Question about Lands Phones
How to change outgoing message KX-T7633
I pressed *075 and it tells me the number I have dialed is cannot be completed as dialed.
cnavarro
  • 2460 Answers
SOURCE: Digital panasonic kx-t7633
The 7633 has a FWD/DND button. Is it blinking, lit solid or dark? It's designed to be pressed 3 times for FWD DND or OFF....It's programmed as follows, assuming that 500 is your voice mail access code:
From the intercom dial *7101. That sets DND. Dial 710x 500 # to set call forwarding where x-2 for all calls 3 for BUSY for for NO ANS 5 for BSY/NA. 7&8 are FOLOW ME commands and they have a different set of instructions ie Dial *7107 plus your extension to have calls come to the phone you're at and *7108 plus your extension to cancel it. I have never seen it used. *7100 cancels all forward and DND arrangements from your phone..
This is just hte command set for ALL CALLS. You can also set up forwarding for Outside Calls and Inside calls seperately and you can program buttons to do the forwarding.
Your Panasonic dealer has 2 manuals that you would find interesting, one is the TDA Operating Manual and the PTPM Manual. The operating manual has a complete set of programming instructions for the manager and users of TDA systems, the PTPM has a complete set of programming features that can be performed from a Panasonic 76XX display phone.
THe pdf's aren't huge and they can be sent to your email address if you provide one under the Ask Me button.
Carl
Posted on Oct 01, 2008
SOURCE: how to forward calls using KX-T7633 ?
press 'program' - at the top of the phone
enter 50
press ' enter'/ auto dial store
enter 4
enter the extension you wish to transfer call to
press auto dial store
to take call forward off
press program
enter 50
press 'enter' auto dial store
press 0
press auto dial/ store
this should work!
Posted on Oct 02, 2008
cnavarro
  • 2460 Answers
SOURCE: PANASONIC KX-TDA-50 PHONE SYSTEM WITH
From the main phone, press PROG **1234 and dial 004. Press ENTER 2 times (watch out, it moves on the display) and you will be looking at 101 : OPERATOR if it's still unprogrammed. Keep pressing NEXT until you get to the one you want to change and use a combination of the keypad and the AUTO ANS button to spell out the new name. The STORE button saves it, the right arrow and clear button step back and forth on the line you're entering.
You can pick up the handset and drop it back into the cradle when you're done to exit.
Carl
Posted on Jan 21, 2009
  • 19 Answers
SOURCE: changing the names fixed to internal extension numbers
If you can not log into the programing tool to change it that way then you will still need the Installer password. However from the main ext typically the first ext or 101
hit the Program soft key just below the LCD
push * then #
password
004
ext number you wish to change
type in new name
ENTER
END
Posted on Apr 14, 2009
  • 547 Answers
SOURCE: KX-T7633 Voicemail rings
The Voice Mail feature is set by your phone company, not by the phone. Typically the phone company will set it for 20 seconds, or approximately 4 rings. This is called your voice mail "Ring Cycle"
Call them up (the customer service number should be on your phone bill) and they should be able to increase or decrease your ring cycle for you at no charge.
Posted on Dec 02, 2009
Message indicator light will not go off. There are no messages.
If there were no messages, then the light would be off. A simple concept.
Messages can be left from someone dialing your number and pressing either MESSAGE or dialing 4 after the number. Call someone inside and try it.
Now, on your own phone, press MESSAGE and look at the display. It will tell you where the message came from and the 3rd soft key under the display will say CLEAR. Press it and keep doing that until you have no messages left.
Carl
Nov 09, 2010 | Panasonic KX-T7633 Corded Phone
With the Panasonic KX-T7633 - how do you change the time on the display?
Press Program button
Dial **1234
Dial 000
Press SP Phone Button Twice
Dial Hour (00-12)
Press FWD/DND button
Dial Minutes (00-59)
Press Auto Answer button to select AM or PM
Press Autodial/Store button
Press Hold button
Sep 28, 2010 | Panasonic KX-T7633 Corded Phone
Panasonic KX-T7633 Notification Light will not turn off
The red light is MESSAGE WAITING. It is not necessarily VM notification. Press the MESSAGE button and look at the display. One of the soft keys will let you CLEAR the message and it will tell you where it came from. It's set by anybody calling your phone, and randomly, it is set by dialing your extension plus "4". Oops. It's a Pana mystery :-)
Carl
Jul 07, 2010 | Panasonic KX-T7633 Corded Phone
Cannot get the correct time set on the phone. Panasonic kx-t7633
Try this....
For Panasonic system (especially for KX-T7633), you have to make changes from extension 101.
1. leave handset in the cradle then press "program".
2. Dial *# then "SP-PHONE" button until you see something like time set something something
3. manually input correct date then time then press "auto dial/store" button.
4. pick up the handset then hang up to save.
Aug 24, 2009 | Panasonic KX-T7633 Corded Phone
Carl
Oct 01, 2008 | Panasonic KX-T7633 Corded Phone
Panasonic KX-T7633. Phone message box is busy
This, my friends, is a very popular problem. It is caused by someone else in your company pressing the Message button on their phone while you are calling them or they are calling you. We strongly recommend to our customers that no one presses the Message button under any circumstances. To access your voice mailbox, always dial the Automated Attendant access code assigned by your installer - usually 165 (although on our systems it is "62" or the letters "MB" for MailBox).
You need to dial the Message Waiting Lamp feature code and dial "0" for the extension number. The code itself varies from system installation to system installation, but the most likely numbers are *70 and 70.
We have a support package that allows us to make all the changes you need over the Internet for a flat annual fee. If you want your whole system to work properly and all changes to be made for you at a flat budget, call us at 877-236-8376.
Jan 14, 2008 | Panasonic KX-T7633 Corded Phone
Recording messages
You are asking about changing you voice mail and phone system settings. Your phone can work on several different Panasonic phone systems and you could have different voice mail systems as well.
The phone KX-T7633 has only a user guide that covers the basic features of the phone itself. You need a programming and installation manual for your phone system AND your voice mail. They are not the same part and have different manuals.
So, your first step is to find out the model number of your phone system and voice mail system.
Oct 09, 2007 | Panasonic KX-T7633 Corded Phone
How to forward calls using KX-T7633 ?
enter 50
enter 4
press program
enter 50
press 0
this should work!
Sep 03, 2007 | Panasonic KX-T7633 Corded Phone
Lands Phones Logo
73 people viewed this question
Top Lands Phones Experts
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
