not start. Clutch does not want to release.
    Sergeant:
  • 462 Answers
Safety switch under seat or cable for clutch needs adjusted
Posted on Apr 23, 2015
SOURCE: engine dies off once brake/clutch is released
Your answer was perfect, when I located the saftey switch it was not working properly.
Thanks a million, Ron
Posted on Feb 12, 2009
SOURCE: I have 16 hp Craftsman riding mower with a Kohler engine.
It may think you are in reverse and is killing the motor to keep you from backing up with the blade running. Look for switch that is telling it when you are in reverse, maybe it is stuck with grass or other debris. another possibility is that the blades are jammed and they are stalliing the motor. Mines stalls easily when cold.
Posted on Mar 12, 2009
  • 109 Answers
SOURCE: engine stalls when clutch/brake pedal is released
Under the seat, there is a operator presence switch, if this switch fails, the mower will shut off when the brake is released, or put in any gear.
Posted on Apr 23, 2009
  • 138 Answers
SOURCE: riding mower dies when releasing brake
the seat switch is the problem. the switch itself could be bad, but usually theproblem is that the connector is just not plugged in all the way [by the way, trying to bypass the switch by inserting the wire doesn't work because there is a "switch" inside the connector to prevent you from doing just what you did]
Posted on Aug 17, 2009
SOURCE: my craftsman lawnmower runs but when you release
i have same problem...where is interlock?..if i hear i'll send to ya..tom..tbrouff@zoomtown.com ...tnx
Posted on Apr 24, 2010
Mower starts, dies when you release clutch.stumped. is it time to replace mower or is this relatively cheap fix
My Husqvarna 48-Inch Mower Will Not Stay Running ' Home ...
homeguides.sfgate.com > ... > Other Real Estate Terms & Definitions
Among its offerings is an extensive list of riding tractors and mowers. ... Mowerissues can prevent you from performing your lawn-maintenance program. ... If yourHusqvarna 48-inch mower dies without spinning down, check the drive belt ... If yourHusqvarna mower runs until you release the clutch, chances are you have an ...
Aug 01, 2015 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Why does engine stop when clutch released or blades engaged?
Make sure have a good battery when you start the blades on any lawnmower it need lots of power to get it going
Jul 17, 2014 | Murray Garden
Murray ride on cuts our when releasing the clutch. Starts ok, have checked fuel supply to carb, air filter, spark plug, oil level .?..
Is this only when releasing the clutch? I assume it runs good other than that? I would check three things first. Compression, spark and fuel. Compression should be at least 50-60 psi. If that's good hook up an inline spark tester and start unit and observe while releasing the clutch, If you loose spark when releasing clutch if probably a safety switch(similar to safety switch on seat that grounds unit out when you get off the seat)
If you have good spark when releasing the clutch and good compression, its probably a clogged carb. This is the route I would take. I hope this helps. Good luck!
Aug 11, 2013 | Garden
Mahindra tractor diagnostics
You are going to have to disconnect belt and try to turn pulleys on drive system to locate the excact location. It sounds like a belt tension or bearing problem to me.
Jul 19, 2013 | Husqvarna Garden
Bolens riding lawnmower st100 pto won't engage?
check for power to the clutch if yes the clutch could be bad or a wire going to it if no power check the safety switches
May 17, 2012 | Briggs & Stratton Garden
How do you replace drive belt on a hydrostatic transmission craftsman riding lawnmower that has slipped off or my be broken.
Its not a hard job just push in clutch and lock it, remove mower belt then replace drive belt and then put mower belt back on and release clutch.
Jul 17, 2010 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
My Craftsman 3000 Riding Lawnmower does not move when the clutch is released. Upon further inspection, I found a rubber strap, about 10 inches long, with larger areas on each end (looks like each end is...
The rubber strap is most likely the battery hold-down strap. It should be stretched up over the top of the battery.
As for not moving when the clutch is released, check the drive belt that runs from the engine back to the top of the transaxle. Check for condition as well as positioning. Is it tight when the brake/clutch is released. Remove the dust caps off both rear wheels and start up the tractor, let out on the clutch/brake and observe the axle in the center of both rear wheels. If one of them is turning without the tractor moving, you have lost the square key that pins the wheel and axle together
Sep 19, 2009 | Garden
Lawn tractor won't stay running if clutch is released.
There is an operator presence switch under the seat...it is more than likely faulty and must be replaced in order for the mower to run right.
Apr 28, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Garden Logo
64 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
