Question about Apple iPhone 4S
Goes to voice main on first try on second try rings
  • 954 Answers
According to iPhone faq.org: " How can set the number of rings on my iPhone before voicemail picks up?
You can set the iPhone to wait longer or shorter than the default 20 seconds before it goes to voicemail when receiving an incoming call. This will result in a different number of rings before the voice messaging system picks up the line and plays your outgoing message. To change the amount of time the iPhone will ring follow these steps:
1. Open the phone app and dial *#61# on the Keypad. Press the Call button.
2. Locate this text on the screen: "Setting Interrogation Succeeded, Voice Call Forwarding, When Unanswered, Forwards to +" and record the 11-digit number after the + symbol.
3. Touch the Dismiss button. Now enter this code on the Keypad: *61*+ followed by the 11-digit Forwards to number recorded in step 2, followed by *11 and *ringtime#. Ringtime is the number of seconds you want your iPhone to ring before voicemail picks up. Your finished code should look something like this:
*61*+18555513466*11*30#
In the example above the ring time is set to 30 seconds. Press the Call button.
4. You should receive the message: Setting Activation Succeeded. Press Dismiss and next time you receive a call it will ring for the new amount of time before going to voicemail."
According to Apple Tool Box.com: "having this problem, please try the followings:
  • Make sure that iPhone's Ring/Silent switch is OFF meaning ringer is ON. A bell will flash briefly on the screen when you turn on the ringer.
  • Make sure that the Do Not Disturb setting is not silencing calls (Settings > Do Not Disturb).
  • Make sure that Airplane Mode is OFF (Settings > Airplane Mode).
  • Make sure that your carrier software is up to date (Settings > General > About)."
    AccorA
Posted on Apr 27, 2015
Trying to change the number of rings before my phone goes to Voice Mail on the Meridian (Nortel) M5316. Only two rings currently so I miss a lot of calls. Thanks!
Depending what system your provider is using it can either be done by you at home or they will have to set it. If you call your provider they will help you or they will fix it. Each ring is set at 6 second intervals so if you have 3rings that is 18 seconds. If you was 6 rings then ask for 36 seconds etc. hope this helps
Oct 11, 2013 | Aastra Telecom Aastra MDC Centrex...
How do i set ring on Flexible Buttons.....
Perhaps you are trying to set up speed dialing.
Right?
Jul 22, 2013 | Panasonic KX-DT343 White 24 Button 3-Line...
How do you adjust the number of rings?
Each ring is 6 seconds. Phone your phone provider and ask them to set the rings to 36 seconds for 6 rings
Feb 29, 2012 | Aastra Telecom Powertouch/Vista 390 Corded...
How do you extend length of ring before it goes to voice mail.
try the following key sequence...
**61*xxxxxxxxxx*11*yy# <send>
xxxxxxxxxx = your voicemail number
yy = time in seconds before it diverts to voicemail (maximum 30 seconds)
Jan 04, 2010 | Samsung SGH-A877 Impression Cell Phone
KX-T7633 Voicemail rings
The Voice Mail feature is set by your phone company, not by the phone. Typically the phone company will set it for 20 seconds, or approximately 4 rings. This is called your voice mail "Ring Cycle"
Call them up (the customer service number should be on your phone bill) and they should be able to increase or decrease your ring cycle for you at no charge.
Dec 02, 2009 | Panasonic KX-T7633 Corded Phone
Need more rings
You have to change the rings from the voice mail server. If you don't know your way around the server, its best to get a local NEC tech although it is fairly simple to navigate. Depends on your skill. Typical default password for the server is NEC
Oct 16, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
Extending Ring Time
You can try the steps below:
A) The simplest method is to call your carrier and request a longer ring time, up to 30 seconds.
B) If you have a GSM based phone, some have had success by dialing this number from your phone: **61*XXXXXXXXXXX**30#
  • Replace XXXXXXXXXXX with the number of your carrier voice mail center (find it by looking at your Phone Dialer > Options > VoiceMail > Access Number. Put your access number in place of the Xs above.
For example, the T-Mobile voice mail access number is 18056377243, and thus the string to dial would be **61*18056377243**30#
  • Replace the 30 at the end of the string with your desired seconds. For most carriers, 30 seconds is the longest allowed.
  • NOTE: Has been reported this doesn't work for Rogers (8700r) . 6/17/2005. Morser
Sep 21, 2008 | RIM BlackBerry Pearl 8100
Number of rings
press *94, then press the number of rings you want 1-9. The tone will change and thats it.
Nov 29, 2007 | Siemens Gigaset S455 Cordless Phone
Apple iPhone 4S Logo
277 people viewed this question
Top Apple Cell Phones Experts
David
Martin Murray
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
