Question about Saws
I'M LOOKING FOR A FENCE FOR MODEL #55-6897-0 SERIAL # W065166
How to find about Electric dog fence?
There are lots of websites on net that are offering data concerning Electric dog fence. These are specially made for all those individuals who are looking at affordable costs for quality dog fences. To find out more please visit with this website:
https://wirelessdogfenceguide.com/
May 05, 2017 | Saws
Truing the fence on a Powermatic 66 table saw
There should be some screws on the bottom side of the fence that allow you to make adjustments. Loosen then slightly then set the fence to 90 degrees & then tighten them.
Dec 27, 2017 | Powermatic 1791227K Model 64 10" Artisan...
Need to line up the blade with the fence
I take the blade out of my tri square and lay it between the fence and the blade and let it touch the blade. Then I set the fence tight with the tri square blade.With the blade against the fence you can position the saw blade just where you need it.
I always add this for your information. If this is not the solution that you are looking for please re post because when we pick a question to answer FixYa takes it out of the question queue. Thank You for choosing FixYa.com.
May 01, 2011 | Delta 36-979 10" Left-Tilt Contractor's...
Can I order from anyone a new fence for a skilsaw fence model 3400.
Skil is part of Bosch Tools. You can go to their website. https://www.boschtoolsservice.com. Click on "Search for your tool" under tool model # type in 3400. I believe the fence you are looking for is part #860 and costs about $34.00, however I would recommend calling them because there were so many variations on the 3400 that there may be more than 1 fence for model 3400 and you want to make sure you get the proper one.
Oct 09, 2010 | Skil F0123400AB Na 10" Table Saw, 15 Amps
Need a rip fence
Howdy, Here is the ordering page link with the rip fence (called edge guide, part number 2610997206 by Bosch) from Bosch:
https://www.boschtoolsservice.com/Search/QuickPartsOrder.aspx
I would recommend looking in a pawn shop or ebay as the rip fence is nearly 100 dollars as a replacement part.
Hope this helps a bit:)
Regards, Farmerbear
Sep 08, 2010 | Bosch 4000 - 07 Electric Table Saws
Blade isn't cutting well. It smokes and the wood rides up as it is cutting. The saw is 14 yrs old but blade has only been used a few times. I think it needs alignment. Can I do that myself?
You should be able to adjust the fence but every model is different so I probably cannot tell you exactly how. My Biesemeyer fence has 2 set screws on front guide of the fence for parallel adjustment to the blade (this fence is a single piece fence). I had a Sears contractor saw that had 2 bolts on the top of the fence that needed to be loosened, the fence moved parallel, and the bolts tightened again (the Sears fence was a bolt together fence). Whatever fence you have I would think the adjustment would be on the front part of the fence. I would remove the fence (the fence only, not the guides) from your table saw and take a close look at it for any adjustment screws (the Biesemeyer set screws are somewhat hidden) . If the fence bolts together you will probably need to loosen the bolts to do the alignment. There is a quick check you can make to verify the problem is the fence not being parallel to the blade because your problem could also be caused by a bent saw blade arbor (the saw blade would wobble as it turns)
ø Lock your fence down and measure from the front of the blade to the fence and from the back of the blade to the fence. These measurements should be within 1/32” (ideally is should be zero).
ø If the fence passes the test above, you can see if your saw blade shaft is bent by sliding the fence very near the blade, locking the fence down, and rotation the blade by hand (unplug the saw first). If the blade rubs on the fence as it rotates then you could have a bent arbor, a bad arbor bearing, or a bent blade.
Oct 03, 2009 | Craftsman 10" Table Saw
I need an instruction manual for a DeWalt DW100 bandsaw.
Hi I have a manual for DW100 bandsaw. E-Mail : mikepat21@sky.com and I will send a copy to you. Regards Mike
Sep 06, 2009 | Dewalt Saws
Fence won't lock on rear rail.
Before I can assist You, I need you to provide some more Information.
Make, Model, & Serial # of Table Saw? Is this Fence the Standard that came with the Saw? What type of "Rear Rail" do you have? What "Rod" are you referring too?
Apr 03, 2009 | Saws
Manual,fence and rail
The manual doesn't seem to be available online at the moment. There's a parts diagram, if that's helpful, or perhaps you can find an alternate site that provides instruction manuals. See this link, in any event.
Otherwise, you might check Woodworker's supply (woodworker.com) for the accessory fence and rail. They carry genuine Delta parts, which should fit your old Rockwell, as well as some aftermarket fences and guides that will usually adapt easily to fit a 14" bandsaw. The 14" Rockwell is one of the industry standards, and many woodworker catalogs carry fences that will bolt on with a minimum of fuss.
I recommend you do a web search on "14" bandsaw fence", and browse the results. You may even find something used to suit your needs.
Good luck, and let us know if this solves your problem or we can provide any further information!
Mar 23, 2009 | Delta Woodworking Delta Rockwell 14 Inch...
Saws Logo
140 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
