Question about Atlantic Breeze ATL44550 Stand (Pedestal) Fan
How do I put the strap back on an Atlantic Breeze fan that holds the guard?
Harbor breeze fan wont run on low speed.
When you remove the Front guard on the fan, does the Fan blade turn freely?
Let's figure this out together....Mack
Nov 23, 2016 | Dryers
Where can I get a j Steven arms co 105/107 single shot 12 ga trigger guard?
http://www.gunpartscorp.com/Products/147830B.htm
That's Numrich. If you like guns, bookmark it.
That flat strap trigger guard is a sort of standard item. You attach the front screw and then gently bend the back til it suits you and it fits the back screw hole.
Big fan of old singles, too. I pick them up any chance I get just to sand and polish and repair. It's a great hobby.
Aug 23, 2016 | Optics
Lasko table fan model 4916 , I would like to know how to take it apart to clean it.
Kevin-
LASKO's typically have latches or clips that hold the front fan guard to the back fan guard.
Flip latches or carefully remove the plastic clips. This will reveal the 'nut' that secures the fan 'blade assembly'. Note, the nut has 'lefthand' thread so to remove it, turn it clockwise to remove.
The fan blade assembly can be pulled / wiggled free.
The fan blade assembly can be washed with water / wiped with a cloth.
Another nut (righthand thread) secures the back half of the fan guard, remove it and remove the guard.
That should do it.
Dec 18, 2014 | Dryers
I have a small hawaiian breeze fan that is all metal with a small metal stand and I took it apart to clean it and I removed the fan blade as well upon cleaning. I put it back together and now it runs way...
did you take any wires off or did you take the switch out ?
If you only removed the fan guard and blade then I have no idea what could have happened
If you removed the motor or wires then possibly you have wired it wrong .You could od a search on the mfg website ands ee if they have a wiring diagram
Sep 22, 2013 | Dryers
Atlantic Breeze Fan
Is this a ceiling fan? Never heard of Atlantic Breeze. Where did you buy it?
Jun 22, 2013 | Dryers
Guards won't stay facing down?
DEAR SIR, PLZ TEL US.HOW TO INSTAL/FIX THERMAL PROTECTER IN CEILING FAN.AND IT FUNCTION.WHY IT MUST FOR CEILING FAN.WHERE NEED FROM MARKET.ITS FUNCTION DETAIL.WHEN HE WORK PROPERLY IN CEILING FAN. alahamadfan@yahoo.com malik jameel awan.
Jun 17, 2013 | Dryers
My hawaiian breeze 16" fan isn't working properly.
try wedging a paper clip in between to hold the gaurd in place.
Jun 17, 2013 | Cars & Trucks
My atlantic breeze fans remote is not working. who mfg them so i can contact them with my problem?
Hello :
Did you try to replace the battery ? I recommend you to replace it .
regards .
Apr 21, 2010 | Atlantic Breeze Dryers
Broken threaded plastic part to hold blade tight.Aloha Breeze Vintage Stand Fan Model 46051
Have you tried using the Evostik Superglue for Hard Plastics
It is brilliant for putting broken palstics back together again
May 25, 2009 | Tower Aloha Breeze Fan
Atlantic Breeze ATL44550 Stand (Pedestal) Fan Logo
46 people viewed this question
Top Atlantic Breeze Dryers Experts
Dan Webster
Dan Webster
Are you an Atlantic Breeze Dryer Expert? Answer questions, earn points and help others
